September 12th, 2015, 12:41 AM | #1 |
[motorcycle.com] - Epic Sport-Adventure Spec Sheet Shootout
It’s a good time to be a motorcyclist. OEMs keep ratcheting up the amount of standard or optional technologies available on modern motorcycles. In just the last handful of years we’ve come to expect ABS, traction control, ride modes and slipper clutches as standard equipment. Cruise control is almost ubiquitous, and electronically adjustable suspension is gaining ground quickly. Five of the nine bikes in our Epic Sport-Adventure Shootout are equipped with semi-active suspension, one has electronically adjustable suspension, while only three are bereft of the technology. Spec sheets are useful for comparing and contrasting the attributes of various motorcycles but obviously fail to tell the whole story. For example, many of the bikes here are outfitted with cruise control, the Aprilia Caponord Rally being one of them, but after having ridden hundreds of miles on each bike we know that not all cruise controls are created equally. The Aprilia’s CC is, in fact, an abject failure in terms of user-friendliness but you’d never know just how bad it is until you have other bikes with much better systems to compare it to. So while we’re busy sorting through all the data, rider notes, images and video clips to bring you the most comprehensive sport-adventure shootout we can muster, we invite you to chew on the fat of these nine bikes by way of their specifications and available technologies. You’ll note that even the least expensive bike here, Kawasaki’s Versys 1000LT, comes equipped with ABS, TC and ride modes while the most expensive bike, Ducati’s Multistrada S, features those plus backlit switchgear, a full-color TFT display, smartphone app and Cornering-ABS. And then there’s the BMW S1000XR, the only bike in the test with a quickshifter that goes through the gears both ways, featuring auto-blipping downshifts. Yes, it is an undoubtedly good time to be a motorcyclist. Aprilia Caponord 1200 RallyBMW R1200GSBMW S1000XRDucati Multistrada 1200 SKawasaki Versys 1000 LTMSRP$15,695$17,493 (as tested)$19,887 (as tested)$21,094$12,799Engine Type1197cc Liquid-cooled, DOHC, four-stroke, V-Twin, 4 valves per cylinder1170cc Air/Liquid-cooled, DOHC, four-stroke, flat Twin, 4 valves per cylinder999cc Liquid-cooled, DOHC, inline-Four, four-stroke, 4 valves per clinder1198cc Liquid-cooled, DOHC, four-stroke, DVT V-Twin, 4 valves per cylinder1043cc Liquid-cooled, DOHC, four-stroke, inline-Four, 4 valves per cylinderBore x Stroke106.0mm x 67.8mm101.0mm x 73.0mm80.0mm x 49.7mm106.0mm x 67.9mm77.0mm x 56.0mmCompression Ratio13.6:112.5:112.0:112.5:110.3:1Rear Wheel Horsepower109.7 @ 8,500 rpm109.4 @ 7,900 rpm156.6 hp @ 11,200 rpm137.1 hp @ 9,700 rpm109.8 hp @ 8,700 rpmTorque (claimed at crankshaft)73.7 lb.-ft. @ 6,900 rpm70.5 lb.-ft. @ 6,600 rpm80.4 lb.-ft. @ 9,200 rpm84.3 lb.-ft. @ 7,900 rpm70.1 @ 7,200 rpmlb/hp5.55.43.54.15.2lb/torque8.27.46.86.78.1Transmission6-speed; multi-plate wet clutch6-speed; multi-plate wet clutch6-speed; multi-plate wet clutch w/slipper function6-speed; multi-plate wet clutch w/slipper function6-speed; multi-plate wet clutch w/slipper functionFinal DriveChainShaftChainChainChainFront SuspensionInverted 43mm fully adjustable Sachs fork. (Aprilia Dynamic Damping)Telelever, 37 mm, central spring strutInverted 46mm fully adjustable fork48mm fully adjustable usd fork. Electronic compression & rebound damping adjustment with Ducati Skyhook Suspension (DSS)KYB 43mm inverted front fork with adjustable rebound and preloadRear SuspensionAluminum swingarm, Sachs monoshock. (Aprilia Dynamic Damping)Cast aluminum single-sided swingarm with BMW EVO ParaleverMonoshock with preload adjustabilityFully adjustable with electronic compression and rebound damping adjustment, electronic spring pre-load adjustment with Ducati Skyhook Suspension (DSS)Horizontal back-link shock with adjustable rebound damping and adjustable spring preload, remote preload adjusterFront BrakeDual 320mm stainless steel floating discs, 4-piston Brembo M432 monoblock radial calipersDual 305mm rotors. Twin 4-piston calipers. Switchable ABSDual 320mm rotors. Twin radial-mount calipers.Dual 330mm semi-floating discs, radially mounted Brembo monobloc Evo M50 4-piston calipers, 2-pad, radial pump with cornering ABS as standard equipmentDual 310mm petal rotors with four-piston calipers and ABSRear BrakeSingle 240mm stainless steel disc, Brembo caliper220mm rotor. Single-piston caliper265mm rotor. Twin-piston caliper265 mm disc, 2-piston floating calliper, with cornering ABS as standard equipmentSingle 250mm petal rotor with single-piston caliper and ABSFront Tire120/70-19120/70-19120/70-17120/70-17110/80-19Rear Tire170/60-17170/60-17190/55-17190/55-17150/70-17Rake/Trail27.4 deg/4.6 in.25.5 deg / 3.9 in.25.5 deg / 4.6in.24.0 deg / 4.3 in.25.5 deg / 4.0 in.Wheelbase62.0 in.59.3 in.61.0 in.60.2 in.61.2 in.Seat Height33.1 in.33.1 in.33.1 in.32.5/33.3 in.33.4 in.Curb Weight604 lbs. (with bags)596 lbs. (with bags)550 lbs. (with bags)567 lbs. (with bags)544 lbs. (with bags)Fuel Capacity6.3 gal.5.3 gal.5.2 gal.5.3 gal.5.3 gal.Saddlebag Capacity66 liters/ 17.4 gallons65 liters/17.2 gallons62 liters/16.4 gallons58 liters/ 15.3 gallons56 liters/14.8 gallonsTested Fuel Economy (Average)33.9 mpg39.6 mpg36.9 mpg40.1 mpg37.9 mpgFull color instrument clusterXGear Position IndicatorXXXXHeated GripsXXXHeated seatHeated passenger seatHillstart controlPower accessory socketXXXXCornering lightsXWheelie ControlXBacklit handlebar switchesXABSXXXXXCornering ABSXWire-spoke wheelsXCast-aluminum wheelsXXXXElectronic suspension adjustabilityXXXXSemi-active suspensionXXXXSmartphone appXXTire pressure monitorXQuickshifterXClutchless downshift abilityXRide modesXXXXXCruise controlXXXXTraction controlXXXXX KTM 1190 AdventureKTM 1290 Super AdventureSuzuki V-Strom 1000 ABSTriumph Explorer XC ABSMSRP$17,899 (as tested)$20,499$14509 (as tested)$18,494Engine Type1195cc Liquid-cooled, DOHC, four-stroke, 75° V-Twin, 4 valves per cylinder1301cc Liquid-cooled, DOHC, four-stroke, 75° V-Twin, 4 valves per cylinder1037cc Liquid-cooled, DOHC, four-stroke, 90° V-Twin, 4 valves per cylinder1251cc Liquid-cooled, DOHC, four-stroke, Triple, 4 valves per cylinderBore x Stroke105.0mm x 69.0mm108.0mm x 71.0mm100.0mm x 66.0mm85.0mm x 71.4mmCompression Ratio12.5:113.1:111.3:1NARear Wheel Horsepower123.6 hp @ 9,500 rpm132.5 hp @ 8,400 rpm91.6 hp @ 8,000 rpm113.6 hp @ 8,700 rpmTorque77.3 lb.-ft. @ 8,000 rpm86.8 lb.-ft. @ 6,800 rpm69.1 lb.-ft. @ 9,300 rpm74.1 lb.-ft. @ 6,400 rpmlb/hp4.54.25.9tk5.3/td>lb/torque7.26.57.98.1Transmission6-speed; multi-plate wet clutch w/slipper function6-speed; multi-plate wet clutch w/slipper function6-speed; multi-plate wet clutch6-speed; multi-plate wet clutchFinal DriveChainChainChainShaftFront Suspension48mm, WP inverted fork, electronically adjustableWP Semi-active suspension USD 48 mmInvetered telescopic, coil spring, oil dampedKayaba 46 mm upside down forks, adjustable preloadRear SuspensionWP monoshock, electronically adjustableWP Semi-active Suspension PDS Monoshock“Link type, coil spring, oil damped “Kayaba monoshock with remote oil reservoir, hydraulically adjustable preload, rebound damping adjustmentFront Brake4-piston Brembo calipers, 320mm discs, ABS/C-ABS4-piston Brembo calipers, 320mm discs, ABS/C-ABSDual 310mm rotors, 4-piston Tokico calipers, ABSTwin 305 mm floating discs, Nissin four-piston calipers, Switchable ABSRear Brake2-piston Brembo caliper, 268mm disc, ABS/C-ABS2-piston Brembo caliper, 268mm disc, ABS/C-ABS260mm rotor, ABSSingle 282 mm disc, Nissin two-piston sliding caliper, Switchable ABSFront Tire120/70-19120/70-19110/80-19110/80-19Rear Tire170/60-17170/60-17150/70-17150/70-17Rake/Trail26.0 deg / 4.7 in.26 deg / 4.7 in.25.5 deg / 4.3 in.23.9 deg / 4.2 in.Wheelbase61.4 in.61.4 in.61.2 in.60.2 in.Seat Height33.8/34.4 in.33.9/34.4 in.33.4 in.32.9/33.7 in.Curb Weight554 lbs. (with bags)562 lbs. (with bags)544 lbs. (with bags)606 lbs.Fuel Capacity6.1 gal.7.9 gal.5.3 gal.5.3 gal.Saddlebag Capacity73 liters/19.3 gallons73 liters/19.3 gallons55 liters/14.4 gallons62 liters/16.4 gallonsTested Fuel Economy (Average)36.4mpg36.8 mpg37.5 mpg35.2 mpgFull color instrument clusterGear Position IndicatorXXXHeated GripsXHeated seatXHeated passenger seatXHillstart controlXPower accessory socketXXXCornering lightsXWheelie ControlBacklit handlebar switchesABSXXXXCornering ABSXXWire-spoke wheelsXXXCast-aluminum wheelsXElectronic suspension adjustabilityXXSemi-active suspensionXXSmartphone appTire pressure monitorXQuickshifterClutchless downshift abilityRide modesXXXXCruise controlXXXTraction controlXXXXEpic Sport-Adventure Spec Sheet Shootout appeared first on Motorcycle.com. Click here for full story...
[motorcycle.com] - Ultimate Sport-Touring Adventure Shootout Prologue | Ninjette Newsbot | Motorcycling News | 0 | August 31st, 2015 03:00 PM |
[RoadRUNNER] - Remembering Emilio Scotto’s Epic Motorcycle Adventure | Ninjette Newsbot | Motorcycling News | 0 | April 14th, 2015 03:10 AM |
Torque spec cheat sheet? | N_hutter | 2013 - 2017 Ninja 300 Tech Talk | 5 | December 3rd, 2014 06:59 PM |
[motorcycle.com] - Indian Scout Spec Shootout | Ninjette Newsbot | Motorcycling News | 0 | August 18th, 2014 04:00 PM |
[motorcycle.com] - 2014 Super Middleweight Sportbike Spec Shootout | Ninjette Newsbot | Motorcycling News | 0 | January 15th, 2014 10:10 PM |
