Old January 13th, 2013, 02:23 PM   #1
TBC
TBC's Avatar
Motorcycle(s): 2004 Ninja 250F
Cracks in Lower Cowling
For whatever reason, every time I go to fix/tweak something on the bike something is always broken .
Today I upgraded the horn and went to lube the chain, and as I looked down to put the center stand up I noticed something on the lower cowling was a little...off. I looked more closely and noticed that the back of the left side of the fairing is cracked in three or four places, right around where it meets the rear mounting point. Gah!!! I have no idea what happened - I would guess that it was either heat that made it brittle, or perhaps heating/shrinking from riding in cold weather, or maybe someone just kicked it one day. Who knows.
Anyways - I think I need a new lower cowling. I could repair it, but it just seems easier to spring the money for a new once. OEM ones seem to be around $350 new (ouch...) and ebay ones are give or take around $50-$100 (less ouch).
Any color suggestions? I'm going to go duct tape the one I have...
TBC is offline   Reply With Quote
Old January 13th, 2013, 02:39 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Old January 13th, 2013, 03:53 PM   #3
lgk
glue it back together before you duct tape it
Old January 20th, 2013, 12:45 AM   #4
http://www.ninjette.org/forums/showt...592#post625592
Old January 21st, 2013, 08:14 PM   #5
krolinked
Nerd
krolinked's Avatar
I use this stuff called plastex. Work pretty damn good if you do it right, and take your time.
http://www.plastex.net/How_To_Videos.php
Old January 21st, 2013, 08:58 PM   #6
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
That's what I have and love it
THE GOOD LIFE
cuz is offline   Reply With Quote
Old January 24th, 2013, 10:12 AM   #7
Wouldn't ABS cement do the same thing as Plastex? IIRC, it's basically just dissolved ABS plastic in acetone and the prep instructions for the part are almost identical. ABS is always black right? If so, I guess they don't use ABS (black, white, and clear are available). Other than that, it seems that the major difference is that they use powdered plastic and don't add the solvent until after it's in place. Perhaps I should source a cheese grater/blender/mortar and pestle/stone mill and dice up some plastic.
Old January 25th, 2013, 06:47 AM   #8
cuz
cuz
cuz's Avatar
http://www.ninjette.org/forums/showthread.php?t=42690
THE GOOD LIFE
Old February 10th, 2013, 09:09 AM   #9
Old February 11th, 2013, 09:39 AM   #10
TBC
TBC's Avatar
^ Yup, that's the ticket
Need help putting lower cowling back on IF13 2008 - 2012 Ninja 250R Tech Talk 9 September 12th, 2013 12:00 PM
09 Special Edition Right Side Lower Cowling (Fairing) abde1337 Items Wanted 3 July 22nd, 2013 10:48 AM
WTB Pregen lower cowling SabreValkyrn Items Wanted 0 June 25th, 2013 07:38 PM
