June 3rd, 2016, 09:59 PM | #1 |
91 zzr 250 fuel in the oil help
hi guys i got a major problem i seem to have a sump full of mixed fuel and oil how has the fuel got in there and how do i fix this problem when the bike runs i pisses out the left hand side near gear lever please guys how do i fix this issue ive just dropped the oil but dont want to put clean oil in till i stop the prblem can you guys help
June 3rd, 2016, 10:03 PM | #2 |
Vintage Screwball
MOTM - Mar '16
Replace/rebuild the petcock and the float valves in the carbs.
@ducatiman for parts.
Goin' fast on slow bikes! |
June 3rd, 2016, 10:13 PM | #3 |
thanks mate much appreciated been freaking thinkin me bikes was f@#ked
June 3rd, 2016, 10:18 PM | #4 | |
Vintage Screwball
MOTM - Mar '16
We know the float valves are bad because there is fuel in the oil. They are letting fuel past and not shutting off when the fuel in the bowls reaches the proper level. We know the petcock is bad because it has to be leaking with the bike off to get that much fuel in the oil, which it shouldn't because of the vacuum petcock. Easy way to test is to pull the fuel line and see if fuel comes out even with the bike off and the petcock OFF. Should be no fuel coming out EXCEPT for the PRIME position.
June 4th, 2016, 03:57 AM | #5 |
Join Date: Dec 2015 Motorcycle(s): 2008 Ninja 250 Posts: 210
^^^ this. I experienced the same problem. Easy fix as long as you are a little mechanically inclined.
June 4th, 2016, 10:01 PM | #6 |
/moved to pre-gen tech
[motorcyclistonline] - Oil Supply, Demand and Fuel Speculation | Ninjette Newsbot | Motorcycling News | 0 | December 6th, 2015 09:50 AM |
Fuel/Oil leak, only when raining? | tmf1423 | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 25th, 2014 11:57 AM |
In need of assistance - fuel / oil issues | ans008 | 2008 - 2012 Ninja 250R Tech Talk | 5 | October 26th, 2013 04:56 AM |
