Go Back   ninjette.org > 2013 - 2017 Ninja 300 > 2013 - 2017 Ninja 300 General Discussion
Old May 24th, 2016, 10:51 AM   #1
BDfromBC
Motorcycle(s): EX250-J
Question Exhaust header question??
I'm curious the difference between paying for a full exhaust on the 300 w/tuner and putting just the canister on a de catted stock header?
Is this exactly the same result? Or do aftermarket headers actually have a wider diameter? Thank you for any input!!
I don't have my 300 yet I'm waiting for insurance to pay out for my stolen 250... I am interested in maximum output, but it needs to be bang for the buck also, so if I can save 2-300$ by buying only the slip on and decatting and welding it up myself I will do so. Thank you!
Im just planning ahead at the moment so I can do some budgeting
BDfromBC is offline   Reply With Quote
Old May 24th, 2016, 08:07 PM   #2
toEleven
Slower than you.
toEleven's Avatar
Motorcycle(s): CBR600RR, CB750, EX300 (半蔵)
MOTM - May '16
Quick measurements:
external diameter, stock header 29mm
external diameter, aftermarket header 31mm
Stock has a crossover, aftermarket doesnt. The routing is completely different. Should you expect exactly the same result? No. Will your plan produce more power than stock? Only a dyno will be sure.
My stock system wasn't weighed in pieces, so I don't know how it compares to the 281g (right) and 299g (left) of my aftermarket header pipes.
DISCLAIMERv1.0: There may be more info on the topic than this forum post. Conduct your own research.
If another thread is linked or quoted, go read it yourself.
toEleven is offline   Reply With Quote
Old May 24th, 2016, 11:17 PM   #3
BDfromBC
Originally Posted by toEleven View Post
Quick measurements:
greatly appreciated! Pretty much all the info I needed!
Old May 28th, 2016, 02:34 PM   #4
TP Ninja
Motorcycle(s): 300 Ninja
The performance increase isn't worth the expense. If you want a different sound, get a can, such as from Yosh or Leo Vince.
TP Ninja is offline   Reply With Quote
Old May 28th, 2016, 02:42 PM   #5
cbinker
cbinker's Avatar
that is all relative to each individual situation. he may have extra money to use.
right now, if i had the money it would be worth the extra power gained.
TEAM ALFALFA
www.apexassassins.com
Old May 28th, 2016, 03:27 PM   #6
Hero Danny
Inline 4!!!
Hero Danny's Avatar
Yup. Also even though you may only see 4-5 horsepower increase, that's a BIG difference on such a small machine.
Be careful. Remember you are
invisible
Old May 28th, 2016, 03:59 PM   #7
BDfromBC
The question is not rather or not it's worth it, though I do appreciate the chiming in.
I more wanted to see a different in numbers from some seasoned folk.
I also worded the question sort of wrong,
If all circumstances were the same: tuner, and can.... (Yoshimura slip on, a decat, and tuner vs yoshimura r77 SYSTEM with tuner) k&n filter & no snorkel on both.
Say I get a 10% increase in power from the mods.
If the decat and slip on is only 9% I would take that route, as the difference is nill... (1%)
Old May 28th, 2016, 04:22 PM   #8
cbinker
cbinker's Avatar
here is a starting point to compare slip-ons to full systems.
http://www.twobros.com/sku/005-3890/...-TM-SO-14.html
TEAM ALFALFA
Old May 28th, 2016, 05:47 PM   #9
TP Ninja
I bet the hp increase is 2 at most. Look at the Revzilla website and the Leo Vince slip-on is actually down .5 hp from stock. Most slip-ons might give you 1 hp increase and maybe the Power Commander's good for one more but the 300 Ninja already runs great and doesn't need one. So $1800 for 2 hp? I'd trade in the beloved 300 Ninja for a Honda CB500F for that.
2 into 1 exhaust header options HoneyBadgerRy 1986 - 2007 Ninja 250R Tech Talk 21 January 11th, 2016 06:45 PM
Single Exhaust Header Shintoxica 1986 - 2007 Ninja 250R Farkles 5 September 12th, 2013 05:56 AM
08+ header question neo101288 1986 - 2007 Ninja 250R Tech Talk 10 February 23rd, 2013 07:16 AM
FS: NEW Area-P exhaust header Momaru Motorcycle-related 6 June 8th, 2011 03:02 PM
Header exhaust gasket B2FiNiTY 2008 - 2012 Ninja 250R Tech Talk 5 May 8th, 2009 08:03 PM
