Old August 12th, 2009, 01:21 PM   #1
25ERic
25ERic's Avatar
Motorcycle(s): 2009 Ninja 250R SE
HID Flicker
Just installed my HID kit but they flicker / pulse with the RPMs of the engine. I know the kit is good because I took it off my car and put it on the bike. Worked fin on the car but has a slight flicker on the bike. Any ideas on what is causing it and how to fix it? I didn't upgrade my fuse as my low and highs work fine with the stock one.
25ERic is offline   Reply With Quote
Old August 12th, 2009, 03:15 PM   #2
randomwalk101
self wrencher
randomwalk101's Avatar
connection not solid
Old August 12th, 2009, 04:51 PM   #3
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Welcome Eric! Be sure to check your connections like John said, and if that doesn't work, come back and let us know
Progrip tank pad, blue rim stripes, blue Pazzos, Roaring Toyz lowering kit, Puig DB in dark smoke, Cortech sport tail, super mini tank, and saddlebags, OES swingarm spools and Intuitive frame sliders
Old August 12th, 2009, 07:21 PM   #4
ScorpionNinja
ScorpionNinja's Avatar
Did you check to see what our Bikes STOCK light bulb type is, and get the HID type/equal?
Old August 13th, 2009, 06:21 AM   #5
25ERic
25ERic's Avatar
The stock bulbs are H7 and that is the kit that I bought. I am using the stock headlight plugs to power them. Do you think I should use a different ground such as the frame?
Old August 13th, 2009, 02:01 PM   #6
noche_caliente
Eric, I didn't have to use anything different on mine. Did you make sure the connection to the ballast is secure, along with the connection to the light? Are both the high and low beams flickering or just the low beam?
Old August 13th, 2009, 02:31 PM   #7
ScorpionNinja
connection issues? well i dont have a HID kit on my bike, but if you can SOLDER the wires together... id do that if i were you! plug ins for wire connections... i never Trust those! Solder good for electronics is 60/40, 60%tin, 40%lead... and has a FLUX core! Thats the kind i used when i used too Race my 1/10scale RC truck in 96" a Team Losi XXT!!!
So i know how to solder and stuff. heh
HID Headlight Flicker Scattcatt 2008 - 2012 Ninja 250R Tech Talk 5 August 13th, 2013 05:28 AM
