Old December 29th, 2015, 05:24 PM   #1
simook
41078 Replacement (i.e. the speedo gear assembly)
Does anyone know of an aftermarket replacement for the speedometer gear housing? (Part 41078)
This would be for race applications where the speedometer cable is not used.
Up until now I've been using the oem gear housing, but I just discovered that it's very brittle (casted steel?), so it needs to be replaced. Yep, it's way broken...
Any ideas, suggestions?
- OMRRA Racer #83 -
-- OMRRA Media Group Editor/Producer --
Last futzed with by simook; December 29th, 2015 at 09:44 PM.
simook is offline   Reply With Quote
Old December 29th, 2015, 09:48 PM   #2
simook
No idea how this happened.
- OMRRA Racer #83 -
Old December 29th, 2015, 10:36 PM   #3
HoneyBadgerRy
HoneyBadgerRy's Avatar
I was told there is no replacement, I'm in the process of finding something that will work, but I haven't tried to hard yet.
Old December 30th, 2015, 06:37 AM   #4
verboten1
verboten1's Avatar
MOTM - June '15
It's just a spacer at this point. Find the right ID tubing and cut it to the correct length.
Ride more, worry less.
Old December 30th, 2015, 07:39 AM   #5
AwDang
Motorcycle(s): 286, 296, 599, 799
try a cush drive spacer from the rear
AwDang is offline   Reply With Quote
Old December 30th, 2015, 07:44 AM   #6
Dsheumaker
Dsheumaker's Avatar
Motorcycle(s): 14 Ninja 300 (Track Only), 07 CRF150RB
I was thinking about trying to make a spacer to replace this since its kinda a pain in the ass haha
Dsheumaker is offline   Reply With Quote
Old December 30th, 2015, 09:36 AM   #7
HoneyBadgerRy
That was my idea, but with the 3 minuets I looked, I couldn't find metric tube.
Old December 30th, 2015, 09:46 AM   #8
AwDang
http://www.onlinemetals.com/merchant...ep=2&top_cat=1
Old December 30th, 2015, 10:40 AM   #9
mgentz
Board Member
@DCMoney or someone makes one...
Old December 30th, 2015, 11:01 AM   #10
HoneyBadgerRy
If someone on here had a lathe it would be sweet.
Old December 30th, 2015, 11:09 AM   #11
DCMoney
DCMoney's Avatar
Thanks for me mention.
https://www.ninjette.org/forums/showthread.php?t=231634
MCRA.com
'08-'12 Front Speedo Replacement Spacer DCMoney Motorcycle-related 34 April 29th, 2017 12:34 AM
- - - DCMoney 08-12 Speedo Replacement Spacer Review - - - Triple R 2008 - 2012 Ninja 250R Tech Talk 1 June 5th, 2015 06:30 AM
