May 31st, 2022, 02:51 AM | #1 |
[webbikeworld.com] - 2022 Harley Davidson Sportster S [Specs, Features, Photos]
Click here for full story...
The 2022 Harley Davidson Sportster S: The Legacy Continues Contents Introduced last year and showcasing a new direction for the legendary American-made Sportster, the bike is largely unchanged coming into 2022. The Revolution Max 1250T engine is a liquid-cooled V-Twin putting out 121hp and a fat torque curve set to add a good stretch to your arms upon a full twist of the throttle. Running a reasonably fat tire both front and rear makes this the most muscular-looking Sportster. Harley Davidson always nails the details, and on the Sportster S for me, it is the Bronze touches. One of the few models in the* 2022 Harley model lineup that takes advantage of modern electronics, the Sportster S has selectable rider modes and lean-sensitive ABS and traction control. 3 color choices exist for the 2022 Harley Davidson Sportster S: Vivid Black, Mineral Green Metallic, and White Sand Pearl. The 2022 Harley Davidson Sportster S starts at $15,499 USD / $18,499 CAD. On this page: we’ve curated specs, features, news, photos/videos, etc. so you can read up on the new 2022 Harley Davidson Sportster S in one place. Model Overview </p>General Info
Main Specs
Competitors
2022 Harley Davidson Sportster S Specifications ENGINE Engine1,252 cc V-twin, Revolution® Max 1250TEngine Torque94 ft-lbBore x Stroke4.134 in. x 2.846 inCompression Ratio12.0:1 Fuel SystemElectronic Sequential Port Fuel Injection (ESPFI)StarterElectricExhaust2-into-1-into-2; catalyst in mufflerDRIVETRAIN ClutchTransmission6-speedPrimary DriveGear, 49/89 ratio CHASSIS FRONT FORK43 mm inverted fork with compression, rebound and spring preload adjustability. Aluminum fork triple clamps. REAR SHOCKSLinkage-mounted, piggyback monoshock with compression, rebound and hydraulic spring preload adjustability Brakes Frontradially mounted, monoblock, 4-piston caliper Brakes Rear*floating, single piston caliperFront Tires160/70R17 73V Rear Tires180/70R16 77V Fuel Tank Capacity3.1 galColorELECTRICAL IgnitionSpark PlugsHeadlightAll LED headlampTail LightLEDDIMENSIONS Length89.4 in. Trail5.8 in Rake30Wheelbase59.8 in. Ground Clearance3.5 in. Seat Height28.9 in Weight, As Shipped487 lb. WARRANTY WarrantyExtension 2022 Harley Davidson Sportster S Features All-new Revolution Max 1250T The next chapter in a century of legendary V-Twins is here. Revolution Max is a liquid-cooled powertrain with double overhead camshafts and variable valve timing: offering ample torque and an immediate powerband tuned to maximize rider control. High Mount Exhaust Inspired by the glory days of H-D flat-track racing, the pipes are crafted from corrosion-resistant 304-series stainless steel and engineered to deflect exhaust heat away from the rider’s legs and tail section. Classic Meets Modern: 4” Round Display Everything you need to know is housed in a Bluetooth -equipped, 4” round thin-film transistor LCD display: digital gauges, indicators, ride modes, and turn-by-turn navigation with the Harley-Davidson Choose Your Ride Mode Flick a switch and choose from 3 pre-programmed Ride Modes (Sport, Road, and Rain) or create your own custom mode — tuning your bike with a specific combination of power delivery, engine braking, Cornering Enhanced Antilock Braking System (C-ABS) and Cornering Enhanced Traction Control System (C-TCS) settings. Dual Purpose Powertrain The Revolution Max 1250T is a structural component of the motorcycle chassis, eliminating a traditional frame — which significantly reduces overall weight and keeps handling precise. This is performance you can feel, with the center of gravity low and the chassis super rigid. 2022 Harley Davidson Sportster S Photos 2022 Harley Davidson Sportster S Videos 2022 Harley Davidson Sportster S | First Ride: Don’t buy a Sportster S until you ride a Fat Bob: Links Harley-Davidson Official Websites Social Media Links The post 2022 Harley Davidson Sportster S [Specs, Features, Photos] appeared first on webBikeWorld.
[webbikeworld.com] - 2022 Aprilia SR GT [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 31st, 2022 01:47 AM |
[webbikeworld.com] - 2022 Honda CB500F [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 25th, 2022 07:42 AM |
[webbikeworld.com] - 2022 Honda Navi [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 25th, 2022 04:52 AM |
[webbikeworld.com] - 2022 Honda CBR600RR [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2022 07:51 AM |
[webbikeworld.com] - 2022 Suzuki SV650 [Specs, Features, Photos] | Ninjette Newsbot | Motorcycling News | 0 | April 28th, 2022 10:42 PM |
