July 5th, 2012, 09:52 AM | #1 |
Join Date: Apr 2012 Motorcycle(s): 650r 2009 Vulcan 800 2005 Posts: 557
Bugger! Sena wet
My sena headset got a sticky stuff on it, perhaps tree sap, so I popped it off the helmet to clean. I used a damp sponge, but ended up scrubbing so hard that I not only rubbed the rubber cover open, but also squeezed water out of the sponge. In the end, the little red light stays on all the time dimly but the unit seems to work fine. In the end, I've placed it in a ziplock bag full of rice to absorb the moisture. This unit is the brand new one that I just bought, if this sort of thing had to happen, I wish it would have happened to one of my older non-upgradable units. cest la vie.
It's all about the curves. If you ride, you understand. If you have a stick skinny g/f and ride, you're 1/2 way there. |
July 5th, 2012, 09:57 AM | #2 |
probably too late now, but next time any water hits it or anything electronic...Take it apart and let it air dry 12-24 hrs.
If any moisture is left, when powered on, it can short out a light or component completely. I've had to recover laptops from lakes (car crash, no clue how car ended up in lake 500ft away from road) anyway, it worked fine after proper drying. |
July 6th, 2012, 06:59 AM | #3 |
After a few days in the rice, the red LED was still glowing dimly (incorrect behavior). I found my tiny torx drivers and broke it open. There was crud near the USB jack where the water from my sponge entered. I removed the battery and doused the PCB with isopropyl alcohol and distilled water. When it dried this morning, the crud had simply moved to a new place on the circuit board. I've taken it to work with me today and sprayed with electrical contact cleaner and it's drying now. We'll see.
Folks if you wet your electronics, take it apart and remove battery ASAP and rinse the circuit board with distilled water before it dries. Must be distilled water because it has no conductive minerals in it and is an insulator. Once the salts and/or sugars dry on your stuff, it's hard to get all of it off.
Looking for Sena group buy | fixxervi6 | Items Wanted | 0 | September 11th, 2012 07:19 PM |
[superbikeplanet.com] - Wet. Wet. Wet. Honda's Pedrosa Again Fastest In Third Practic | Ninjette Newsbot | Motorcycling News | 0 | April 28th, 2012 02:31 AM |
[kropotkin thinks...] - 2012 WSBK Assen QP2: Wet, wet, wet | Ninjette Newsbot | Motorcycling News | 0 | April 21st, 2012 02:50 AM |
[motorcyclistonline] - Riding On Wet Pavement - Slippery When Wet - Street Savvy | Ninjette Newsbot | Motorcycling News | 0 | November 14th, 2009 04:10 PM |
[roadracingworld.com] - Westby Fastest In Wet/Drying/Wet Daytona SportBike Practice A | Ninjette Newsbot | Motorcycling News | 0 | March 22nd, 2009 10:21 AM |
