Old October 29th, 2013, 06:59 AM   #1
gkarats
gkarats's Avatar
Motorcycle(s): 08 Ninja 250r
K&N Air filter
hi guys/gals this has probably been covered more than once, but unfortuneately the search function is not working on my tablet.
I installed a k&n airfilter ka-2508. The cover did not sit flush with the airbox (until i bolted it tight), filter was sticking out just slightly? After i tightened the allen bolts it looks fine, just curious if this is normal or do i need more grease on the lip to slide it in further?
Cheers
gkarats is offline   Reply With Quote
Old October 29th, 2013, 07:47 AM   #2
DaBlue1
Long Time Rider
DaBlue1's Avatar
Improperly fitting filters have been reported more than a few times. Be careful not to over tighten the cover if the filter is not fitting properly. Bending or warping of the cover may occur. This may also cause some air to leak in too. A easy remedy is too shave a little rubber off on the ends of the filter to ensure a proper fit of the airbox cover.
Old October 29th, 2013, 07:52 AM   #3
gkarats
gkarats's Avatar
Ok im going to pull it and try a little more grease to see if that makes a difference, were talking mm here. If that fails ill try shaving some rubber off as you suggested.
Cheers
Old October 30th, 2013, 12:04 AM   #4
ninja250r81
ninja250r81's Avatar
i had to shave some rubber off with a razor blade for mine to fit
Old October 30th, 2013, 01:03 PM   #5
gkarats
gkarats's Avatar
Yeah I ended up doing the same - then got a good fit.
Old November 1st, 2013, 07:18 PM   #6
Klint
Motorcycle(s): 2009 Ninja 250R Special Edition
you may want to shim your needle with 1 washer for better performance if you notice that your bike doesn't want to stay on with a cold startup or lags at lower rpms.
Installing the filter will make the bike run a bit leaner than it already is from the factory!
I just shimmed with two washers and i have a K&n filter and Yoshi exhaust... it feels like a new bike!
2009 Kawasaki Ninja 250R Special Edition
2005 Lotus Elise Sports Pack
Klint is offline   Reply With Quote
Old November 1st, 2013, 09:04 PM   #7
abhijitz
There is a recess at the far end of the airbox. The filter has to go all the way IN to the recess. The K&N is slightly thicker than OEM, so sometimes it is usual for the filter not to fit all the way into the recess.
I have a K&N and when i service it, it usually takes 2-3 tries to get it fit into the recess. It doesnt stick out to the extent that i would have to press the cover.
[ex-AFM #828 | SMUSA #828 |
Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers
+ OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com
Ninja 300 K&N Air Filter How To Install Tutorial & Quick Review Video SON1C 2013 - 2017 Ninja 300 Tech Talk 12 June 27th, 2014 07:15 PM
[sportrider - latest stories] - K&N Air Filters Named as Official Air & Oil Filter Su Ninjette Newsbot Motorcycling News 0 June 11th, 2012 06:00 PM
Anyone have a K&N Air Filter? Machine1 2008 - 2012 Ninja 250R Tech Talk 6 June 6th, 2012 02:09 PM
