August 29th, 2015, 05:11 PM | #1 |
Join Date: Aug 2015 Motorcycle(s): 2005 Kawasaki Ninja 250 Posts: 13
Front vs Rear Turn Signals
So I have a question about the turn signals on our bikes, are the front and rear signals able to be used interchangeably? I know the front uses a bracket and the rear goes right into the fender, but are they the same? The reason I ask is because I bought a pair of signals from a guy off ebay and he said both signals are the same. The ones I purchased look like they are the rear set. Can someone help me out with this? Thanks!
August 31st, 2015, 05:57 AM | #2 | |
August 31st, 2015, 06:51 AM | #3 |
According to Kawasaki the front will swap left to right, same for the rear.
They list a different part numbers for the front and rear, not left to right. I don't remember there being that much difference, but it's been awhile since I've had OEM turn signals. Also on the last years of the PreGen they used a small assembly.
August 31st, 2015, 03:42 PM | #4 |
Whoops!
The OP didn't mention year, I went with what mine is which is 2006-7. Previous years have a radically different signal assembly. |
August 31st, 2015, 03:53 PM | #5 |
No worries, I've made the same mistake a few times myself, I blame Kawasaki for changing.
September 1st, 2015, 04:29 AM | #6 |
Thanks a lot for the information guys! I was confused as to how the rear signals would fit into the front mounting brackets, but it looks like it just screws out of the rubber piece that goes into the fender. That diagram helps a lot. Also I have an '05 Ninja so hopefully that parts diagram applies to my bike?
September 1st, 2015, 07:15 AM | #7 |
EX500 full of EX250 parts
http://www.kawasaki.com/Parts/PartsD...2005/EX250-F19
There are 5 different suffixes (F15-F19) for the 2005. I'm not sure which yours is or what the difference between them is.
September 1st, 2015, 08:26 AM | #8 |
Thanks for the link Bill. When I enter in my VIN number on the Kawasaki website it takes me to the same diagram. So I'm thinking I should be good then.
Looking for 09 oem rear turn signal and front turn signals and tail fairings | mbbernas | Items Wanted | 1 | September 11th, 2013 10:48 AM |
Rear turn signals don't blink, front turn signals don't turn on | andyuc88 | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 23rd, 2012 02:47 PM |
Front/Rear turn signals | C L | 2008 - 2012 Ninja 250R Tech Talk | 4 | October 8th, 2011 08:23 AM |
07 turn signals, OEM front and rear identical? | davidemartindale | 1986 - 2007 Ninja 250R Farkles | 4 | September 16th, 2011 11:56 PM |
2008 ninja 250r turn signals rear - front | jorgecornet | 2008 - 2012 Ninja 250R Tech Talk | 8 | October 18th, 2009 07:14 PM |
