Old May 10th, 2011, 09:43 PM   #1
areifel
areifel's Avatar
Rear-Alert Problem
As some of you are familiar with the nocutmodulator on our 250's. Mine seemed to have stopped working tonight after a short ride to the other side of town. I recently washed my bike last week and have not noticed any problems. More than likely due to the fact that i do not look at my rear brake while riding. i tried unplugging the unit and re-installing but no luck.
any suggestions?
areifel is offline   Reply With Quote
Old May 11th, 2011, 01:30 AM   #2
Is the bulb itself still good?
Old May 11th, 2011, 01:49 AM   #3
if the bulb checks out, inspect that the rear brake light switch is adjusted properly. it's located down next to the rear brake pedal.
Old May 11th, 2011, 05:31 AM   #4
bp328i
bp328i's Avatar
Motorcycle(s): 2010 Ninja 250
First thing I would do would be to disconnect the nocutmodulator and see if the break light still works. If it does then you know the nocutmodulator has gone bad (or at least part of it) and replace it.
bp328i is offline   Reply With Quote
Old May 11th, 2011, 04:33 PM   #5
areifel
areifel's Avatar
Yeah, the bulb works perfectly guys. i contacted the supplier and they are letting me swap it out for a new one. Apparently there was a resistor problem in a batch of 200. But, thanks anyways!
Just installed new gen rear wheel, brake problem? Zombarian 1986 - 2007 Ninja 250R Tech Talk 6 August 2nd, 2014 09:26 PM
Rear Brake Problem RandomPhantom 2008 - 2012 Ninja 250R Tech Talk 11 July 11th, 2014 05:10 AM
Rear light problem? azimmer11 2008 - 2012 Ninja 250R Tech Talk 5 August 14th, 2013 10:15 AM
rear brake problem after 600 miles maintenance tac12345 2008 - 2012 Ninja 250R Tech Talk 3 June 25th, 2010 02:45 PM
Dude are you freakin serious? Rear brake problem. Tentil3 1986 - 2007 Ninja 250R Tech Talk 5 September 30th, 2009 10:54 AM
