#1 |
CBR250R Traitor
Join Date: Jun 2011 Motorcycle(s): 2011 Red CBR250R 2009 Ninja 250r SE(With 2008 Fairings)(sold) Posts: 924
BRT TIS 87 Octane
Just got a BRT TIS used. I was just too annoyed with the RPM fluctuations in the heat. Install was quick and a breeze. I've attached the map controller to my left handlebar and have it set to 'ON'. From what I read here this is the less aggressive map #1, correct? My question, firstly is this map #1, and secondly is it ok to run 87 in there? I haven't heard any knocking since putting it in, I'd rather stick with 87 if I can, though not if the advanced timing is going to cause engine damage:
![]() (I'm a commuter and don't wanna shove premium in there all the time because I'm a cheapo college student ![]() |
#2 |
"ON" is in fact map #1 and yes it is safe to run 87 octane with that map.
09 250R SE: Paying it forward one post at a time! ![]() ![]() ![]() |
#3 |
Have you noticed any improvement in performance os is map #1 the normal setting?
#4 |
CBR250R Traitor
Yeah, I have, mostly in the top end though. Seems to pull from 70-90 faster than before. I'm going to have my friend who also has a 250 give me his opinion on it too.
#5 |
Join Date: Oct 2009 Motorcycle(s): '09 zx6r Green/Black, (ex-)Diablo Black '09 Ninja 250r Posts: 959
I haven't noticed any "butt-dyno" difference with map #1, maybe a smoother power curve. - still haven't hooked up the map button, so no idea about map #2. Anyone have an opinion on map 2?
#6 | |
Map #2 (running 93 fuel) does seem to have some noticeable differences. Bike seems to accelerate harder and faster. Throttle response seems a bit better and the bike pulls to 14k with little effort. ![]()
#7 | |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
Is the programmable version really worth it?
----> My Youtube! <---- Unregistered, watch my youtube page! ![]() |
#8 |
IMHO... not for street use. If you have plans for engine work or maybe NOS then a prograable unit would be the proper choice. I'm pretty sure the timing settings on the preprogramed model is already as efficient as possible.
#9 |
KThanksBye
Hmmm, nos sounds good
![]() one day I'll stop buying stuff for this bike lol
#10 |
CBR250R Traitor
I'm going to try out map #2, when I'm not cheap enough to put in 93
#11 |
ModMy250.com
Not sure where you live but premium is only 20 cents more/ gallon here. Even at a 4 gal fill up, it's an extra $.80. That's cheaper than a cheeseburger. Unless you're living on stale cereal and water, you may not even notice the difference. The extra bump in power is worth it to me. Keep in mind my bike is jetted and needles shimmed, which also makes a difference.
#12 | |
CBR250R Traitor
![]() I'm not shimmed though, I guess I'll see if there's a difference or not next fill-up. I've been meaning to shim this past month, but I've been way too busy/lazy to pull out the fairings and fuel tank. |
#13 |
anyone know if a BRT tis would work on a pregen? I know some members have used a pregen cdi to correct the newgen rpm indicator issues. does it would both ways?
#14 |
ModMy250.com
The pregen's CDI has more advanced timing on it's ignition than the new gen. Unless you need something programmable, I don't think it's necessary. Other than that, I'm sure if you rewired the bike, it could be used.
Thinking of buy a brt Tis? | kittyslasher | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 1st, 2013 07:07 PM |
BRT TIS troubles | hoodadooda | 2008 - 2012 Ninja 250R Tech Talk | 54 | May 25th, 2013 08:16 PM |
FS: Sportisi BRT TIS (nonprogrammable) | staulkor | Motorcycle-related | 1 | May 11th, 2013 10:38 AM |
Shimming or BRT TIS? | tjb0012 | 2008 - 2012 Ninja 250R Tech Talk | 14 | April 26th, 2011 02:30 PM |
BRT TIS is Finally here | ztrack157 | Motorcycle-related | 20 | July 10th, 2009 12:10 AM |
