May 20th, 2011, 08:30 AM | #1 |
ModMy250.com
What will you be doing to your bike this weekend?
Any projects you want to share? A while back, my dog decided to bust my rear seat cowl. She knocked it off my shelf and it fell and broke off a corner. I epoxied it back together last night. This weekend, I'm going to play around with it . I'll be skinning it with real carbon fiber. I don't ride with the cowl since I prefer the back seat on there, but if I like how it turns out, I may put it back on . I'll post pics when it's done. I hope I get enough time to finish the project this weekend.
What will you be doing?
The www.ModMy250.com guy |
May 20th, 2011, 08:49 AM | #2 |
Join Date: May 2011 Motorcycle(s): 2009 blue ninja 250r Posts: 223
Playin with my fender trying to fix a bad cut I made and clean/lube the chain and maybe polish her up a bit.
If you’re going to lead, then lead. If you’re going to follow, get the hell out of my way! |
May 20th, 2011, 08:54 AM | #3 |
ninjette.org Monkey Spank
Join Date: Apr 2009 Motorcycle(s): 2008 250R Track-Bike Woodcraft clip-ons and rearsets FZ-6 track bike Posts: A lot.
Ummmm RIDING
Black 250R Full Area P QC Dyno Jet Kit 100 main 41T Rear Sprocket |
May 20th, 2011, 08:56 AM | #4 |
Join Date: Dec 2010 Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125 Posts: 812
wife bought me a battery tender, great set up like the "battery tender" with wall unit, but a Shumacker for $19.99. Had the last shumacker for 7 yrs. until my 220 Volt post the other day. so i'm a wee bit grounded, just enough to let her think she has a say, yah mean? Also picked up my golden spectro and uni filters for both ninjas and will drop my earl.
May 20th, 2011, 08:59 AM | #5 |
ModMy250.com
John, I don't want to sound mean, but sometimes I feel like I need a Batman decoder ring to figure out what you're trying to say. LOL
May 20th, 2011, 09:00 AM | #6 |
Ninjette CPT
Join Date: May 2009 Motorcycle(s): Black 08 250r Posts: A lot.
swapping old bt45 rear for new b45 rear. good to go for another 15k
May 20th, 2011, 09:00 AM | #7 |
CVMA #74 WSMC #750
Join Date: Oct 2009 Motorcycle(s): All of them Posts: A lot.
Rebuild forks, install Ohlins Rearshock, install preload adjusters, replace grip, custom side tank grip, and upgrade clutch/brake MC levers. Oh and clean & lube chain. Possibly change front brake pads too.
Would have been nice to get that 415 chain conversion and do that too. |
May 20th, 2011, 09:20 AM | #8 |
ModMy250.com
Sounds like you'll have a busy weekend Nemesis!
May 20th, 2011, 09:30 AM | #9 |
Join Date: Apr 2011 Motorcycle(s): 2010 Red Ninja 250R Posts: 167
probably clean and lube the chain and give the bike a bath. And of course ride if at all possible
May 20th, 2011, 09:39 AM | #10 |
besides normal weekend checks like tires/fluids...
change air filter wash bike ride her |
May 20th, 2011, 10:20 AM | #11 |
Wash and ride...
May 20th, 2011, 10:20 AM | #12 |
Wartown, USA
Join Date: Nov 2009 Motorcycle(s): 2009 Ninja 250R SE, 2007 Ninja 650R, and assorted other bikes Posts: A lot.
Well...
Got up yesterday, and completely washed and waxed the bike...usual routine. Got the wrenching bug, and decided to adjust my shifter lever down, because its just too darn high from the factory for my long legs and seating position. Took off the shifter, and adjusted it, and figured since I had it off, I might as well pull the sprocket cover and clean out any road grime and chain lube that was in there. While I had the sprocket cover off, I checked my sprocket.....turns out I need a new sprocket. The teeth are starting to hook....which will also mean a chain change. Soooooooooooooooo. Looks like Ill be doing a sprocket and chain swap this weekend. |
May 20th, 2011, 12:41 PM | #13 |
Join Date: May 2011 Motorcycle(s): 1995 Ninja EX250 Posts: 65
Just dreaming about it as it has been in the shop for two weeks now getting the carbs rebuilt. It's killing me I bought it about a month ago and have only been able toget it out a few times. When I do get it back it will be running right though and ready for the road!
May 20th, 2011, 02:09 PM | #15 |
Join Date: Mar 2011 Motorcycle(s): 09 ninja 250r Posts: 97
Pack her and strap her down with the chocks and canyan dancer then off to fl!
May 20th, 2011, 02:32 PM | #16 |
May 20th, 2011, 08:13 PM | #17 |
ModMy250.com
Bah. Forgot my niece's first communion is tomorrow. Most of the family will be there so no joy on the carbon fiber for me
May 20th, 2011, 08:36 PM | #18 |
Join Date: May 2011 Motorcycle(s): 2008 kawasaki ninja 250r Posts: 20
sprocket change
Ok 2008 250r, changed front sprocket out for 1 tooth less. I was told that I would see a big difference in low and mid range that would be pleasing. I was also told that the top end would come down from 100 mph to about 80 mph. My bike runs very strong and has low miles on it still. But after change out on sprocket I got a totally different out come. Its was slower in low and mid range. And top end I could still hit 100 mph. The rpms always seem to be in the 10 thousand or higher after each shift as if im missing the power band now. Has any one else done this and what was your out come. There is nothing wrong with my bike it just feels slower all together? Please post
May 20th, 2011, 08:40 PM | #19 |
May 20th, 2011, 08:49 PM | #20 |
Join Date: May 2010 Motorcycle(s): Current: '11 ZX-6R; Previous: '09 Ninjette; '08 ZX-6R (Ex-Wife '09 TU250X) Posts: 981
I will be (should be) building a shed for my bike and the wife's bike. We finally got our driveway poured last Thursday or Friday, and we have been able to drive on it since this Tuesday. I love it! So nice to have a drive after 12 years of gravel and dirt. Now to just wait for the rest of the road to get finished over the course of the summer.
R.I.P EthioKnight (Alex) |
May 20th, 2011, 08:59 PM | #21 |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
Installing a full race CF 12" Area P, Installing pods, and jetting
May 20th, 2011, 08:59 PM | #22 | |
Here's a link to a pretty detailed thread about sprockets, but search on "sprockets" and you'll find a bunch more as well.
May 20th, 2011, 09:13 PM | #23 |
Indeed. Going down in the front and up in the back is pretty much for parking lot stunters to make off-the-line wheelies and such. Top speed isn't affected but RPM at that speed and how much "pull" it has at a specified RPM *IS.*
May 20th, 2011, 09:46 PM | #24 | |
Last futzed with by jaso; May 20th, 2011 at 11:13 PM. Reason: wrong spelling |
May 20th, 2011, 09:51 PM | #25 | |
It should be about 1,400 RPM at idle when fully warmed up. Last futzed with by CZroe; May 21st, 2011 at 09:50 AM. |
May 20th, 2011, 10:11 PM | #26 |
Lol, no not compensating :-). I have my idle at about 1600 rpm's fully warmed up. But my manual said idle should be in the 1250 to 1350 @ temp for an 2008
May 21st, 2011, 08:11 AM | #27 |
MOTM - Mar '13, Jun '14
lube the muffler
May 21st, 2011, 09:51 AM | #28 |
May 21st, 2011, 06:11 PM | #29 |
ummm riding ftw!
Me and my brother road the kids around for about 4 hours. Sad to admit we were a bit squiddy. (put all the good gear on the kids) Was a nice slow, easy ride. Put my hugger on before the ride. Wow! what a difference in dirt on the underside. Bro road the pregen, I rode the 2010. Time to clean up the ladies and tend to the the chain and carbs of the pregen. She idles a bit high fully warmed up. Can't wait to ride his kids around, less squiddy next time though. |
May 21st, 2011, 06:18 PM | #30 |
Join Date: Mar 2009 Motorcycle(s): '09 Blue Kawasaki KLE650 Versys, '95 Ducati 900SS/CR (undergoing track conversion) Posts: 287
hrmm...
traded the 250 in for a Versys... Started the tear down on the Ducati to convert it to a track only bike...
2009 KLE650 LSL bars, Full Muzzy PC-V 1995 900SS/CR mildly modified |
May 21st, 2011, 06:19 PM | #31 | |
May 21st, 2011, 07:22 PM | #32 |
Our drive is roughly 100 feet. The entire road, which is being paved by my wife's uncle (since he owns the machine shop and is doing reasonably well), is somewhere around 3/8 of a mile.
Our cost on the driveway was substantially less than it otherwise would have been, because we got a deal due to the entire road eventually being paved. My wife also got a bonus of sorts from her aunt and uncle (the machine shop people, whom she works for) so that further reduced the cost. Our final total for the 100 foot long, 12 foot wide drive was roughly $1800. The actual cost was closer to $3000. I don't even want to think about what the entire road will cost. You can actually see the gravel road in the YouTube video I posted under the same user name. Basically, the camera bounces up and down a lot until I get to the end. We will be finishing up the shed tomorrow. I will be taking a video of the driveway and shed sometime later in the week and I will post it on YouTube.
May 21st, 2011, 11:51 PM | #33 |
Didn't get to install the jet kit and exhaust so I'll just be rocking it stock again at the track tomorrow for parade laps.
May 23rd, 2011, 10:40 AM | #34 |
ModMy250.com
The CF was a bust. I got some sort of bubbling from the weave. I think I might have squeegeed too much epoxy off. I'll have to strip it and retry it this week.
May 24th, 2011, 01:08 PM | #35 |
Smoker
track the shiat out of it.
May 24th, 2011, 06:46 PM | #38 |
Professional belly dancer
Join Date: Apr 2009 Motorcycle(s): 1992 GSX-R 750 Posts: A lot.
Dumped half a bottle of seafoam into the tank over the weekend and the bike ran like garbage today. I guess I'll be tearing into the carb this weekend.
Dropped My Bike Last Weekend... | Minikin_Jo | !%@*#$%!)@#&!%@ I crashed! | 74 | November 1st, 2012 02:01 PM |
Big Bike Weekend, Oct 12-14, Redding CA | Kregore | Ride Reports | 3 | September 20th, 2012 08:47 PM |
Some Bike Maintenance last weekend... | LiquidBiohazard | Pictures | 3 | August 18th, 2011 04:16 PM |
Can't wait - bike#2 this weekend! | vital2009 | New Members | 47 | July 16th, 2011 03:15 AM |
Wrecked my bike this weekend :( | d16soda | !%@*#$%!)@#&!%@ I crashed! | 21 | June 27th, 2011 09:00 AM |
