April 19th, 2015, 05:24 AM | #1 |
Damage from brake fluid questions
I just got a spiffy new set of brake lines and I'm going to install them today.
Thanks to the Interwebz I've got lots of reference material and this looks like a simple job. Two questions: 1) I know that brake fluid eats paint. Question is, how fast? This job will result in spilled fluid, and I'm quite sure that no matter how many paper towels and such I lay down, contact is likely to happen. How fast do I need to be with cleanup? "OH SH*T OH SH*T SH*TSH*TSH*T" or "Ah, bugger. I'll reach for this rag right here...." 2) What should I use to clean the fluid off of painted surfaces? Brake cleaner? Formula 409? Spit? TIA....
April 19th, 2015, 05:41 AM | #2 |
I think I'd wipe it off with a paper towel first, then use 409 or something similar to clean any residue.
I don't think it will damage OEM paint or powder immediately, but it's hard to say. It will soften spray can paint and probably streak any silver metallic paint (like engine case paint) quicker. |
April 19th, 2015, 05:45 AM | #3 |
The A Team
Join Date: Aug 2012 Motorcycle(s): Z50, CB125, RZ500, MC22, R3. Posts: 394
H2o
April 19th, 2015, 06:28 AM | #4 |
Freedom for Germany
April 19th, 2015, 08:11 AM | #5 |
It isn't gunna be instant, wipe with a clean shop towel, wash with Dawn dishwashing liquid, water rinse. Should be no problem really.
April 19th, 2015, 10:39 AM | #6 |
Participant
What the other guys said.
If it's left on the paint for a while, the paint turns sticky and icky and stays that way for a long time (spilled some on a HF vice years ago). |
April 19th, 2015, 10:52 AM | #7 | |
Hope you plan on servicing the calipers, and flushing the fluid too.
April 19th, 2015, 12:11 PM | #8 |
cadd cadd cadd
MOTM - May '15
I'd use liquid soap to wash after wiping it off. If it's on a painted surface, make sure to apply a little wax on it as the Dawn strips the wax off the surface. I'm sure the brake fluid also dissolved any wax that was there a well.
April 19th, 2015, 06:19 PM | #9 |
Success. Velcro tie on the brake lever... we'll see how it is in the morning.
I just wonder why they give you SO MUCH brake fluid.... 'cause that stuff don't keep. (It's bike-specific, BTW... MOTUL RBF600... so no reason to package it in such a big bottle).
April 19th, 2015, 06:24 PM | #10 |
Participant
April 19th, 2015, 07:42 PM | #11 |
cadd cadd cadd
MOTM - May '15
What I also like to do is use plastic food wrap (saran wrap???) to cover the hole before screwing on the cap. Keeps it more air tight so water from the air doesn't get in as easily.
April 19th, 2015, 09:35 PM | #12 |
30 seconds you probably wont notice it. 5 minutes will leave marks that you'll be able to polish out. an hour and it will be very noticeable and you'll have a real hard time making it go away without repainting.
Brake fluid | Islandmax | 1986 - 2007 Ninja 250R Tech Talk | 11 | June 22nd, 2013 04:28 PM |
2010 Ninja 250r Brake fluid bleed/Replacement and brake caliper cleaning | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 1 | May 30th, 2013 08:13 PM |
Replacing brake pads and brake fluid | Bones85 | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 28th, 2013 06:25 PM |
How much brake fluid ? | GiGs | 2008 - 2012 Ninja 250R Tech Talk | 5 | December 31st, 2010 06:06 PM |
Brake Fluid? | ASecretNinja | 1986 - 2007 Ninja 250R Tech Talk | 4 | January 20th, 2010 03:02 PM |
