April 2nd, 2013, 02:58 PM | #1 |
Join Date: Feb 2012 Motorcycle(s): 06 250 rat, 20 400 krt Posts: 55
carburetors overfilling
after cleaning my carbs they started to overflow. assuming i muffed up the setting on the floats i pulled them back off and readjusted them again. not much of a change at all maybe a mm. but they are still pushing quite a bit of gas out the overflow.
is there something else that could be causing this ? or am i screwing up the float adjustment. they are set to 17mm btw Edit: i also added one shim if that makes a difference. |
April 2nd, 2013, 03:22 PM | #2 |
The petcock.
Between the petcock and the float valves, gas should only flow when vacuum is applied and the carb bowls should never run over. Look into rebuilding or replacing the petcock. A new petcock is $60 while a rebuild kit is $30-ish + shipping. In my experiences, the new petcock option was the permanent fix, while repairing the old petcock didn't really work for very long. |
April 2nd, 2013, 03:34 PM | #3 |
it only flows while the bike is running. the petcoc is good. sorry should have said that before
April 2nd, 2013, 08:07 PM | #4 | |
One or both floats are punctured or getting stuck in any awkward position. The valves are not sealing (the neoprene tip gets hard and/or the aluminum seats get deformed). The level of fuel inside one or both bowls is higher than specifications. Sometimes a light tapping (wood or plastic screwdriver handle) on the body of the carbs suffices to relocate internal parts and to stop a casual overflow.
April 2nd, 2013, 08:41 PM | #5 |
MOTM - Sep '18, Feb '16
Pull the carbs back off. Remove the float bowl. Attach a clean piece of fuel line to the carbs. Turn the carb up side down. Make sure the float is sitting about 10-14 mm above the bottom of the carb. The floats should be level.
You should not be able to blow through the hose. If you can blow through the hose then one or both needle and seat assembly's are not sealing.
April 3rd, 2013, 09:31 AM | #6 | |
that is a good trick that I would have never thought of. Apparently after cleaning them twice one was still not sealing properly. got it now. off to reinstall them in the bike. Edit: Yep runs like a champ. thanks again everyone. Last futzed with by Xer0-; April 3rd, 2013 at 02:49 PM. |
Dirty Carburetors? Nope! What could it be | ROSS11988 | 2008 - 2012 Ninja 250R Tech Talk | 11 | April 3rd, 2014 05:22 AM |
Tweaking the carburetors | broken neck | 2008 - 2012 Ninja 250R Tech Talk | 9 | September 25th, 2013 08:26 AM |
Overfilling the gas tank. | ChaoSS | General Motorcycling Discussion | 8 | April 10th, 2013 04:50 PM |
Removing Carburetors? | jdkvice | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 23rd, 2009 09:07 PM |
