Old February 8th, 2013, 11:51 PM   #1
krolinked
Nerd
krolinked's Avatar
Questions on valves.
So I adjusted my valve clearances to the loosest possible while still being "In Spec" My engine is pretty loud. Will I cause any damage like this?
Both the Intake and Exhaust clearances are at their max clearances.
Also, I have Idle screws turned ALL the way in on my carbs, how do i know where they should be adjusted to? Bike currently idles, but is very laggy with throttle response.
Old February 9th, 2013, 12:56 AM   #2
cuong-nutz
cuong-nutz's Avatar
What mods, do you have on your bike? full exhaust, slip-on, stock intake, stock intake without snorkel, aftermarket oem style air filter? or Pod filters? Shimmed needles?
Generally 2.5 full turns back out from bottomed out is a good starting point for the idle mixture screws.
HalfFast Racing Team
Old February 9th, 2013, 02:57 AM   #3
krolinked
Nerd
krolinked's Avatar
Stock Exhaust, K&N Drop In Air Filter. 100 Main Jet, Factory Pro Needles middle position.
Old February 9th, 2013, 05:52 AM   #4
Originally Posted by krolinked View Post
.........My engine is pretty loud.........
Service and lubricate your cam chain tensioner (CCT).
Old February 9th, 2013, 08:49 AM   #5
krolinked
Nerd
krolinked's Avatar
I've got a manual chain tensioner because i broke my last one. It is taking up the slack so its i think the valves themselves making the noise.
Old February 9th, 2013, 11:57 AM   #6
100 main is way too rich for stock setup like yours. The drop in air filter doesn't make much difference
Old February 9th, 2013, 12:05 PM   #7
cuong-nutz
cuong-nutz's Avatar
When you said loud, what do you mean? Did you cover up the KLEEN air system?
Old February 9th, 2013, 06:37 PM   #8
tubarney
You only need a 98 main jet and no shims under your washers with a stock airbox with the snorkel still in. I have a dyno sheet to prove this.
Clean your shim buckets, my mates car engine was making a ticking a noise and it turned out to be dirty tappets.
Old February 10th, 2013, 11:40 PM   #9
krolinked
Nerd
krolinked's Avatar
I am having a world of problems with this bike.
I can only get it to idle, and no amount of throttle manipulation can get the bike to rev up any. Could the main jet affect it like this? I even put the stock needles back in an nothing.
Old February 11th, 2013, 07:05 AM   #10
cuong-nutz
cuong-nutz's Avatar
Are you positive that the diaphragms are not torn and all the jet and air orifices in the carbs are clean and clog-free?
Old February 11th, 2013, 10:38 AM   #11
it dies? or does nothing? did you connect the throttle cables?
Old February 11th, 2013, 04:22 PM   #12
krolinked
Nerd
krolinked's Avatar
It does not rev up. I am manually opening the butterflys with my finger. It will die if i slam the throttle shut, but does not rev up when i open it.
Diaphrams are not torn
Measuring valves Nemesis 2008 - 2012 Ninja 250R Tech Talk 75 August 4th, 2019 06:59 AM
How to know you need your valves adjusted? Hero Danny 2008 - 2012 Ninja 250R Tech Talk 42 July 26th, 2014 06:39 PM
just adjusted Valves. ... Fakker 1986 - 2007 Ninja 250R Tech Talk 7 July 2nd, 2014 10:28 AM
valves keep going out of spec. Causes? Monkeytofu 1986 - 2007 Ninja 250R Tech Talk 7 September 5th, 2012 07:16 PM
Valves Job - lots of questions indr 2008 - 2012 Ninja 250R Tech Talk 14 November 24th, 2010 08:08 PM
