December 27th, 2013, 11:40 PM | #1 |
Piston to valve and head clearance issue.
This is what happens when you decide to chance it and not clay the motor before assembling
Currently trying to figure out the issue. I don't know of anyone else running the 265cc 12.5:1 Wiseco Pistons. valve adjustments good, single base gasket and single head gasket were new. Head was not shaved nor was the the cylinder block. Wiseco hasn't been much of help so I'll try calling them again next week. Here's where the piston is hitting the head along with the obvious exhaust valves: stock 62mm 11.6 piston vs 64mm 12.5 piston
HalfFast Racing Team Serving Greater Houston Area Riders:WFO Riders MotoHouston HPC CMRA Ride Smart Fastline Lone Star Track Days Last futzed with by cuong-nutz; December 29th, 2013 at 09:27 AM. |
December 28th, 2013, 04:45 AM | #3 |
It seems that the piston has some tolerance's errors from machining.
Hopefully, the manufacturer will replace it for you.
December 28th, 2013, 07:16 AM | #4 |
Board Member
I am running those pistons. No issues so far.
December 28th, 2013, 10:10 AM | #5 |
Mike, by chance would you happen to have the build/run number of your pistons?
It's the last line of numbers and letters on the left box. The last part of the number should be 4 numbers and a letter which is the same as stamped on top of your piston. Mine is 6331K although the K is not printed on the label.
December 28th, 2013, 10:24 AM | #6 |
Join Date: May 2013 Motorcycle(s): honda crf230l & 2013 ninja 300se wife has Honda crf230l & honda cbr250r repsol Posts: 222
Dumb question. Are the pistons facing the correct direction? What direction is the arrow supposed to face engine front or back as the pistons don't look symmetrical?
December 28th, 2013, 10:44 AM | #7 |
Yes, they are facing the correct direction: arrow towards exhaust.
December 28th, 2013, 11:38 AM | #8 |
Board Member
6331K. Arrow toward exhaust.
I had a picture of my pistons to confirm....how can you tell its hitting without having done the clay method? |
December 28th, 2013, 12:29 PM | #9 |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
did you make sure timing was correct? Might be why yours are hitting and mgentz arent
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
December 29th, 2013, 02:01 AM | #10 | ||
Is it possible to have stretched connecting rods or somehow damaged my connecting rod bearings?
December 29th, 2013, 07:19 AM | #11 |
Board Member
Did the motor spin freely by hand before you started it? I can see where it is hitting the head but the valves look ok in the pics.
I will be pulling my head soon and I will check for this issue as well. |
December 29th, 2013, 09:25 AM | #12 |
The motor spun freely by hand and I couldn't feel anything binding or holding the piston up.
December 29th, 2013, 09:49 AM | #13 | |
Also arent the piston numbers from yours and mgentz different?
December 29th, 2013, 01:48 PM | #14 | |
Piston numbers match up. I verified it with the photos he took in his build thread. http://www.ninjette.org/forums/showp...&postcount=146 At first I thought Mgentz cleaned up the combustion chambers and deshrouded it but his combustion chamber is still stock in shape.
December 29th, 2013, 01:52 PM | #15 |
Join Date: Oct 2013 Motorcycle(s): gsxr 750, sv650, 250 ninja Posts: 110
do any of you guys have the piston to valve clearance with the stock pistons, i'd like to know before i tear mine apart, thanks
December 29th, 2013, 01:57 PM | #16 |
also did you have either the head or cylinder decked, if so that might cause your clearance problem
December 29th, 2013, 10:17 PM | #17 | |
Clayed it and got some weird results so I'm going to try it again tomorrow. What kind of clearances should I be getting? Piston #1 Exhaust 2.25mm/2.27mm Intake 2.01mm/1.95mm Piston #2 Exhaust 2.28mm/2.15mm Intake 0.70mm/0.80mm Definite piston to head contact.
December 29th, 2013, 10:22 PM | #18 | |
Join Date: Mar 2012 Motorcycle(s): Ninja 250r 2010 SE Posts: 573
Can't understand how you didn't smash everything into a thousand pieces. Conrod's have a bit of wobble, this is probably what saved you. For some reason your valves are deeper than mine. You can see mine sit almost flush with combustion chamber. I had barely minimum clearances. Leave your pistons alone and de-shroud that chamber. Might as well gain power than lose it right? Let us know how things go. |
December 29th, 2013, 10:27 PM | #19 |
1.6 mm - intake
2.0 mm - exhaust These are minimum. Piston 1 is good. Plenty of clearance on that baby. I would double check piston 2. Then if need be, fly-cut that bitch |
December 29th, 2013, 10:51 PM | #20 |
Definitely will have to cut back that area on the head. HOPING when I reclay #2 piston that the intake checks out. I'm still boggled as to why I'm getting that low of a clearance there.
I need to pick up some more dremel bits.
December 30th, 2013, 04:28 AM | #21 | |
The intake valves of cylinder #2 may be abnormally low, but the piston to head contact shouldn't have never happened, unless that piston is defective, as I presume. The last thing you want is to end up with different compression ratios in both cylinders. Any play in the bearings means higher readings of clearance, always.
December 30th, 2013, 04:58 AM | #22 |
Board Member
I'm with them. Something odd going on with #2. However, both pistons are hitting right? If I have time this week I will pull mine apart to show. Could there be anything wrong with the cam?
December 30th, 2013, 03:26 PM | #23 | |
Yep, both pistons are hitting the head. I don't think anything is wrong with the cams either but I'll measure them and strip the heads again.
January 2nd, 2014, 08:05 PM | #24 |
I pulled the pistons out earlier and found out that I had a bur on the edge of #2 skirt that left a good scratch on the cylinder wall. Hopefully the rings and wall are still salvageable.
January 2nd, 2014, 08:31 PM | #25 |
Board Member
I was always instructed not to reuse rings. Sux.
January 7th, 2014, 05:51 AM | #26 |
Board Member
updates????
January 7th, 2014, 11:30 AM | #27 |
I brought my junk over to a bike builder/racer and it looks like one of my pistons was cut wrong. He showed me that the compression heights are different between the two pistons. I think he might have not have seated one piston all the way in the pin hole so I have to go home and verify them both with each other and with the stock ones. Method used: Attach the two pistons together sharing the piston pin and compare.
The guy also noted that it wasn't my skirt that caused the scrape but possibly a ring end or something got lodged inbetween the rings since the scrape goes all the way up where the rings sit. This is definitely one biggest learning experience I have had with a motor build.
January 7th, 2014, 03:21 PM | #28 |
So, compression height is all the same between the both Wiseco and stock pistons. hmm.
January 7th, 2014, 03:55 PM | #29 |
Board Member
I think its the way the done is cut. Look at the difference between your pistons and je domes.
January 7th, 2014, 04:22 PM | #30 |
MOTM - Sep '18, Feb '16
This is a shot of the top of a std bore 13 to 1 piston. In the back ground is 13 to 1 and 12.5 to 1. Both seem to have the same room for valve clearance. The 13 to 1 pistons have a dig out in the center for the spark plug.
13.5 to1 only comes in 64 mom.
January 7th, 2014, 05:16 PM | #31 |
That's the only thing I can think of. The angled cut was probably started too soon for the squish band for the exhaust side.
I measured the squish angle for the head and pistons and Exhaust is about 19* and intake is 15*.
January 9th, 2014, 03:34 PM | #32 |
I tried calling Wiseco again but powersports tech was already closed for the day so I left a message via Wiseco website putting as much information as possible. Bob Defranco(sp?), Wiseco street bike parts manager, called and left me a voice message stating that he wants to send me two new pistons. He saw the pictures I linked in the message and says that the pistons I have were from an early production run which they have made revisions to the design since then addressing the issue I'm having. Looks like somehow some from the early batch made made it out to the market. Lucky me :/ He asked that I call tomorrow and speak with the returns department so they can make good on the parts.
@mgentz I know you have the same batch as I do but I'll give Bob a heads up about you having the same batch of pistons as me. I'll shoot you a PM with my cell phone in case you want to get in touch with me faster.
January 9th, 2014, 03:41 PM | #33 | |
January 9th, 2014, 03:51 PM | #34 |
I didn't mention it but I'll give him a call back tomorrow. My last resort was to tear the whole motor down again to reinspect all bearing clearances to rule out any error on my end. It's a good thing I didn't have to do it. That saved me some more time and money. Maybe they'll help me with a new headgasket and stuff.
Finally the build can progress again!
January 9th, 2014, 03:54 PM | #35 | |
January 9th, 2014, 06:00 PM | #36 |
The scratch could be caught with my fingernail.
Seems like there are other Wiseco pistons with the same issues: http://www.ebay.com/itm/10-Kawasaki-...e94600&vxp=mtr Take a look at the photo of the piston head. I am just in shock.
January 9th, 2014, 06:29 PM | #37 | |
January 9th, 2014, 07:01 PM | #38 | |
Board Member
January 10th, 2014, 01:41 AM | #39 |
Here's the scratch:
crappy cell phone picture. :/
January 13th, 2014, 01:35 PM | #40 |
doesnt look deep but if you can catch it with a finger nail might be bad.
Any update with the company and see if they can help?
valve clearance | sharky nrk | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 18th, 2014 06:19 AM |
Should I do the valve clearance inspection myself? | nickjpass | The Ex-Ninjetters Lair | 13 | June 13th, 2014 12:50 AM |
What is the Optimal Valve Clearance? | krolinked | 2008 - 2012 Ninja 250R Tech Talk | 2 | March 15th, 2013 02:25 AM |
valve clearance specs | dotsony | 1986 - 2007 Ninja 250R Tech Talk | 20 | March 17th, 2011 02:46 PM |
valve clearance??? what are they supposed... | ecannon1 | 1986 - 2007 Ninja 250R Tech Talk | 3 | May 20th, 2010 10:41 AM |
