Old March 4th, 2012, 08:01 PM   #441
ProdigyRacingLA
ProdigyRacingLA's Avatar
Motorcycle(s): 2008 Ninja 250r Red
Talking what kind of gas do you pump?
When I first got the bike, used regular unleaded gasoline. After that been using premium gasoline. Top of the line chevron.
Which do you recommend or use?
Thnx for reading!
ProdigyRacingLA is offline   Reply With Quote
Old March 4th, 2012, 08:01 PM   #442
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Manual says to use 87 octane 91 RON.
Old March 4th, 2012, 08:03 PM   #443
ProdigyRacingLA
Thnx bro!
Now to check and see if I've been damaging the engine with different gasoline's. xD
Old March 4th, 2012, 08:05 PM   #444
MikeBudd
MikeBudd's Avatar
Motorcycle(s): RED 2010 Ninja 250r
Very debated topic. There was a video floating around that explained octane's and showed why you should use the manufacturer recommended which for the 250's is 87 or 91 ron
As long as your engine is not pinging, you should be fine :O
MikeBudd is offline   Reply With Quote
Old March 4th, 2012, 08:15 PM   #445
ProdigyRacingLA
Just checked and ive been pumping the correct gasoline. It's premium 91.
Getting better mileage and performance out of higher octane gasoline.
The first time I pumped it, my buddy said I had a little backfire come out of the exhaust. That I shouldn't be worries due to the gasoline I pumped that caused it. Runs just fine, 4 months strong ridden daily.
Old March 4th, 2012, 08:17 PM   #446
No. All gen's of the ninja 250 are spec'd for 87 fuel.
/merged with main octane thread
Old March 4th, 2012, 08:23 PM   #447
MikeBudd
MikeBudd's Avatar
What he said^
I told you in my above post (so did nick)... Its 91 RON. 87 Octane.
Old March 4th, 2012, 08:28 PM   #448
ProdigyRacingLA
Well thanks guys, ill be sure to make the switch to 87.
Hopefully no major damage has been done :/
Sorry for the confusion
Old March 4th, 2012, 08:30 PM   #449
MikeBudd
MikeBudd's Avatar
Shouldn't have done any major damage. (don't quote me on that )
Old March 4th, 2012, 08:30 PM   #450
Nothing to worry about. The only thing running 91 will hurt is your wallet, there's just no benefit to it on these bikes.
Old March 4th, 2012, 08:46 PM   #451
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Higher octanes are for higher compression engines (not necessarily however). Some cars use 110, but that's race fuel. A common misconception is that the fuel is cleaner, however, there isn't a big difference in that. By using a higher octane, your wasting a small amount of money each time you fill up, since that gas won't be used. The higher the octane number, the more compression the fuel can withstand before detonating. I think I wrote that correctly.
Old March 4th, 2012, 08:58 PM   #452
Because it needed to be said again in this thread?
Old March 4th, 2012, 09:42 PM   #453
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Sorry.
Old June 21st, 2012, 05:20 PM   #454
PsHYk
PsHYk's Avatar
Motorcycle(s): 2012-250R
Fuel Octane Rating
i think this is tech talk but if its not i apologize and should be moved where it should...
ok so i was wondering what octane fuel you guys use in your bike and why?
well why other than prices i use the 91 or whatever it is the most expensive one but i read somewhere...ill try to find again here in a bit...that on bikes its better to use lower octane fuel than higher octane fuel so i thought i would ask you guys...also if its better to use the lower is it bad to use the higher and vice versa? i know its probably not too much difference but again...just thought id ask...
PsHYk is offline   Reply With Quote
Old June 21st, 2012, 05:21 PM   #455
xSean13
xSean13's Avatar
87, non-ethanol. I believe the owner's manual recommends 87.
Old June 21st, 2012, 05:22 PM   #456
PsHYk
PsHYk's Avatar
oh oh...
Old June 21st, 2012, 05:24 PM   #457
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
yup 87 its in the book
THE GOOD LIFE
cuz is offline   Reply With Quote
Old June 21st, 2012, 05:27 PM   #458
PsHYk
PsHYk's Avatar
i dont remember reading that and im not saying youre lying just i actually read the manual for the most part and the safety tip book...
but cool least thatll save me some money now... =D
Old June 21st, 2012, 05:53 PM   #459
cuz
cuz
cuz's Avatar
page 33
under
General Information
Fuel Requirement:
Fuel type
THE GOOD LIFE
Old June 21st, 2012, 08:53 PM   #460
Boom King
So, where's the reverse?
Boom King's Avatar
Yup, if you're lucky to get ethanol free gas where you live. Everything is E10 around here except for Shell V-Power at selected stations. Even then, I question whether it is truly 100% ethanol free. I believe the manual states that gasoline containing up to 10% ethanol is "approved" for use.
Old June 21st, 2012, 09:25 PM   #461
Miles_Prower
One Loyal Fox
Miles_Prower's Avatar
Motorcycle(s): 2012 Ninja 250R (RIP), 2011 ZX-6R
I use regular..87. that is what the bike is rated for..!!! the supersports all need 90+ octane, but not our little ninjette. pumping anything more than that is just a waste of cash, just like in most vehicles rated for 87 (i have a friend who runs his corolla on premium..i think he's a nut lol). my fuel also has ethanol, but the dealership guy said as long as I empty the tank every week or so, it won't really cause any problems... only if you leave the ethanol gas in the tank for an extended period will it cause problems. so far, so good!
Miles_Prower is offline   Reply With Quote
Old June 22nd, 2012, 04:37 AM   #462
Old June 27th, 2012, 08:11 PM   #463
Renner
Ignoring Jiggles
Renner's Avatar
Motorcycle(s): '09 Ninja 250R, '06 Ninja 250R (Sold)
Holy Crap 12 pages on what gas to use!!!
YouTube And Facebook
http://www.youtube.com/RennerVlogs
http://www.facebook.com/RennerVlogs
Renner is offline   Reply With Quote
Old June 27th, 2012, 08:14 PM   #464
Change your posts-per-page setting in your options, and you can get it down to 5 pages.
Old June 27th, 2012, 08:17 PM   #465
headshrink
headshrink's Avatar
Do they have these ongoing discussions in car forums?
How about forums for bikes that require premium?
Old July 1st, 2012, 07:39 PM   #466
Renner
Ignoring Jiggles
Renner's Avatar
Yah but then it isn't ....it's more like I think 12 pages is more dramatic
Old July 28th, 2012, 04:48 AM   #467
akcalhoun
Motorcycle(s): 2013 honda shadow phantom
premium plus gas
does it worth?
jk, but seriously is it worth to put this in bike? will it keep the engine cleaner and perhaps last longer or am i just wasting money if i do this?
akcalhoun is offline   Reply With Quote
Old July 28th, 2012, 06:18 AM   #468
Originally Posted by akcalhoun View Post
does it worth?
Actually, it is the other way around.
Anti-detonation additives tend to create more deposits in the carbs and engine.
Regular gas is good enough for these engines, which can't benefit from the characteristics that the premium gas offers.
http://www.cartalk.com/content/premium-vs-regular-0
Old July 28th, 2012, 06:37 AM   #469
dfox
dfox's Avatar
Motorcycle(s): 08 250R
There is no benefit to running "premium" gas in an engine designed for "regular".
the designations that stations give gasoline is very misleading. They should simply stick to calling them by their octane number, because in no way is "premium" gas better than "regular" gas. It's simply different.
The higher the octane rating, the more heat/pressure is required to detonate that gasoline. This is especially important in cars/motorcycles with very high compression ratios, or cars with forced induction. By design, those vehicles have excess pressure that can cause the gasoline to prematurely detonate. Premature detonation induces "ping" and is not good for an engine, and reduces performance.
Generally speaking, for street riding, you should use the LOWEST octane rating that your engine was designed for, for the best performance.
track days, aftermarket tunes, etc. all bring in other factors that may change your desired octane, but on our bikes 87 will give you optimum performance.
If you're concerned with keeping the engine cleaner, use "top tier gasoline". You can google that term, and find a list of gasoline stores that are considered "top tier". I choose to only buy gas from these stations unless I'm in an emergency, when I only put in as much gas as I need to get me to a top tier station. They include additives that help clean out your fuel system.
dfox is offline   Reply With Quote
Old July 30th, 2012, 03:23 AM   #470
ninja250r81
ninja250r81's Avatar
Motorcycle(s): 2012 ninja 250r se
higher the octane means the fuel takes longer to burn.
so blah blah blah, the fuel will be less prone to pinging.
use the higher octane fuel in summer when the temperature gets hot
ninja250r81 is offline   Reply With Quote
Old July 30th, 2012, 05:23 AM   #471
Kawasaki recommends 87. Just use 87 unless you get knocking, then use a tank of midrange. No reason to blow extra money out your exhaust pipe.
Posted via Mobile Device
Old July 30th, 2012, 02:09 PM   #472
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
http://www.ninjette.org/forums/showthread.php?t=15904
broilmebk is offline   Reply With Quote
Old July 30th, 2012, 02:12 PM   #473
/merged
Old July 30th, 2012, 02:15 PM   #474
it means it takes more heat to ignite the fuel. it burns at the same rate. higher octane gas is made for higher compression engines that would predetonate regular gas because the heat from compression is enough to ignite the gas. causing the ping.
heres a nice explanation: http://www.rockettbrand.com/techsupp...ationships.pdf
Old July 30th, 2012, 02:29 PM   #475
broken neck
Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally
Once again,
Thanks ninjette.org...
I don't know why, but I was using 91 for mine... Maybe because it's a motocycle with a porty look, so it needed to be fed with some expensive gas...
So I'll try 87 on my next fill up...
Never thought that Ninjette could be less expensive to run...
broken neck is offline   Reply With Quote
Old July 30th, 2012, 02:40 PM   #476
nakedhunter
Motorcycle(s): 2009 Ninja 250R (RED)
I run on 91 octane simply because Costco here offers either 85 Octane or 91 Octane. no 87 octane unless I want to pay 15 cents more a gallon down the road
nakedhunter is offline   Reply With Quote
Old July 30th, 2012, 02:44 PM   #477
the greatest thing about the ninjette is how ridiculously cheap it is to own and operate
Old July 30th, 2012, 02:47 PM   #478
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Amen Alex, this bike will save you nearly $0.60 on every fillup
AFM #676
Supersports are for n00bs
Old July 30th, 2012, 03:34 PM   #479
Heffdan
Motorcycle(s): 2012 Ninja 250 SE
I once have put 100 octane in the tank.
Heffdan is offline   Reply With Quote
Old August 2nd, 2012, 02:08 AM   #480
ninja250r81
you do know 100 at united stations its e85 with 98
[topix.net] - Officials stunned as 94-year-old uses his funeral money to run for parl Ninjette Newsbot Motorcycling News 0 December 13th, 2012 08:40 AM
[topix.net] - Run with Nuns hits the streets to raise money for children Ninjette Newsbot Motorcycling News 0 October 23rd, 2011 06:40 PM
take the money and run.. greatwhiteninja Off-Topic 4 August 4th, 2011 01:49 PM
[crash.net - WSBK] - Haslam: We'll give twins run for their money Ninjette Newsbot Motorcycling News 0 April 8th, 2010 05:00 AM
[crash.net - WSBK] - Haslam: We'll the twins a run for their money! Ninjette Newsbot Motorcycling News 0 April 8th, 2010 03:30 AM
