August 13th, 2009, 01:22 AM | #1 |
Join Date: Dec 2008 Motorcycle(s): 09 ninja 250 Posts: 42
BEET 265cc kit
So ive saved up enough money for the 265cc kit from BEET. But before i go ahead and purchase this , is there any mods i should do along with gaining 15 more cc's? besides re-jetting , air filter etc. My other question is will a exhaust made for the EFI 250 work for a carbed 250 without any negative results
By the way the kit costs 480 about the price for a exhaust. |
August 13th, 2009, 05:15 AM | #2 |
old git
Join Date: Mar 2009 Motorcycle(s): BMW K1300S Posts: 479
I would be asking my self if an increase of 15cc is worth all the hassle
Steve
Some mistakes are too much fun to make only once. |
August 13th, 2009, 06:37 AM | #3 |
265cc?? |
August 13th, 2009, 04:20 PM | #4 |
MOTM - Sep '18, Feb '16
You may want to get the Adjustable cam sprockets from APE. They will allow you to get a little more and the BRT_TIS ignition would be a good idea if you want to really get into it . Have you thought about head work? And I don't mean the one on your shoulders.
September 16th, 2009, 04:59 AM | #5 |
n00b
Join Date: Sep 2009 Motorcycle(s): 09 250r Blue Area P, Factory Pro Jet kit, woodcraft rearsets, Galfer SS brake lines Posts: 19
its only a 6% increase in engine size. dont get me wrong im right there with you on trying to squeeze as much out of the 250 as possible and i looked into that kit as well but its so much of a hassle and a huge expense for such a small increase. i would build the head up first. cams valve job ext.
September 16th, 2009, 06:58 AM | #6 |
would only make sense if trying to cheat in a 250 racing class - where every little edge helps
September 16th, 2009, 03:23 PM | #7 |
I run in the 350 class at Maxton and Drag racing where it dose not matter. So it would not matter if I went up 15cc in displacement. These engines are a piece of cake to get the pistons out of . And boring a block is cheep enough. I need pistons so I can get stock size from JE . But I may have to buy 4 or look for the bigger ones from Beets. Dose anyone know what the compression ratio is?
Last futzed with by Racer x; September 16th, 2009 at 06:47 PM. |
September 17th, 2009, 11:42 PM | #8 | |
It could cheat the lower HP requirement of some license types (in other countries), it could cheat the insurance co to keep you in a lower price bracket, it could give you a better balance of fuel economy and performance compared to a bigger bike, it could give you more passing power on the street without having to go too far (with a more powerful bike), etc |
September 18th, 2009, 05:44 AM | #9 | |
Beet Camshaft Info-Anyone know how to translate pdf | tubarney | 2008 - 2012 Ninja 250R Tech Talk | 98 | October 9th, 2020 05:03 PM |
Installed Nassert Beet 320mm Front Rotor today | mania | 2013 - 2017 Ninja 300 Tech Talk | 12 | February 12th, 2014 05:22 PM |
BEET swing arm, where can I purchase online? | Dr.Ninja | Items Wanted | 2 | April 19th, 2013 06:28 AM |
Head Specs for use with Nassert Beet Cam | fordendk | 2008 - 2012 Ninja 250R Tech Talk | 9 | April 17th, 2013 02:36 AM |
