February 20th, 2014, 08:37 AM | #1 |
Are you sure about that?
Name: That's "Sir" to you!
Join Date: Sep 2012 Motorcycle(s): Ninja 250R-F16, Versys KLE650 CAF Posts: 418
Clutch Cable Snapped
I've had clutch cables snap on me in the past. It's always been a relatively benign experience. One minute you're happily riding along, shifting up or down, then 'clunk', no clutch. It's usually a nuisance because chances are you're not close to home so now you have to either; ride home without a clutch, stop and call a recovery service, stop and call a friend with a truck. None of them are great options and the first is a definite no-no for an inexperienced rider. But, it's just a nuisance ... that's all.
Well, this last weekend the clutch snapped on me just as I was approaching a fast bend and I was shifting from 4 down to 3 and getting ready to wind-up the throttle. What a mess. The bike jumped into third, the rear wheel skipped, the engine whined, I got unbalanced, I straightened for a split second thinking "oh s***", I saw the other side of the road approaching and managed to recover fast enough to pull more lean angle and wind up the throttle, and made it round the corner. Whew! But ... it was close. Next time you're out burning up the road give a little thought to mechanical issues on your bike. Don't ride at 100%. Leave 1% for the little things that go wrong from time to time. |
February 20th, 2014, 08:47 AM | #2 |
#squid
Join Date: Jul 2011 Motorcycle(s): Track dedicated 2008 ZX6R Posts: A lot.
MOTM - Jul '16
Mine snapped while parking at work. I got lucky. I however had to ride the bike home, took over 45 minutes longer than it usually did. Glad you saved it!
February 20th, 2014, 09:40 AM | #3 |
Certified looney toon
MOTM Jul '13, Jul '14
I've heard a trick for some long long distance riders that they zip tie a second clutch and throttle cables into place so if they do have a break, all they do is swap out the ends. Half tempted to do that but wasn't sure how common a fault that is.
Might rethink that belief now...
February 20th, 2014, 10:43 AM | #4 | |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
Ive always just waited for stuff to go wrong then deal with it lol -glad you saved it ... I have had close calls but none with a clutch cable yet/
LIFE IS NOT FOR REGRETS OR EXCUSES. Breath deep, seek peace. Embrace the Madness. Life is good, let it be |
February 20th, 2014, 11:21 AM | #5 |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
Thanks for such a great reminder! One correction though. When you're riding on the road, leave a much larger margin than 1% for the little (and not-so-little) things that go wrong from time to time. A solid safety margin for the street is riding at about 60% and leaving 40% in reserve for the myriad of possibilities of things that could (and will) go wrong.
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
February 20th, 2014, 12:38 PM | #6 | |
#squid
MOTM - Jul '16
February 20th, 2014, 06:19 PM | #7 |
Join Date: Jan 2014 Motorcycle(s): 2009 Ninja 250R (Sold), 2007 SV650S Posts: 161
dang a '12 ninja cable snapped? that's like only a few years old..
i lubed mine the other day just for peace of mind. some black stuff came out the other end. must be the sheath material wearing away inside. |
February 20th, 2014, 06:49 PM | #8 |
Intrepid Adventurer
black stuff.... probably corrosion I would think
Ridding the street hold back ridding the track leave 1% racing competitively - hold nothing back guts and glory
February 20th, 2014, 06:55 PM | #9 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
So it's OK to lube the Ninjette cable itself? BMWs have had teflon-lined cable jackets for the las 30 years, so we only oil the drums on the ends of the cables, as lube will gunk up the cable-to-jacket interface.
February 20th, 2014, 08:11 PM | #10 | ||
You will note damage way earlier than any snap, as the recommended gap will become slowly bigger. All you need is to clean, to inspect and to apply lubricant at the intervals recommended by the factory. Molly grease should go into all the articulations of the levers (yes, upper and lower) and cable's barrels. Quote:
Any light lubricant (oil or lithium or Teflon) help with reducing friction and preventing corrosion due to water intrusion.
February 20th, 2014, 08:51 PM | #11 |
#squid
MOTM - Jul '16
I use PJ1
February 21st, 2014, 09:09 PM | #12 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
I've replaced the clutch cables for both of my bikes and have been religiously lubing them every 1,000 miles. I definitely noticed the cable fraying based on the feel of the clutch and the engagement point/friction zone before any actual snapping occurred.
February 22nd, 2014, 06:29 PM | #13 |
MSF Coach!
Join Date: Jun 2012 Motorcycle(s): 2003 ninja 250 Posts: 886
good job! mine snapped once in 5th shifting down on the interstate merging. i like the idea about zipping the spare on.
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35 |
Throttle Cable Snapped while on Interstate | SafetyPaws | 2008 - 2012 Ninja 250R Tech Talk | 17 | July 21st, 2014 11:43 AM |
Clutch snapped | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 19 | June 21st, 2013 05:03 PM |
Clutch cable snapped. | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 6 | November 17th, 2012 02:46 PM |
Clutch cable snapped today... | jdoucet93 | 2008 - 2012 Ninja 250R Tech Talk | 24 | December 18th, 2011 03:39 PM |
2008 model clutch cable snapped @ 17,800 miles. Replacement? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 9 | December 14th, 2010 05:40 PM |
