February 12th, 2012, 07:14 PM | #1 |
Join Date: Feb 2012 Motorcycle(s): Road star bagger, KZ400 bobber, kz305 cafe racer, '94 ninja 250 cafe project, vfr750 Posts: 17
Valve adjustment Issue
So tried adjusting the valves on my new-to-me '94 with 8k miles.
Problem: even backing adjusters all the way out I can't get the feeler gauge between cam and rocker. Is there something I'm doing wrong or is this as bad as I'm afraid of (valves beat into seats)? |
February 12th, 2012, 07:35 PM | #2 |
http://faq.ninja250.org/wiki/What_is...t_procedure%3F <-- Did you do everything by the book? Your positive your cam lobe is in the right position? Correct feeler gauge sizes?
Sorry if those questions were stupid... just making the obvious is out of the equation. |
February 12th, 2012, 07:42 PM | #3 | |
Yes, followed direction, I'd done valves on a few other bikes so familiar with basic idea. Yes cam lobe position pointing so rocket is at loosest position. The rockers will move when I loosen them up so they are not always under pressure. Yes used correct gauge. |
February 12th, 2012, 07:54 PM | #4 | |
February 12th, 2012, 08:56 PM | #5 |
Milkshake Drinker
Join Date: Aug 2011 Motorcycle(s): 2007 Orange DRZ400-S, 2005 Ninja 250 & Custom Thundercunt Dirt Chopper Posts: A lot.
It's far more likely you messed up. If the bike runs normally, you probably don't have any major issues. If you loosened the lock nut and unscrewed the screw all the way, you would have enough clearance that the rocker would slide right out (it's not attached to anything.) if it moves when you touch it, you're not sticking the gauge in right.
Posted via Mobile Device |
February 12th, 2012, 09:30 PM | #6 |
Make sure you're using the right feelers, the specs are in millimeters, not inches.
February 14th, 2012, 06:25 PM | #7 |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
actually this has about happened to me. i had backed out the rocker arm and yeah i could barely get the mid range of clearance. Is it possible to run out of adjustment?
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
February 14th, 2012, 07:34 PM | #8 |
Valve adjustment | ninjaryda | 1986 - 2007 Ninja 250R Tech Talk | 6 | April 6th, 2013 06:02 PM |
Valve adjustment | blink | General Motorcycling Discussion | 7 | February 21st, 2013 01:41 PM |
Valve Adjustment | fredhsu | 2008 - 2012 Ninja 250R Tech Talk | 7 | August 7th, 2012 03:57 PM |
Valve adjustment ?s | Jewtoys | 2008 - 2012 Ninja 250R Tech Talk | 5 | August 1st, 2012 08:47 PM |
Valve Adjustment-Really Tight adjustment screw? | mikesova | 1986 - 2007 Ninja 250R Tech Talk | 5 | May 2nd, 2010 04:57 AM |
