November 22nd, 2010, 07:54 AM | #1 |
Join Date: Oct 2010 Motorcycle(s): 2005 Blue/Orange Ninja 250 Posts: 27
Pulsing, rubbing noise - front brake?
I went for a nice ride yesterday - probably the last really nice day of the year here. It was the first time I've really been able to get it out and stretch its legs since purchasing it. (2005, with ~3500 miles) I was pushing it harder and sustaining some higher speeds than my usual commute to work. Nothing crazy, just some nice open road riding and lake sight-seeing.
I starting hearing a noise I hadn't noticed before. It was kind of a pulsing, wha wha wha wha sound. I pulled over at one point and checked everything over and couldn't find anything wrong. The bike was running great and felt fine, so I continued to ride. The noise continued the whole time. It was mostly noticeable starting at around 40 to 50 mph, and much more so when I would pull the clutch and coast, probably because the engine would get quieter. When I got home I thought to put it up on the center stand and rotate the front wheel. I can hear the front brake rubbing a little at a certain point during the rotation. Seems likely that this is my noise. Has anyone else experienced this, and what is the solution? Thanks! |
November 22nd, 2010, 08:14 AM | #2 |
Join Date: Jun 2010 Motorcycle(s): 2008 ninja 250 Posts: 168
Same thing happened to me on my 08' I wore the brake pads down to the metal. check the pads and if thats not it you might have a warped rotor, check if your rotor is straight.
Colin #191 - Area P, Elka Shock, Woodcraft Clip-Ons and Rearsets, Attack Race Bodywork, BT 003RS, .700 Fork Springs, DynoJet Stage 2 and BMC High Flow Air Filter. 613 MOTORSPORTS.COM |
November 26th, 2010, 08:33 PM | #3 |
Join Date: Sep 2010 Motorcycle(s): 05 Ninjette Posts: 131
Hmm not sure what's up ccampbell. At the moment I'm a noob so I usually ask the questions .
Separately, I've been hearing a whiisssssssshhh sound at higher speeds in 5th and 6th gears when accelerating. Maybe it's related? |
November 28th, 2010, 06:53 AM | #4 | |
Livin' the Minimoto Life
Join Date: Mar 2009 Motorcycle(s): 2022 Honda Navi, 2018 Z-125 Pro Posts: A lot.
Just take a straight edge, ruler or whatever, and check along the rotor at different points. If the rotor is gone, might as well change pads while you are at it.
--- My IG Page --- My FB page! --- 2022 Honda Navi && 2018 Z-125 Pro |
Front Brake, Rotor bolts rubbing, '07 250 | gonzo | 1986 - 2007 Ninja 250R Tech Talk | 7 | July 6th, 2014 01:57 PM |
Danmoto Jisu rubbing on brake line. | wicked300z | 2008 - 2012 Ninja 250R Tech Talk | 11 | May 6th, 2012 07:46 PM |
Rubbing / chaffing noise | Redsvt | 2008 - 2012 Ninja 250R Tech Talk | 3 | February 27th, 2012 06:03 PM |
Pulsing front brake | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 36 | April 18th, 2011 08:51 PM |
Noise from front wheel | sherbear | 2008 - 2012 Ninja 250R Tech Talk | 3 | May 19th, 2009 09:48 PM |
