November 18th, 2014, 06:52 AM | #1 |
Join Date: Apr 2014 Motorcycle(s): Ninja 250, Yamaha RS200 (classic) Posts: A lot.
Alternative Carbs ?
Okay I left it standing for a couple of weeks and now, as usual, it will only run through the choke circuit because the idle circuit has a smidgeon of oxide in it so will have to be stripped for the (double figures) time.
It is beginning to feel like a Wile-E-Coyote Acme bike Anyone fitted alternative carbs to the Keihin CVKs that make it behave like a normal bike instead of clogging every time it stands for more than a week. Everything else about the bike is fine but the carbs are a real achilles heel. No its not that I haven't cleaned them well enough it is always running just fine before standing. And every time it stands it is stuffed, I'm contemplating a nice simple pair of these secondhand with K&Ns to get rid of the PITA airbox hassle too. http://www.ebay.co.uk/itm/Mikuni-VM3...3D171258821631 It is going to be that or part it out because I need this hassle like a leaky biro in a white suit. Last futzed with by Ninjinsky; November 18th, 2014 at 08:15 AM. |
November 18th, 2014, 08:42 AM | #2 |
have you checked the inside of your gas tank for rust?
whats the status of the fuel filter
November 18th, 2014, 08:51 AM | #3 |
In a couple of weeks of sitting you can get a fair amount of condensation built-up if the tank is not close to full.
Gas with ethanol can go bad quickly, and you never know how long it was in the storage tank before you bought it. Can you get "Regular" (or anything) without ethanol? Higher octane than necessary can cause hard starting. Drain the floatbowls and look at what comes out. I'd also run a fuel system cleaner once a season, or more if you think you have some deposits that need to be removed. I really don't think a different set of carbs would help. |
November 18th, 2014, 08:52 AM | #4 |
direct fuel inject would probably solve the issue though
November 18th, 2014, 09:14 AM | #5 | |
JKV: appreciate that but once the idle circuit has been cleaned that fuel is fine. I will drain them completely tomorrow in case there is water and to give the float bowl a completely fresh charge, but have never seen water in there. |
November 18th, 2014, 09:33 AM | #6 | |
The Pilot jets may have corrosion internally, made worse by ethanol. You could try replacing the Pilot Jets and see what effect that has - and run fuel without ethanol. |
November 18th, 2014, 09:58 AM | #7 | |
http://www.tescopfs.com/our-fuel/specifications |
November 18th, 2014, 12:18 PM | #8 |
Join Date: Sep 2010 Motorcycle(s): Cheap Italian Suit. Otherwise known as Dew Kitty Posts: A lot.
I prefer vegan bread.
November 18th, 2014, 01:19 PM | #9 |
KAWASAKI GURU
Join Date: Jul 2013 Motorcycle(s): Turbo Ninja 250 Posts: 863
Convert to ninja 300 fuel injection? lol
November 18th, 2014, 03:39 PM | #10 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Ever consider adding a bit of fuel stabilizer every time you gas up?
November 18th, 2014, 03:46 PM | #11 | |
The main difference is diaphragm versus slide; the passages for air and fuel are equally small; both types work with the same clogging gasoline. I have had my Ninja out of operation for more than a month when I had gone to work out of the state and it has started right away. My trick: draining both bowls completely before storage and filling up the gas tank up to the cap.
November 18th, 2014, 03:58 PM | #12 |
Inline 4!!!
Fuel injection was the main reason why I ditched my 250. I miss the hell out of it, but I feel like my bike runs more reliably now, just push the button and you're good to go.
November 18th, 2014, 04:07 PM | #13 | |
direct injection runs much higher psi, more like a diesel works. but obviously nowhere close to the levels that a diesel runs, otherwise the gas would explode in the injector. direct injection doesn't clog because you're talking about a piezo hammer bringing it up to around 5000psi (diesels go all the way up to 30-50k psi depending)
November 18th, 2014, 04:45 PM | #14 |
The thing is That I have had maybe 12 cars and 10 bikes, some of them pretty ragged and none of them has exhibited this behaviour, Only the CVK's on the ninja.
November 18th, 2014, 04:52 PM | #15 | |
I don't know of an evident cause in this specific type of carbs. Again, mine never get clogged: sometimes I ride daily, sometimes I must stop for several days. The poor thing sleeps in a hot and humid garage. Respect to the other bikes, has any other thing changed other than the Ninja? Fuel (ethanol, octane, additives)? Location (climate, height, air humidity)? Storage conditions (fluctuations of temperature, humidity)?
November 18th, 2014, 05:18 PM | #16 |
are you sure its the carbs causing the issue?
i know the problem goes away after you clean the carbs... but maybe its a distraction... maybe you have a really bad vacuum leak that develops after the carbs have been seated for awhile? and when you reseat the carbs its fine for a bit until they come out again? just spitballing.
November 18th, 2014, 05:22 PM | #17 |
Xemilin's video from a couple of threads down is the typical experience.
Link to original page on YouTube. |
November 18th, 2014, 05:40 PM | #18 | |
Sometimes in life one just has to say "beats me" and move on. It has been apart many times and I have 2 sets of carbs, changed ICU and coils The head was off recently for a seeping gasket so pretty complete strip with all items/ plumbing checked but the problem remains the same. So as I said above I think I will spares or repair it. |
November 18th, 2014, 06:22 PM | #20 |
True but I can't afford one which is why I said VX800 Suzukis neat semi custom v twin
http://www.suzukicycles.org/photos/v...Bruce1_640.jpg |
November 18th, 2014, 06:34 PM | #21 | |
Inline 4!!!
November 18th, 2014, 08:22 PM | #22 | |
Unless you are smelling or seeing overflowing fuel while cranking, the bowls of your carbs are dry like coconuts !!! I would check for plumbing problems instead, such as vacuum in the cold tank or lack of it in the petcock. What that video shows is far from normal; my bike never needs more than three attempts after weeks in storage. If your hose delivers less than 2 c.c. per second, there is a plumbing or vacuum or filter problem. Check the mesh filters inside the tank and inside the end of the hose. Try cranking with the petcock in reserve as well. Also, do not crack the throttle open while cranking, you are killing the vacuum for the idle and choke circuits that way. I fully agree, life goes away in a heart beat.
November 18th, 2014, 09:38 PM | #23 |
it's the sad truth about life. it's over in an instant. and it comes from every direction.
November 19th, 2014, 11:09 AM | #24 | |
After reading this, could you tell us what system is in your bike?: http://en.wikipedia.org/wiki/Fuel_injection
November 19th, 2014, 11:34 AM | #25 | |
https://www.ninjette.org/forums/showthread.php?t=202942 |
November 19th, 2014, 12:00 PM | #26 | |
It was suggested that he crank a bit longer before letting up on the button, and try backing the choke off some and/or opening the throttle while cranking. Not sure if that solved his problem or not. |
November 22nd, 2014, 10:17 AM | #28 |
Join Date: Feb 2013 Motorcycle(s): Ninja 250 (2001) Posts: 135
As a fellow sufferer of carburitis, I feel your pain. My bike has trouble starting after sitting for two weeks, and past three weeks its almost impossible to start (yes, I'm a terrible motorcycle owner). I've had success with rolling it into some sun, cranking for short bursts (about 5-7 seconds) with full choke until it starts to fire and stall (with 30 second rests between each round of cranking), and then feathering the throttle verrry lightly while cranking, until it eventually runs with choke. As soon as it will run with choke, put it in gear and putter around for 5 minutes
Instead of ripping out the airbox, consider n4mwd's airbox mod -- it really simplifies the process of getting the carbs on and off. For me it changed the process from a 2 hour ordeal with lots of cursing to a 20 minute project (with recreational cursing). Good luck, fellow carburhater! May the force be with you. |
November 22nd, 2014, 10:40 AM | #29 | |
I notice yours is about the same age as mine and shows the same characteristics. I will go through the fine specs and see if anything changed in the jetting or plumbing after our model. Since newer bikes regardless of mileage seem better reading the carb threads on here. I am also going to lift the needles 1.5 mm I have removed the carb heater plumbing but that obviously doesn't affect starting because the coolant is cold at that point anyway Meanwhile the carbs are off (the hard way) and I am summoning up the will to strip them again Alex.s Yes mate, I completely went through the valve clearances when I did the head gasket they are fine. |
November 22nd, 2014, 12:05 PM | #30 |
The pictures in n4's thread don't seem to be loading for me, so here's a link to a similar mod, so you can see what's actually being done. In this version they actually remove the airbox from the bike before sawing the battery box off, which just adds way too much hassle -- using string or steel wire is way faster.
November 27th, 2014, 07:09 AM | #31 |
Join Date: Apr 2013 Motorcycle(s): 2005 Ninja 250, 2006 SV650N Posts: 642
Yeah I feel you on that. If I sneeze wrong my carbs get clogged but it's almost always because I run the tank too low. Fortunately I have pods so removing the carbs takes 5 mins.
January 10th, 2015, 07:41 PM | #32 | |
January 11th, 2015, 02:35 AM | #33 |
The ninjette is currently stored in friends shed 200 miles away with the carbs off since I didn't have time to work on it during the house move.
I will get it running soon and take it to a dealer friend to sell for me. then I will join the ex ninjetters forum with some kind of V twin in the 500-800 bracket. |
Jacket Alternative | Ninja Rob | Motorcycle Gear | 21 | January 23rd, 2015 10:19 AM |
Alternative to replacing jets? | red5 | General Motorcycling Discussion | 1 | October 16th, 2013 08:41 PM |
Alternative to Photobucket | Jiggles | Off-Topic | 25 | May 30th, 2013 10:16 PM |
An alternative clock | Alex | Off-Topic | 11 | January 26th, 2011 08:06 AM |
An alternative to removing the snorkel | irishjohn | 2008 - 2012 Ninja 250R Tech Talk | 3 | September 1st, 2010 05:25 PM |
