Old December 20th, 2011, 09:35 PM   #1
CmichRider
CmichRider's Avatar
Motorcycle(s): 2000 Ninja 250
Front fairing bolts for pre-gen
Hey guys, if anyone has a set of all the bolts needed to attach the front fairing correctly, I'd like to take them off your hands! I bought a front fairing off ebay a while back, and now that my bike is in winter storage, I'd like to install the fairing. Let me know what's up!
CmichRider is offline   Reply With Quote
Old December 20th, 2011, 09:48 PM   #2
Here's the diagram of what you're looking at. clicky
The part you want is part 92150-1553 ($5.17). That's the bolt, which appears to be an M6 that is 18 mm long. Don't get any that are longer than that!
You're probably also going to want part number 92143-1226 ($7.29). That's the collar for the bolt.
check a local hardware store to see if you can get the bolt cheaper.
Old December 20th, 2011, 10:45 PM   #3
Skippii
Milkshake Drinker
Skippii's Avatar
Yeah....I think I paid 7 cents each at Ace Hardware and True Value hardware.
This could be trickier to buy...but you can make them yourself for pennies each if you have one. Find a washer the right size diameter. Just cover the one you have in vaseline, and press it into Bondo or putty or whatever to make a mold. Remove it when the bondo has set, drop in the washer, and pour in some epoxy. I do this kind of stuff all the time. Works great. I also cast rubber parts with hot glue.
"What a sweetheart."- ninja_sleeper to me
Old December 20th, 2011, 10:56 PM   #4
Skippii
Milkshake Drinker
Skippii's Avatar
Here you go:..course, it doesn't help if you don't have one already. I might have a spare somewhere.
http://www.ninjette.org/forums/showthread.php?t=93072
Old December 21st, 2011, 07:16 PM   #5
CmichRider
CmichRider's Avatar
Isn't that for the rubber pieces the gas tank lays onto? I hadn't realized that the only extra bolts I needed are the ones that go "into" the gas tank. I don't have the side fairings, or the bottom, on the bike right now, so it's been a while really since I saw what was needed. I've been running nekkid for a while .
Thanks for the help though guys! I'll be sure to run out to the hardware store and grab a bolt that fits for cheap. I bought a blue fairing to go on a green bike...so one or the other, or both, will be painted. I'll post up some pictures once the project gets started!
Old December 22nd, 2011, 02:24 PM   #6
Skippii
Milkshake Drinker
Skippii's Avatar
I was just explaining the process I use to cast stuff, if you wanted to make new collars.
Posted via Mobile Device
Old December 22nd, 2011, 03:41 PM   #7
CmichRider
CmichRider's Avatar
Ah I see. Seems pretty simple really, compared to how difficult you could have made it.
Fitting a new gen front wheel on a pre gen? thumper64 1986 - 2007 Ninja 250R Tech Talk 13 November 6th, 2013 02:44 PM
WTB front upper pre-gen fairing Daks Items Wanted 0 March 26th, 2013 07:42 PM
WTB: Pre-gen upper front fairing drdriftking007 Items Wanted 4 May 15th, 2012 06:25 PM
09 Front fender on Pre Gen? streetracer744 1986 - 2007 Ninja 250R Farkles 6 November 1st, 2011 05:18 PM
FS Pre Gen Front Fender, Back Fairing and Right Side Fairing. 20ninja03 Motorcycle-related 3 August 11th, 2011 10:02 AM
