January 2nd, 2017, 12:06 PM | #1 |
Join Date: Oct 2016 Motorcycle(s): '06 Ninja 250 Posts: 19
Nude gauges project
Got my first bike a few moths ago and have been slowly converting it into a street fighter. Pulled off all the fairings, replaced the tail lights, wrapped the headers, and am now tackling the front section. Just received a new headlight and mounts and $30 universal speedo with some rather lackluster wiring instructions
https://www.amazon.com/IZTOSS-Speedo...2E9NWZ8B768G85 Gonna take today to get started on attempting to wire it up. I'm sure there'll be a couple questions throughout this process, but here's one to start: Did some prep reading, and there are a lot of suggestions to wire the tach straight to the coil instead of wrapping a spark plug. How does one do this? Please explain as if talking to a 5-year old who has never done anything more adventurous than attach new turn signals. Many thanks. Photos of the process to come throughout |
January 2nd, 2017, 07:13 PM | #2 |
So I'm well on my way! Photos below.
Only two snags so far: 1) How do you mount an electronic speedo sensor to the front tire? Would love to see some picture of how you all have done it. I have the long bolt kind and it's not sitting comfortable anywhere. 2) Is there a proper way to attach a wire to the positive terminal of an ignition coil? Otherwise, she's well on her way! |
January 3rd, 2017, 05:54 PM | #3 | |
Note that the coils and tach receive constant 12V power (red and brown wires respectively), and the igniter grounds the black (or green) wire to complete the circuit.
January 3rd, 2017, 06:52 PM | #4 | |
Also, there's a pin that says needs to go straight to the positive terminal of the battery for uninterrupted current (even when ignition is off). Are you saying the the red and brown wires of the coils and tach respectively will serve the same function? Are these the positive terminals of the coil on that PDF? Thanks so much for all the help. Really appreciate it Last futzed with by magnaton; January 4th, 2017 at 12:36 AM. |
January 4th, 2017, 12:35 AM | #5 |
Ack -- no luck. I can't get this thing to save my settings. Which makes it a little useless as a speedometer since it needs wheel circumference saved.
I've wired the power to the positive terminal of the battery for constant power supply and still no joy. For all intents and purposes, what's the difference between the brown and the red/blue wires in the stock gauge? Are those both switched power? |
January 4th, 2017, 08:38 AM | #6 |
Join Date: Feb 2009 Motorcycle(s): 2009 250r SE, 2015 FJ-09 Posts: 171
If you have 12v+ with the ignition off and it is still not saving with the ignition off you might have a switched ground or possibly the full time 12v+ is on the wrong wire.
January 4th, 2017, 02:52 PM | #7 |
Hrmm makes sense. To confirm, my interpretation of the wiring schematic in the sticky is:
1) Yellow/Black: Constant ground 2) Brown/blue: Switched 12v 3) Red/blue: Switched 12v 4) Red terminal battery: Constant 12v Is that correct? Is there any difference between 2 and 3 above? Last futzed with by magnaton; January 4th, 2017 at 07:59 PM. |
January 5th, 2017, 05:18 AM | #8 | |
Red/blue is from the TAIL fuse, and is switched power to all the "running" lights on the bike. In the dash, it powers the illumination bulbs.
The brown/blue is switched power from the IGN fuse. It powers the gauges and indicator lights themselves, the igniter, and the kill switch (which passes through to the red wire powering the coils). Other than the battery terminal/lead, the white wire is the only source of non-switched 12V power in the harness. It runs from the Main fuse to the ignition switch, R/R, and the FAN/ACC input of the junction box (that might be changed on some years' harness, as was the case on the EX500). Quote:
January 6th, 2017, 08:02 PM | #9 | |
As a hail mary I switched the two powers to see if there's was something I missed and that just made things worse, as expected. Ground direct to battery negative didn't help either. Color me stumped |
January 6th, 2017, 09:12 PM | #10 |
If you have ground direct to battery negative and a direct line for battery positive and it is still not saving you either have a dead battery or it is something with the unit. My money would be on bad unit at this point.
January 7th, 2017, 07:55 AM | #11 | |
Like empire00 said, if you've got the power hooked to the battery and are using the common black/yellow ground or the battery itself, there's not much else to go wrong. I'd suspect a bad (or poorly documented) gauge. There can be confusion around the red/blue wire though. It's red/blue coming out of the TAIL fuse and going to the ignition switch, dash illumination lights, and brake light switches. The wires from the brake light switches to the bulb are blue/red. The oil pressure sensor also uses a blue/red wire, and runs to the dash for the warning light. But again, this should be going to the switched power circuit on your gauge, so using the wrong source here should just result in the gauge not turning on at the right time (as opposed to working properly but not saving settings).
[motorcyclenews.com - reviews] - Derbi GPR50 Nude (2004-current) | Ninjette Newsbot | Motorcycling News | 0 | December 5th, 2013 07:00 AM |
Planning out my fighter project, I want Trail Tech Vapor gauges...how to mount it? | seksninja | 1986 - 2007 Ninja 250R Tech Talk | 19 | August 10th, 2013 11:23 AM |
[motorcyclenews.com - reviews] - Derbi GPR50 Nude (2004-current) | Ninjette Newsbot | Motorcycling News | 0 | April 18th, 2013 01:10 PM |
Nude beaches, would you go? | ninjabrewer | Off-Topic | 43 | September 12th, 2010 12:38 PM |
