July 21st, 2015, 01:50 PM | #1 |
Join Date: Jun 2015 Motorcycle(s): 98 Ninja EX250r Posts: 26
Trying to wire a cig lighter for a cell phone
Well really it's a 12 volt with an in line fuse and wired stright to the battery and the usb (rated for 12v) insert thingy lol lights up and when I plug my cell into it it will bearly charge and and show its charging(lighting bolt) but stop showing it after a few seconds. But if I unplug it turns the screen on like it was unplugged...... any help
July 21st, 2015, 02:12 PM | #3 |
Yes
July 21st, 2015, 02:14 PM | #4 |
Track Clown
MOTM - Sep '15
what kind of 12v did you instal?
is the bike running? |
July 21st, 2015, 02:27 PM | #5 |
Ok this is weird I tried anot her 12v usb adapter and now it's charging fine.... both r duel usb ports and both rated the same...... anyway shes working and yeah tried with the bike on and with a few differant fuses stared with a 15 and 20 and 25 and left the 20 in their but I'll probably put a 15 in it
July 21st, 2015, 02:28 PM | #6 |
Oh and the 12v cig lighter u can get at Walmart with a cover. It's weather proof
July 21st, 2015, 10:45 PM | #7 |
I have one on my bike....it's a USB plug and it has these arrow lights on the outside...I keep it disconnected (via a disconnect on the ground wire) until I need to use it so no extra draw on the battery.
July 22nd, 2015, 04:23 AM | #8 |
Mine doesn't have light so it won't draw with nothing plugged in but I still just take out the usb plug. I still gotta gigure out how I wanna run the power cord
July 22nd, 2015, 09:21 AM | #9 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
I wired mine to the instrument light circuit... USB chargers will only draw 500mah at peak, that's 6W, plenty of room on the circuit for that, however, I found the USB adapter vibrates out of the plug real easy, and had lots of intermittent issues just like you. To test, I ended up taping the USB adapter onto the plug to assure solid contact - that worked.
Next step is to take one apart and built it into a water proof case so no cig lighter adapter, just a USB plug... One day, when I have time...
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
July 22nd, 2015, 01:50 PM | #10 | |
EX500 full of EX250 parts
If you don't need the lighter socket for something else, I recommend just getting a hardwire USB port (this is the first example I found on Google). They're usually smaller, and you don't have to worry about parts vibrating loose or getting lost. Note that the voltage regulator used in these 12V-USB adapters will always be drawing a little bit of current, even if you don't have a USB device plugged in. It's not going to drain your battery overnight or anything, but you wouldn't want to leave it hooked up to a bike in storage.
July 22nd, 2015, 03:14 PM | #11 | |
MOTM - Oct '15
Looks like we're both partially right. Most phones can draw just more than 1A @ 5V. Tablets can draw up to 2.5A @ 5V. Since the input is 12v > 12/5 = 2.4 (ratio). 1A/2.4 = 0.42A. So, even on full draw on a phone, the bike will only experience a ~500mA draw, which the circuit can easily handle. The line I tapped into actually ran an APRS setup (back before we had things like WAYZ and Find My Friends) drawing 2A for 4,200 miles across the western states, so I know it will charge a cell phone just fine. It's neither here nor there however, since the simplest answer is to just hook up a direct wire to the battery, and I love that USB power converter you posted.
July 22nd, 2015, 04:26 PM | #12 |
Certified looney toon
MOTM Jul '13, Jul '14
I picked up the BurnsMoto USB socket that also has a little boot to go over the plug to make it weather proof when plugged in. In the two (three?) years I've had it installed, never had trouble with the plug working itself out. That little thing holds the plug securely!
July 23rd, 2015, 09:38 AM | #13 |
MOTM - Oct '15
ooo, dems are nice Nevada Wolf!
July 24th, 2015, 03:34 AM | #14 |
Join Date: Jul 2015 Motorcycle(s): 2001 Ninja 250, 2019 Harley Ultra Classic, 2001 Suzuki SV650 Posts: A lot.
MOTM - Jan '16
I just picked up the USB adapter for my battery tender. Just plugs into the cable when I unplug the battery tender. IIRC it was $5 or $6 on amazon when ordering a few other items.
July 24th, 2015, 04:18 AM | #15 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
I ran a blue sea dual usb on the left, and a lighter socket on the right.
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
July 24th, 2015, 08:48 AM | #16 |
MOTM - Oct '15
Those look real good! Took me some time to find them, so super good!
July 24th, 2015, 08:53 AM | #17 |
Ah heck, wish I'd seen yours, Jason, before doing mine. i like that placement a LOT better.
July 24th, 2015, 06:34 PM | #18 |
MOTM - June '15
they just barely fit up there, but it worked out really well for the long trip i did.
July 29th, 2015, 06:29 PM | #19 |
Join Date: Jul 2015 Motorcycle(s): TRX 450 R Quad, no street Posts: 20
Do you guys use full 3 foot wires? or short 3 inch wires and a mount close to your power? I couldn't stand the extra 2.5 feet of wire flopping...
[motorcycledaily.com] - AMA says, ?Put away the phone,? for National Cell Phone Court | Ninjette Newsbot | Motorcycling News | 0 | June 27th, 2014 08:20 AM |
Cell Phone Mount | reroka | 1986 - 2007 Ninja 250R Farkles | 8 | May 30th, 2014 03:51 PM |
Cell phone solution | Racer x | Off-Topic | 16 | November 26th, 2012 10:33 AM |
Her last call was from a new cell phone!!! | g21-30 | Off-Topic | 9 | September 27th, 2012 03:05 PM |
Does anybody here not have a cell phone? | Heed | Off-Topic | 10 | August 20th, 2012 05:36 AM |
