August 11th, 2011, 10:28 AM | #1 |
exhaust issue i think?
last week my bike feel over on its right side due to a storm that came out of no where and now my right side exhaust has huge crack where the muffler meets the tubing. when i ride the bike it loses power at about 5,000 rpms and feels like its running flat on its face. i can hardly get it above 55 mph.
August 11th, 2011, 10:46 AM | #2 |
August 11th, 2011, 12:42 PM | #4 |
Pics?
August 12th, 2011, 09:13 AM | #5 |
well i tried the duct tape thing just for the heck of it and well it didn't work, the exhaust just found another path under the cone shaped guard. i will get some pics when the bike cools off a bit. oh and another thing i have a feeling my right side piston is shot or the rings need to be replaced, white smoke comes out of the exhaust for a bit and then stops after the bike has been running for a a while. anyone know where i can order some? thanks for the help guys
August 12th, 2011, 09:51 AM | #6 |
Smoker
You do know that the stock pipes have a seam on the bottom of the cone shaped area that actually has an opening, right? This lets condensation out. Before you go tearing the engine apart, have you checked to see if your plugs are fouled? If it was on its side, there is a very good chance that oil leaked up into the cylinders, fouling the plugs. Trust me, if your rings were toast youwould know, as the smoke would be constant and also be coming out of your crank vent too. And it wouldn't stop.
Having BTDT, my advice is to do this, in order: Pull the plugs and check for fouling (or just replace them with iridiums and never worry about plugs again) Bang on the side of the carbs to make sure your floats aren't stuck. The handle of a long screwdriver does well in this regard. Check oil level - you may have also gotten gas into your crank case, again normal from a bike being on its side. Sniff your oil (just open the fill cap and sniff). If it smells like gas drain and replace, along with the filter. Ride bike normally, all your problems are solved. |
August 12th, 2011, 10:17 AM | #7 |
Thanks for the advice jinx. I will check all the above as mentioned.
FS: Area-P solo exhaust bracket for Ninja 300 w/stock exhaust | c-dog | Motorcycle-related | 2 | September 12th, 2014 10:48 AM |
How to remove stock exhaust and install aftermarket Slip-On Exhaust System Ninja 300 | SON1C | 2013 - 2017 Ninja 300 Tech Talk | 4 | August 14th, 2014 05:45 PM |
Tyga full exhaust leak issue | 675Raisinator | 2008 - 2012 Ninja 250R Tech Talk | 11 | March 27th, 2012 12:32 PM |
[superbikeplanet.com] - Suzuki: Haslam's Wrist Issue Should Not Be An Issue | Ninjette Newsbot | Motorcycling News | 0 | May 11th, 2010 07:50 AM |
Have a lean issue with my bike, issue with coasting enricher. | twiggy2cents | 1986 - 2007 Ninja 250R Tech Talk | 7 | February 24th, 2010 06:54 PM |
