Old April 30th, 2016, 07:49 AM   #1
Catchandrun
Motorcycle(s): 02 ninja 250
02ninja 250 stalls when coming to a stop or when reving in neutral
Is it just the idle? I've cleaned the carbs and the the jets and there has been no change except now it's leaking a little gas at the top end of the petcock to carb tube. I would change the plugs but I've lost my plug wrench and I really don't think it's the plugs anyways but Idk. Also when I took the carbs off the first time I noticed that my air filter wasn't even connected to the carb could this cause any problems? Lastly the rpms seem to stick just a tad when going down from time to time. All help is greatly appreciated.
Catchandrun is offline   Reply With Quote
Old April 30th, 2016, 12:11 PM   #2
Ghostt
Ghostt's Avatar
Make sure the airbox, and cylinder boots are properly installed.
What is the idle currently set @?
Have you done a valve adjustment? Or checked them?
Where exactly is the fuel leak? If you petcock is bad, it could be sucking fuel thru the vacuum line.
Test the petcock, if it bad, order a new one.
violente et ignorantia
ZX-2R BLOG
Old April 30th, 2016, 01:44 PM   #3
Catchandrun
The airbox and boots are good the idle is @1300-1500 it like to bounce a little. the peacock is,good but it,seems when the fuel goes to,the carb from the tube it's,overflowing just a little from the top of,the tube where it meets the peacock not to big a deal I think because it's only a couple drops when I first start it up after,that its,good, but I thought that could of been a symptom of the bigger problem I'm having
Old April 30th, 2016, 01:45 PM   #4
Catchandrun
Also no valve check or adjustment when and y though, would I have to do this
Old April 30th, 2016, 03:57 PM   #5
VaFish
VaFish's Avatar
MOTM - Jan '16
It's a routine maintenance item every 6000 miles.
Old April 30th, 2016, 06:23 PM   #6
Ghostt
Ghostt's Avatar
Okay fuel leaking is always a big deal! Find it, and fix it ASAP, for your own safety at the very least.
I'm sure the others will agree.
Valves out of adjustment will effect idle, and performance. It's one of the most overlooked service items.
ZX-2R BLOG
Old April 30th, 2016, 08:04 PM   #7
........ the idle is @1300-1500.......
Welcome, Greg !!!
Simplest thing is to increase that idle rpm's some, like 1.6 to 1.8 K rpm.
Did you clean the idle circuit in the carburetors?
New o-rings for the needle valves?
Old May 1st, 2016, 09:50 AM   #8
Catchandrun
So I just put the idle up to around 1800-2000 is that too high? But anyways that didn't help it at all. It seems to run perfectly fine now at idle and while riding except I can tell when it is about to die when I'm riding because there is a short stutter in the throttle while I'm riding and I know if I stop the bike will shut off. Also idkI if this changes anything for the valves but it only has 2500 miles on it so please let me know on that. I didn't check the orings for the idle screws but I took them out and soaked them with carb cleaner and sprayed cleaner all the holes where they screw in. I really don't want to take the carbs back off unless I have to. so do I have to check the orings first? Also when the bike shuts off it won't start for about 10 mins and only will run with the choke on until I ride for a couple mins idk of that helps but I guess it doesn't hurt btw too the idle screws are set to what they were for the past 2 years before the bike ever had this problem
Old May 1st, 2016, 09:51 AM   #9
Catchandrun
The needle valves are the idle screws right?
Old May 1st, 2016, 05:19 PM   #10
Yes.
So I just put the idle up to around 1800-2000 is that too high? But anyways that didn't help it at all. It seems to run perfectly fine now at idle and while riding except I can tell when it is about to die when I'm riding because there is a short stutter in the throttle while I'm riding and I know if I stop the bike will shut off............ Also when the bike shuts off it won't start for about 10 mins and only will run with the choke on until I ride for a couple mins........
I don't know if your problem could be electrical or just improperly cleaned carburetor or fuel delivery.
The intermittent way in which it shows up makes me think that it is more the other two than carburetor related.
For electrical: Check all the connections of the battery and the two spark coils and wires-boots.
For fuel delivery: Check that the cap of the gas tank is letting air flow in and that the vacuum hose to the petcock is not leaking air in.
Now, you can reduce the idle rpm's to normal, since 2K is not doing anything to avoid stalls.
Old May 1st, 2016, 05:29 PM   #11
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Carb vent hose sounds plugged or pinched to me....hence the waiting 20 minutes and having to run on choke.
Low fuel in the bowls.
Or petcock....or vacuum hose to the petcock has a leak.
Goin' fast on slow bikes!
Old May 1st, 2016, 07:35 PM   #12
Ghostt
Ghostt's Avatar
Tank vent ?
ZX-2R BLOG
Old May 1st, 2016, 08:28 PM   #13
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Tank vent ?
Yeah, this one too!
Old May 2nd, 2016, 12:34 PM   #14
Catchandrun
Thanks for help everyone i probably should of mentioned this earlier but I had to buy a new gas cap (off eBay from china) so where would the tank vent be? Also where is the carb vacumn hose
Old May 2nd, 2016, 12:35 PM   #15
Catchandrun
Sorry I meant carb vent hose?
Old May 2nd, 2016, 12:39 PM   #16
RacinNinja
Vintage Screwball
RacinNinja's Avatar
MOTM - Mar '16
Tank vent is in the gas cap.
Easy test. Loosen the gas cap after it dies....if you hear a hissing sound, the gas cap isn't venting properly and creating a vacuum, restricting fuel flow.
Old May 2nd, 2016, 12:41 PM   #17
Ghostt
Ghostt's Avatar
The OEM gas cap has diaphragm vent, most aftermarket ones don't have a vent, so the tank doesn't vent, and gas can't flow.
To verify this try loosen the cap, or just open it, allowing the air back into the tank, if the bike starts and it's okay, you found your problem maybe.
Here's my write-up on the vent issue
Sounds like it could be a venting issue, no worries it's a free and easy fix,
You need you to disassemble the gas cap and remove the two small red diaphragms, assuming this is your only problem.
The diaphragm gets hard and losses it's flexibility and gets stuck, and doesn't allow proper venting.
IMHO this modification should be done regardless to prevent future problems whatsoever.
They are ment to vent the tank, but in the case of an accident not allow gas to leak out, but more often cause problems then they fix.
Here are some pictures to help you.
The plastic piece houses the two small red diaphragm pieces, this one being mine, they are already gone, and you can leave the plastic piece out all together, as I'm going to do now.
Some things to watch out for are, there are 5 small springs under the round collar, and a small round collar as well on the locking mechanism, don't lose any of them.
Good luck.
ZX-2R BLOG
Old May 2nd, 2016, 12:42 PM   #18
Catchandrun
Also I cleaned the carbs very good the only thing it could be regarding the carb is the float bowls because all jets were cleaned to perfection but I didn't touch the float bowls. Would the bowls cause this problem? How do I check to see if the carb vac hose has an air leak.
Ninja 250 stalls when giving throttle ji0315tafeng 2008 - 2012 Ninja 250R Tech Talk 4 August 24th, 2015 10:43 AM
Which foot do you put down when you're coming to a stop? Mr.E Riding Skills 96 May 22nd, 2014 08:32 AM
2011 Ninja 250 stalls when given too much gas GregoryC4 2008 - 2012 Ninja 250R Tech Talk 15 April 1st, 2014 09:45 AM
Engine quits while reving in neutral spawned4562 2008 - 2012 Ninja 250R Tech Talk 10 November 15th, 2012 08:44 PM
Shifting to neutral when at a stop. Kitdog Riding Skills 55 October 28th, 2010 10:20 AM
