April 7th, 2015, 03:16 PM | #1 |
Join Date: Apr 2015 Motorcycle(s): 1996 250 ninja, 1995 sportster Posts: 13
New guy..Heavily modified 1996 250
Hi there..I have a heavily modified 1996 250 that I've been working on for several years and I'm almost done but I'm having a problem getting it running again, which is why I'm here..I'm hoping someone has modified theirs and can help me out with a few bugs! Thanks for any help in advance! Adam |
5 out of 5 members found this post helpful. |
April 7th, 2015, 03:30 PM | #2 |
MOTM - Sep '18, Feb '16
Wow that's modified alright. What's going on?
April 7th, 2015, 03:41 PM | #3 |
cadd cadd cadd
MOTM - May '15
Wait a minute....is that a hardtail?! Oh man....your body is going to get punished real bad! But looks so damn unique. I like.
April 7th, 2015, 03:42 PM | #4 |
Join Date: Aug 2014 Motorcycle(s): 2007 Ninjette Posts: 809
I've identified your problem. Your ninja is no longer a ninja.
LOL What's the issue?
"That's what" -she |
April 7th, 2015, 03:47 PM | #5 |
idling problem
I had the bike up and running and riding but it doesn't seem to want to stay running now. I can't get it to idle for more than like 30 sec. I have adjusted the valves, had the carbs apart 3 times and messed with the idle screw to no end. It will idle with the choke on for a few min but if I turn it off it dies or will only idle a very short time. I have the exhaust pretty much open also. I'm more familiar with the Harley platform and I guess I'm wondering if I'm overlooking something...
April 7th, 2015, 03:50 PM | #6 |
Not a ninja!
Ha! I figured I'd see that...I do like them stock but I've built a frame jig and was eager to build a chopper..yeah a hardtail..it actually seemed pretty decent for the 2 miles I've been able to put on it.
April 7th, 2015, 04:07 PM | #7 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
Is the radiator hooked up? Not that it would matter for 30 seconds, but that tube looks like it's supposed to go somewhere. I'm not familiar with any issues that you could be having. Any way to post a video or something?
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
April 7th, 2015, 04:29 PM | #8 |
Its not hooked up in the pic, I actually made one out of copper...The only vid I have is of the bike actually running and now it doesn't want to. Some stuff is on my phone and some my comp...I'll try to post one
April 7th, 2015, 05:36 PM | #9 |
I'm crazy,your excuse is?
Welcome. Hope your moto feels better soon.
April 7th, 2015, 06:26 PM | #10 |
What size jets are you using? How does fuel feed the carbs?
April 7th, 2015, 09:01 PM | #11 |
Welcome!
April 7th, 2015, 09:30 PM | #12 |
haha this is the best ninja 250 i've ever seen
April 7th, 2015, 09:38 PM | #13 |
MOTM - July '15
Agreed^ I heavily admire seeing something turned into something it's not.
April 7th, 2015, 09:49 PM | #14 |
Inline 4!!!
Looks great man, hope you get the issue resolved... I'd definitely say it's carb related. Also check your hoses, make sure there are no vacuum leaks.
April 7th, 2015, 10:18 PM | #15 |
Freedom for Germany
wow incredible beautiful bike
April 7th, 2015, 11:42 PM | #16 |
Join Date: Dec 2008 Motorcycle(s): '08 Kawasaki EX250 "Yoshi", '99 Kawasaki Concours "Grace", '06 Concours "Belle", '06 Yamaha YZF600R "Slick" Posts: A lot.
< ATGATT > Sweat you can wipe off, Road rash you can't. HEY!! Unregistered!! Does your bike have a name? |
April 8th, 2015, 06:23 AM | #18 |
Thanks to all!
I'm using #108 mains and stock pilot but I can't get it to idle long enough to even rev it much, the petcock is a stock early Harley and I have a clear fuel line so I can see fuel flowing, I had issues with fuel leaking out of the pilot jet circuit but after polishing the float seats with a Q-tip it seems to have stopped. I have had the mixture screws all over the place I'm at around 2 1/4 turns now. Maybe I just need a larger pilot?
April 8th, 2015, 06:54 AM | #20 |
@garth285..its brand new, and the tank is super clean, it was one my buddy had that was never rally run. The odd thing is, I had it running but it would only run for around a mile and die, is there an over-temp shut down? I didn't notice anything on any wiring diagram. The only vac lines are running to the coast enrichner and I plugged off the one to the petckock with a brand new block off plug.
April 8th, 2015, 07:08 AM | #21 |
Replace the pilots with 38-40
April 8th, 2015, 08:13 AM | #22 |
MOTM - Oct '15
Ok, this might be reaching but it looks to me as though you've tilted the engine and carbs further forward than it is in the ninja frame. If I were you this is what I'd do:
1.) Level the carbs (I think this is your issue) 2.) Adjust float height, etc. 3.) Run a 38 idle jet, 102 main jet (unless you've done extensive head work, a stock untouched head won't flow much more than that), idle mix set at 2.75 and match needles and idles screws for both carbs since the stock setups aren't identical. - From the factory cylinder 1 is tuned for torque and cylinder 2 for HP with different main and idle needles. Since you're running equal length intake and exhaust you've defeated this tuning so you have to match them. Just buy another needle and idle jet for either cylinder and put it in the other cylinder's carb. I don't think it's overheating - you're way to rich for that. If you've got reliable spark, it's starving for fuel. So if fuel is being delivered to the carbs, it's not getting into the chamber and the only thing affecting that if you're carbs are clean is carb angle/float height (getting the fuel to be the right distance from the jets to be sucked up and atomized). Since you can't change the angle of the engine, change the angle of the carb with some AL tubing - you could even cut the intake runners to fit inside the AL to make for a solid seal or come up with some other way of sealing them. Anyway, just a thought.
April 8th, 2015, 11:26 AM | #23 |
update
Right on, thanks for all the info, I'm going to order the new idle jets today and I'll check out those other items as well, Spooph. I hadn't considered the tilt at all yet. So I went back and double checked and I'm running a #105 main and a #38 pilot..I guess I'll have to try leveling them first...
Last futzed with by akexel; April 8th, 2015 at 11:39 AM. Reason: add text |
April 9th, 2015, 11:17 PM | #24 |
Hello and welcome. Awesome mod.
April 10th, 2015, 02:55 AM | #25 |
sammich maker
MOTM - Apr '15
Welcome, any pics of the process of the modifications?
April 10th, 2015, 08:54 AM | #26 |
Join Date: May 2013 Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol Posts: 222
To try to see if it is the level of the carbs I would jack the front up to make the carbs level and see if it runs. If so then you know the problem.
April 16th, 2015, 07:14 AM | #27 |
Update on ninja chop
Sorry for being away but I work 3rd shift 6 days a week and I have 3 kids to chase after! After messing around a bit it seems that at 2 1/2 turns on the pilot I can get it to idle but the slides are bouncing up and down at idle and all over the place when I try to rev it at all, but when I blocked the crescent opening to the diaphragm chamber I got it to smooth out and operate normally. I also only got it to do it once...I'm thinking I have a vacuum issue somewhere..
April 16th, 2015, 07:16 AM | #28 |
Could be a hose is disconnected? On the stock ninja there is a vacuum line going to the petcock from the carbs.
April 16th, 2015, 07:38 AM | #29 |
I'm pretty sure I have all the hoses covered, I used a block off on the one that's supposed to feed the petcock..I feel like I've been over all the lines and boots and triple checked the diaphragms...
April 16th, 2015, 08:48 AM | #30 |
time to spray some carb cleaner and check for rev changes. Old school it.
April 20th, 2015, 05:33 PM | #31 |
I finally got it!
Ok, so my vacuum problem was actually due to an intermittent weak spark at idle caused by the ign module. My friend and I were checking all the vacuum lines and he thought that it seemed the vac signal was off from the engine but we were able to get it to rev decently and we double checked the valves and everything was all good...so messing with it the next day I noticed one exhaust pipe was hotter so I checked the spark and at idle one was weak. So I switched the signal wires and the problem followed so I switched out the ign module and bam! I was riding it! Thanks a ton to everyone for your suggestions!
April 21st, 2015, 10:03 AM | #32 |
MOTM - Oct '15
i formally request a video of this "ninja"... I've never seen/heard a bobber run up to 13K... Wicked build dude!
April 21st, 2015, 01:30 PM | #33 |
250 Hartail test ride
https://www.youtube.com/watch?&v=aGK-4JUXj6E
April 21st, 2015, 10:32 PM | #34 |
Best 250 in its class!!!
It's at least the best I've seen this month glad you got the problem sorted!
April 22nd, 2015, 07:47 AM | #35 | |
MOTM - Oct '15
April 22nd, 2015, 08:00 AM | #36 |
ᗧ•••ᗣ•ᗣᗣ•••ᗣ
Join Date: Nov 2013 Motorcycle(s): 2009 Ninja 250R and 2014 Triumph 675R Posts: A lot.
Private -->
Spoiler for topic:
April 22nd, 2015, 04:40 PM | #37 |
Right on..
Yeah, I knew you were talking about RPM..I'm used to my sporty and revving it that high is pretty foreign to me! It looks like the video is up now..? I tried switching my youtube settings so..again, thanks for the help..will post more vids as I get it dialed in!
April 23rd, 2015, 09:04 AM | #38 |
MOTM - Oct '15
haha, that's awesome! dat idle do... :P Wicked bike man, and job well done! Can't wait for a new vid to hear that bobber scream! Really nicely done!
heavily modded 250 doesn't idle right | ekj112 | 2008 - 2012 Ninja 250R Tech Talk | 61 | May 16th, 2013 10:15 PM |
FS: Red 2010 heavily modified 250r. Bloomington, Indiana | NathanUc | Motorcycle-related | 23 | March 30th, 2013 01:33 AM |
1996 250 for $1000 FL | HKr1 | Motorcycle-related | 0 | June 1st, 2011 01:47 PM |
carb problems 1996 ninja 250 | mr.jake | 1986 - 2007 Ninja 250R Tech Talk | 17 | February 15th, 2011 08:54 AM |
[kropotkin thinks...] - More Moto2 Details - Spec Engine Will Be Heavily Modified CBR | Ninjette Newsbot | Motorcycling News | 0 | May 4th, 2009 03:40 PM |
