Old June 26th, 2013, 09:55 AM   #1
Aggrotech
Aggrotech's Avatar
Motorcycle(s): 12' Ninja 250
C-550 Wellnut
Is it possible to find these..? I checked the kawasaki site, ebay, google, amazon, ninjette..basically I'm looking for a wellnut that has C-550 on it, its about half the size of the typical looking M5 wellnuts that come with aftermarket windshield kits and it also has an O ring in the center of it.
I cant find it anywhere, Anyone know where to get them? I've looked for about 10-15minutes and have checked all types of forums aswell with no luck
Aggrotech is offline   Reply With Quote
Old June 27th, 2013, 02:14 AM   #2
Aggrotech
Aggrotech's Avatar
Come on, Anyone? After searching i found something very similer to what im talking about, but theyre still not quite it.
http://www.neverland-motor.com/unive...5mm-black.html
Very similer to these, with the built in Oring. The wellnuts im trying to find i believe came stock with the 2012 ninja. I have 2 left at the 2 top mounts of my wind screen, I couldnt find them on the kawasaki sites and the bolt kits dont even come with them.
Old June 27th, 2013, 05:52 AM   #3
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Can I get a picture of the exact wellnut? I've purchased quite a few different kinds over the years.
Why do you need the built in O-ring?
Old June 27th, 2013, 06:25 AM   #4
Aggrotech
Aggrotech's Avatar
I wouldnt say i necessarily need it (the O ring,) It just happens to be on the wellnut im trying to find. basically the most common m5 wellnuts are too long, with the threads at the very bottom. the one im trying to find is still an m5, its just smaller, which means the threads arent so far down the wellnut and it just happens to have an O ring on it
Sun is finally comin up, i'll see if i can get a decent pic of them. Don't wanna pull it out in case i ruin it
*edit* was able to get one pic before the battery died, charging now and i'll upload
Old June 27th, 2013, 06:35 AM   #5
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Normally I get my stuff from http://www.lockhartphillipsusa.com/S...STENERS-c-367/
Or http://kurveygirl.com/shop/index.php?cPath=24
Old June 27th, 2013, 06:54 AM   #6
/moved to items wanted
Old June 27th, 2013, 06:54 AM   #7
Aggrotech
Aggrotech's Avatar
The top of the wellnut looks like ur standard wellnut and it says WELLNUT C-550 33 ( 33in smaller print)
Old June 27th, 2013, 06:59 AM   #8
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
And it's molded that way new and not just deformed like that opon tightening right?
I've seen both, I just have to remember if I can order those through anywhere but the dealers.
Old June 27th, 2013, 07:03 AM   #9
Aggrotech
Aggrotech's Avatar
yeah its molded just like that, it isnt a normal wellnut with an O-ring attached separately , its built INTO the wellnut. the entire wellnut is also smaller then ur standard m5's by maybe a quarter, if not a little more.
Ive also tried my dealership and they had no idea wtf i was talking about.
Old June 27th, 2013, 07:59 AM   #10
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
That picture has no molded o-ring.
Now that I think about it the only ones I've seen that have a molded bulge are always ones I've removed from a Yamaha as OEM I always figured after a few months being compressed like that it stays like that. Kinda like your mom used to say when you'd make a funny face
If you just need short nuts then the Lockhart ones are only 10mm long that's only 3/8 of and inch so its very short. The only other thing I can think of is going to a Yamaha dealer and asking for part # 90179-05523-00 that's the well but off an R1 and if I've ever come across one with a molded bulge it would probably be off a Yamaha.
Sorry I'm not more help but I swear the I have normal nuts that look just like your first pic after they've been used and sitting out years later. Ill keep looking and let you know if I find what your looking for.
Old June 27th, 2013, 08:06 AM   #11
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Ok so I found the c-550 but it says its 14.2 mm long when new uncompressed. Here the website with the detailed chart but you may have to call them up to order since I can't find a buy button. I still say buy the Lockhart 10mm since they're shorter.
http://www.thread-rite.com/pop_nuts/...t_standard.htm
Old June 27th, 2013, 09:17 AM   #12
Aggrotech
Aggrotech's Avatar
The standard M5's shown in post 9 are just an example. They will compress in the middle exactly like the pic i showed in post 7 . If that was the case though and they got "stuck" that way after a long period of time, wouldnt the inside of the wellnut be deformed or look different in some way? I ended up taking them off and got some better pics.
These also feel stronger all around, were much harder to bend and install compared to the ones i posted in post 9
that looks too perfect to be caused by just tightening right?
Old June 27th, 2013, 09:29 AM   #13
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Time and age make them harder(tougher) plus some brands will use a slightly higher quality rubber then others. Those last pics look like normal well nuts that are permanently deformed.
And no the centers will look normal because the bolt was in there keeping the centers round shape.
Old June 27th, 2013, 09:51 AM   #14
Aggrotech
Aggrotech's Avatar
I have another spot on my bike that has ur traditional m5 wellnut, unscrewed the bolt and looked at the wellnut. Yeah it was compressed, very similar to the pics, but once i got the bolt off it went right back to normal and that wellnut has been in that same position for the passed 7-8months or so.
Either thats the case and the ones in the pics are stuck that way or we'll never find out what they really are o.o
Old June 27th, 2013, 10:15 AM   #15
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Maybe some rebound better then others may sun exposure has an effect.
Must the 9th wonder of the world
Old June 27th, 2013, 11:30 AM   #16
verboten1
verboten1's Avatar
MOTM - June '15
they are most likely designed to deform in a certain manner as well
Ride more, worry less.
[visordown.com] - The £550,000 motorcycle Ninjette Newsbot Motorcycling News 0 September 17th, 2013 12:50 PM
Honda CB550 CB 550 Four - 1975 & 1976 - $1100 (San Jose, CA) altomista Motorcycle-related 2 October 6th, 2009 04:58 PM
[topix.net] - Biker Reviews: Garmin Zumo 550 Motorcycle GPS Receiver | 65 Deals Ninjette Newsbot Motorcycling News 0 May 22nd, 2009 07:40 PM
[hell for leather] - 2009 Aprilia RXV 450, 550 tweaked for competition Ninjette Newsbot Motorcycling News 0 August 7th, 2008 05:24 AM
[roadracingworld.com] - Three Ride For Kids Events Over The Weekend Raised Over $550, Ninjette Newsbot Motorcycling News 0 July 21st, 2008 07:11 PM
