October 23rd, 2013, 06:39 PM | #1 |
Join Date: Sep 2013 Motorcycle(s): 2008 Ninja 250r Posts: 7
Ninja Clutch Plates
Hi I need help fixing up my clutch. I reinstalled new clutch plates and steel clutch plates. I have realigned the U shape ends of the clutch plates together. There is no indexing (from the DIY clutch replacement of up to 2007).
My problem is that it won't grab. The clutch stays in neutral when I start it. Any ideas? |
October 23rd, 2013, 09:34 PM | #2 |
Correct number of plates? If any are missing, the operating plate will bottom out before it squeezes the clutch pack.
October 24th, 2013, 06:23 AM | #3 |
October 24th, 2013, 09:59 AM | #4 |
The number of plates are right. I have 5 clutch plates and 4 steel plates alternating. I think how I put them together is the only problem why they won't engage properly.
And what I mean by "it stays in neutral" is when I pull the clutch in, it stays pulled, it doesnt push back. Is there a certain way to put the clutch plates together. I tried aligning all the clutch plates with U shaped indentation. not working. |
October 24th, 2013, 10:10 AM | #5 |
the "u shaped indent" in the one side of each of the clutch plates is meaningless
number of plates would only effect it not fully engaging. it would not keep it from engaging at all. if you were missing a plate it would simply slip. but the lever would return. the springs underneath the 5 bolts that hold the clutch hub in are what push the clutch hub back down, causing the clutch lever to return to its normal position. maybe the cable is stuck? did you forget to put the clutch springs in? is the linkage from the clutch release pin to the cable working?
October 24th, 2013, 04:52 PM | #6 | |
Check this out: http://www.ninjette.org/forums/showt...=127820&page=3 http://www.ninjette.org/forums/showp...61&postcount=3
October 24th, 2013, 05:49 PM | #7 |
No part 13102 engages the clutch rod. It's the clutch rod that doesn't push back.
I'm putting it back exactly how that visual assemble says. Btw Motofool, just read that page, It is exactly the same problem as that guy. Will disassemble again tonight and see if your solution works. I'm pretty sure I'm putting the clutch cover on properly, so that the clutch rod works. It's just that I think the clutch rod doesn't push back when you push it in. |
October 24th, 2013, 07:44 PM | #8 | |
The only other problem would be that the teeth of both parts are jammed somehow and impede any relative slide.
October 24th, 2013, 09:41 PM | #9 |
So I studied that picture for a few minutes. Okay so the correct sequence is 46102 (clutch rod), 92045, and 13187 (clutch plate).
Lol I was installing it as 92045, clutch plate then clutch rod. Damn. stupid mistake haha. Thanks a lot you guys. Hey Motofool, you know your **** with ninjas btw. I've been in this forum for a while and I always see your responses. (P.S. Also, I bet that guy that you were trying to help with the same problem as me did the same stupid mistake.) |
October 24th, 2013, 09:59 PM | #10 |
You are welcome, Vince
Hope the thing works properly now, ...... don't forget lubricating the cable and the lever's pivot and leaving some slack to the cable (some gap at the lever).
Clutch plates stuck? | dragono | 1986 - 2007 Ninja 250R Tech Talk | 37 | February 28th, 2015 01:58 PM |
DIY: Replacing the Clutch Plates | Purspeed | 1986 - 2007 Ninja 250R Tech Talk | 76 | December 1st, 2013 12:17 AM |
clutch plates and steels | mgentz | 2008 - 2012 Ninja 250R Tech Talk | 21 | February 20th, 2013 08:50 PM |
