January 21st, 2010, 08:19 AM | #1 |
Join Date: Nov 2009 Motorcycle(s): 300, WeeStrom Posts: A lot.
Errr...can we torque ?
The DIY forum is so well done that I've decided to start wrenching.
And my first purchase will be a torque wrench. Webbike world writes up the Precision Instruments C2R100F as it's current fave...OK. Located it at Mechanics Tool Supply for $127.99+ freight. The question is...given that I have metric sockets that are 1/4, 3/8 and a few 1/2 drives...will using a drive adaptor cause inaccurate readings on the wrench. The C2R100F is avail in 3/8 and 1/2...I have craftsman sockets and adaptors. Also...I've seen torque values expressed in inch pounds as well as foot pounds....is there a formula to convert to foot pounds ? Thank you in advance eddie K |
January 21st, 2010, 09:08 AM | #2 |
Fighting Texas Aggie '05
just multiply by 12 for inch to ft lbs. the extensions and adaptors should not invalidate your readings - the good thing about having multiple sizes are the ranges
January 21st, 2010, 09:39 AM | #3 |
thanks SN
...better to ask a dumb question than make a dumb mistake...so if the book says 120 inch pounds....that's 10 foot pounds ?
Ran across a DIY calling for 94 inch pounds,,,I guess ...set the wrench @ 8lbs |
January 21st, 2010, 09:48 AM | #4 |
indeed
January 21st, 2010, 10:31 AM | #5 |
Just be aware that torque wrenches get very finicky about reading correctly/clicking at the low end of their respective scales. My 3/8" drive wrench is kinda "iffy" at 8ft/lbs, so I use a 1/4" drive wrench in inch pounds for those low values.
While getting a good wrench is important, I went with 3 cheapy wrenches that covered all my bases from Harbor Freight. The main thing is to use the wrenches as opposed to not using one and guessing at how tight things should be. Even a cheapy wrench will get you close to the correct value, if not right on. |
January 21st, 2010, 11:12 AM | #6 |
KK...good strategy for an experiened mechanic. I can get 3 HF wrenches for 1/2 the price of the C2r100F. Yet, I have no experience. Quick check of HF Pittsburgh T wrenches on other forums yielded little positive comments.
I believe I will go with the $127 wrench, use drive adaptors and maybe spring for the HF 1/4" inch-pound wrench. Noobies like me tend to buy too many tools too soon and i don't want to buy stuff till I need it AND feel competent to use them. |
January 21st, 2010, 12:51 PM | #7 | |
January 21st, 2010, 01:33 PM | #8 | |
I have a 1/2 and 3/8 torque wrench. A combination of both will be just enough for what you need to do on this bike. |
January 21st, 2010, 07:42 PM | #9 |
I have a 1/4, 3/8, and 1/2" wrenches. They were not terribly expensive. They also get used a lot. Remember to slacken them up after you use them (Return to Zero). Definitely a wise choice if you plan on wrenching.
January 21st, 2010, 07:49 PM | #10 |
took some good advice
Followed KK's and SA leads...Harbor Fr in 1/4, 3/8, 1/2...er..what size is the axle nut...yeah, checked...only have PART of a craftsman set in the garage
thanks for help guys, maybe i'll post pics of my bleeding knuckles in a week or so |
torque | skip | 2008 - 2012 Ninja 250R Tech Talk | 7 | May 22nd, 2014 02:55 PM |
What is Torque and Horsepower? | Sungfooo | General Motorcycling Discussion | 105 | May 2nd, 2012 08:11 PM |
Torque Wrench | koenigcitizen | 2008 - 2012 Ninja 250R Tech Talk | 16 | October 16th, 2011 08:11 AM |
Torque Wrench | JLinde1339 | 1986 - 2007 Ninja 250R Tech Talk | 16 | September 18th, 2011 05:40 PM |
torque wrench | tinng321 | Off-Topic | 2 | June 28th, 2010 02:31 PM |
