Old March 13th, 2013, 08:24 PM   #1
4950cycle
Motorcycle(s): 06 EX 250, 75 CB 125 S, 2011 Fang Bobber
Oil change issues
Hi I got an 06 250 Ninja I turned into a trike. Anyway i went to change the oil filter and clean the screen. Seems to me the previous owner may have gotten the spring , filter , and tin filter hat in the wrong order. I may be wrong but it just does'nt look correct. Can anyone verify in what order the oil filter system goes in ? It was in this order from the bottom up. Cover plate, spring, filter, then tin hat (filter shroud of some sort). Any help would be greatly appreciated.
4950cycle is offline   Reply With Quote
Old March 13th, 2013, 10:23 PM   #2
Arby3k
Motorcycle(s): 2000 Zx6r
http://kawasakipartshouse.com/oempar...ump-oil-filter
Don't have the bike my self, but maybe this might be useful.
Arby3k is offline   Reply With Quote
Old March 14th, 2013, 05:28 AM   #3
Check this link out:
http://faq.ninja250.org/wiki/Oil_Change_Procedure
You did not mention the flat washer that goes between the spring and the filter (92022).
Old March 14th, 2013, 06:02 PM   #4
4950cycle
I didn't see any washer Were all the other things in the right order that I said I did'nt put oil in it yet. I will pull the cover back off and put a washer of the right size in between the spring and filter element. So this is how it goes from the top of the bike down. Tin Top hat, filter element , washer, then spring on the bottom , right ?
Old March 14th, 2013, 06:10 PM   #5
j98sprint
Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900
Yup
j98sprint is offline   Reply With Quote
Old March 14th, 2013, 06:14 PM   #6
Originally Posted by 4950cycle View Post
I didn't see any washer Were all the other things in the right order that I said .........
Check the links above, which contain schematics.
Old March 14th, 2013, 07:07 PM   #7
4950cycle
What links above what
Old March 15th, 2013, 02:24 AM   #8
Links shown in posts #2 and #3 that will take you to another web page.
Old March 15th, 2013, 07:55 PM   #9
4950cycle
I see the links now ? where were they before ? Anyway, thanks so much Arby and Moto. Solid info.
Went to change my brake pads, but had some issues installing the news ones. Insane Pie 2008 - 2012 Ninja 250R Tech Talk 6 September 16th, 2014 02:18 PM
Is it normal for oil to increase a bit in the crankcase after an oil change? cadd 2008 - 2012 Ninja 250R Tech Talk 10 May 15th, 2014 08:38 PM
Synthetic oil at 300 mile oil change? anacron 2013 - 2017 Ninja 300 Tech Talk 14 July 29th, 2013 04:58 PM
Oil drain plug gasket for oil change. tsdexter 2008 - 2012 Ninja 250R Tech Talk 8 July 10th, 2012 01:00 PM
change oil filter, without draining oil? peter330 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2010 01:08 PM
