August 25th, 2013, 03:44 PM | #1 |
Join Date: Apr 2013 Motorcycle(s): 2010 250r SE (without stupid tribal decals) Posts: 110
So I shimmed the needles today...
And now I don't know what to do. As in, I don't know how to check if I've done a good or bad job. I have a two bros slip on and I removed the snorkel, so I put two washers under each needle.
After I put everything back together (minus fairings) I turned it on and it sounded kinda boggy at first, but I have been playing around a lot with that knob on the left side of the bike that controls the idle, so I played with it a little more and now it sounds...I don't know how to explain it...not boggy but not super buzzy. To me it sounds and "feels" okay but I just wanted to make sure here first.
"It sounds like a lawnmower." "Shut up no it doesn't." |
August 25th, 2013, 04:48 PM | #2 |
Join Date: Jul 2012 Motorcycle(s): 2010 Ninja 250 2009 Ninja 250 Posts: 730
I set the idle after I been riding for a while and it's complelty warmed up. Setting it while it's cold never worked well for me
2010 Red Ninja 250 2009 Black Ninja 250 -If you ride like lightning,you're gonna crash like thunder- |
August 25th, 2013, 05:41 PM | #3 | |
Next, comes the synchronization of the carbs. Then, the adjustment of the idle rpms' after the engine is hot.
August 25th, 2013, 06:40 PM | #4 |
Well I took it for a test ride of about 10 miles and after it got warmed up it idled at about 1300-1500rpms. Also instead of almost bogging out when pulling from a light, it pulls off great!
And @Motofool thanks, I'll be sure to check out how to do that!
August 25th, 2013, 07:15 PM | #5 | |
http://faq.ninja250.org/wiki/How_do_...carburetors%3F
August 25th, 2013, 08:04 PM | #6 |
Also I forgot to add that my petcock was leaking fuel even though it was set to the "ON" position. It was only leaking small drops, but still. And what's the "PRIME" position used for? my bikes always been on "ON".
August 25th, 2013, 08:09 PM | #7 |
Prime is to intentionally drip fuel. This is helpful when you're taking the bike out of storage or have just changed main jets or cleaned the carbs and you need to fill the carb bowls in order to get the bike running.
Shimmed my needles, but didn't need to. | peteypetepeep | 2008 - 2012 Ninja 250R Tech Talk | 11 | April 10th, 2014 07:26 PM |
Shimmed my needles and discovered something | kaiserz | 2008 - 2012 Ninja 250R Tech Talk | 10 | June 6th, 2011 06:36 PM |
Shimmed the needles, running slower | atl-ninja250 | 2008 - 2012 Ninja 250R Tech Talk | 24 | July 19th, 2010 08:38 AM |
Shimmed Needles ? | overload | 2008 - 2012 Ninja 250R Tech Talk | 5 | October 26th, 2009 01:18 AM |
I shimmed the needles and.... :( | Gbug | 2008 - 2012 Ninja 250R Tech Talk | 12 | January 25th, 2009 09:14 PM |
