July 30th, 2009, 10:36 PM | #1 |
Join Date: Jun 2009 Motorcycle(s): 09' Ninja 250 (SOLD); 00' CBR 929RR Posts: 133
Looking to pull off fender
Searched the DIY, didn't find any information on pulling it off, I want to do a fender chop, but not sure if pulling off the entire thing is required or not.
July 30th, 2009, 10:40 PM | #2 |
do you have a bike that you've seen that you would like to copy? some methods require some disassembly, others don't.
http://www.ninjette.org/forums/showthread.php?t=964 |
July 30th, 2009, 10:46 PM | #3 | |
http://www.kawiforums.com/ninja-250r...tra-parts.html But pulled his off, however: is another cut I could make, the link however seems cleaner to me, I thought it might expose too much to the elements, but after a second look it seems fine, so if pulling it off is the way to go, can't seem to locate a diy. Mind you I have done shimming to the carbs so I have at least taken off the fairings/gas tank/seat so I've gotten that far at least... just how do I get the fender off |
July 30th, 2009, 10:54 PM | #4 |
lol... it's been so long since I've done mine, I forget.
take off the passenger seat and have a look around under there for bolts holding stuff on back there... that's what I did.. eventually, stuff will come off. you have a pm |
July 30th, 2009, 11:06 PM | #5 |
Join Date: Jun 2009 Motorcycle(s): 2007 Suzuki GSX-R750 Posts: 378
Take the tail section off and there are 4 bolts holding the fender on, I believe the tail light is also bolted in it...Its easy I did it a couple times becuz of illegal fender elim I had on there...Unplug you signals and everything..I sold my bike so I dont really have a reference anymore...But get the 2 tail section plastics off, look at the bolts disassemble and reassemble..
July 30th, 2009, 11:12 PM | #6 |
July 30th, 2009, 11:21 PM | #7 |
mmmm... I'm thinking you do. anyway, here's some pics that might help you with removing those pieces and your upcoming shimming.
http://www.kawiforums.com/1147643-post13.html http://picasaweb.google.com/kkim993/AirboxAndRejet# |
July 31st, 2009, 05:43 PM | #8 |
Mike, I'm pretty sure you do have to take them off, but it's pretty easy - not too much to worry about - you'll be fine!
How Many Can Pull A Tight U-Turn? | Purspeed | Riding Skills | 61 | June 9th, 2014 05:06 PM |
[visordown.com] - How to pull a wheelie | Ninjette Newsbot | Motorcycling News | 0 | October 11th, 2013 02:40 PM |
Tug and pull feeling | ortizj2289 | 2008 - 2012 Ninja 250R Tech Talk | 8 | August 5th, 2013 06:30 AM |
Would you/do you pull this move? | az3200 | General Motorcycling Discussion | 20 | June 16th, 2013 01:17 PM |
did I pull something loose or is this normal? | bluesinorbit | General Motorcycling Discussion | 14 | June 8th, 2011 03:24 AM |
