May 6th, 2012, 09:38 AM | #1 |
Join Date: Mar 2011 Motorcycle(s): 09 Ninja 250r Posts: 634
What grit to use to sand fairings for painting?
Just curious what number of coarse grit I should be using to sand off all paint for prep and then which finer one should I use to smooth out all the imperfections?
May 6th, 2012, 09:47 AM | #2 |
Join Date: Mar 2012 Motorcycle(s): 2009 Ninja 250 Posts: 127
Depends on how bad your scratches are... I started off with 80 then did 120 then 220.
May 6th, 2012, 10:25 AM | #3 |
scratches aren't too bad, I can only see the black plastic through the paint in some areas, I'm concerned with fixing the cracks...
Did the 220 result in a baby bottom smooth finish? Also did you use a power sander or by hand? What was the end result like? |
May 6th, 2012, 06:37 PM | #4 |
Join Date: Jul 2011 Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636 Posts: 661
All of the paint does not have to be removed, only scuffed enough for adherance.
Areas around imperfections should be taken down to base layer completely. All body work is 90% prep work, 10% paint skill. Work progressively finer grit during the process. A quality primer can fill minor imperfections. For a smooth finish you are looking at 1200 - 2000 grit wet sanding. |
May 6th, 2012, 08:41 PM | #5 |
D. Not enough information provided to solve problem
May 7th, 2012, 04:10 AM | #6 |
Leave the original paint intact whenever possible, just scuff it until completely dull with a gray Scotchbrite pad. Wherever you've done repair work sand with 320 before spraying adhesion promoter and then sandable build primer. Wetsand with 400 using guidecoat if necessary, wipe everything down and you're ready to spray.
Painting Fairings | onetruevibe | 2008 - 2012 Ninja 250R Tech Talk | 35 | July 15th, 2012 12:54 PM |
[crash.net - MotoGP] - Rossi: I'll have to grit my teeth at Jerez | Ninjette Newsbot | Motorcycling News | 0 | March 30th, 2011 12:50 AM |
[visordown.com] - Grit in throttle caused fatal bike crash | Ninjette Newsbot | Motorcycling News | 0 | March 22nd, 2010 05:30 AM |
Replacement Fairings and Painting | kevlarorc | 2008 - 2012 Ninja 250R Tech Talk | 17 | January 21st, 2010 11:44 PM |
[crash.net - MotoGP] - Vermeulen to 'grit teeth and carry on'. | Ninjette Newsbot | Motorcycling News | 0 | July 17th, 2009 09:40 AM |
