August 9th, 2009, 07:16 PM | #1 |
two wheel addict
Join Date: Apr 2009 Motorcycle(s): 94 xlh 883, 1984 kawi gpz money pit Posts: 556
Rubber Well nuts
Has anyone noticed that the stock rubber nut wells (they are used on parts of the fairing and windscreen) seem to deteriorate rather quickly.
I was just wondering if anybody has used some aftermarket ones from the hardware store that seem to do a better job, Im not sure if its just the material that Kawi had outsourced was shoddy or not. |
August 9th, 2009, 07:18 PM | #2 |
everyone seems to have problems with those and it doesn't seem to be a problem with only a single manufacturer.
August 9th, 2009, 07:41 PM | #3 |
dirty old man
Join Date: Nov 2008 Motorcycle(s): Blue '08 Ninja 250 Posts: A lot.
I have lost one and one of them falls out everytime I take the left side off. I had thought about getting new ones the next time I have the fairings off, which, hopefully is not very often.
nb
Death tugs at my ear and says, "Live, I am coming." -Oliver Wendell Holmes, Sr., poet, novelist, essayist, and physician (1809-1894) www.friendsofsanonofre.org |
August 9th, 2009, 08:12 PM | #4 |
Join Date: Nov 2008 Motorcycle(s): '09 Ninja 250R Posts: 518
Yep, i have 3 that are broken. I just have to reach my hand inside the fairing to hold them when taking off or putting the fairings on.
August 9th, 2009, 09:45 PM | #5 |
have you guys seen this thread? http://www.ninjette.org/forums/showthread.php?t=26251
August 10th, 2009, 12:15 AM | #6 |
Ramen Rider
Join Date: Jan 2009 Motorcycle(s): 2015 BMW R1200R, 08 Honda VFR800A (sold), 09 Ninja 250R (sold) Posts: A lot.
here is where i bought mine: http://www.desmoparts.com/ducati/wellnut/wellnut.htm
ours are supposedly the m5 nuts. i bought a bunch but i haven't taken my fairings off again since i got them, so i can't confirm if the fit or not. kkim ordered some with me, and i gave some to istreefitty when he bought my bike. they feel like they will last longer than the stock ones, but who knows. |
August 10th, 2009, 05:00 AM | #7 | |
August 10th, 2009, 07:03 AM | #8 |
Bike Thrasher
Join Date: Apr 2009 Motorcycle(s): 2008 EX250r Posts: 334
Funny you guy are talking about wellnutts. I found these yesterday but I refuse to pay $30 for them.
http://cgi.ebay.com/ebaymotors/Set-o...#ht_1615wt_895
Intuitive Sliders, Aftermarket pegs, Custom Paint, Seat Cowl, Tinted Screen, Aftermarket flush mounts, Wheel Tape, Fender Chopped, Stock Shortie Exhaust and Woodcraft ClipOns |
August 11th, 2009, 06:49 PM | #9 |
Join Date: Feb 2009 Motorcycle(s): 2008 Ninja 250 Posts: 24
I just replaced all of my hardware (screws, push rivets, well nuts) through http://www.bikebolts.com. Using coupon code '4forum20' to get 25% off makes the well nuts about 50cents each.
August 11th, 2009, 07:32 PM | #10 |
MOTM - Sep '18, Feb '16
I ordered a bunch from Cheap cycle parts. Like 5 or 6 bucks each . I thought It was because I take my bike apart so much.
June 2nd, 2011, 10:32 PM | #11 | |
I found 14 total rubber well nuts: 2x in the tail fairings under the passenger seat/solo sport cowl. 2x in the undertail, one of which requires removing the right-side passenger peg (you can leave your exhaust "floating") 2x in the RH lower fairing 2x in the LH lower fairing 2x in the windscreen 2x in the fairing stay under the windscreen/upper fairing (longer bolts from the bottom of the windscreen) 2x inside the upper fairing for the headlight mount For search results purposes: wellnut wellnuts well nut well nuts well-nut well-nuts |
February 8th, 2013, 01:28 AM | #12 | |
1) the two exposed on the windscreen that originally had a different part number and 2) the two that a dealer had already replaced when they serviced my bike (RH lower). I gradually replaced them all with various brands of M5 rubber wellnuts and none have rotted since. Kawasaki obviously knew there was a problem to use the rotting M5s only where you couldn't see them and to use a more expensive M5s with a different part number which don't rot for the exposed windscreen (others are "out of sight, out of mind"). More proof that it is a problem with these particular wellnuts: Kawasaki silently revised their parts diagram so there is no longer a different part for the windscreen wellnuts. I don't know if you can still order 92015-1757 (92015B on the old diagram), but it has been replaced in the diagram with the same wellnuts used on the windscreen: 92210-0498 (92210A on the diagram). They did that for good reason and you would be throwing your money away on 92015B 92015-1757. Hopefully the good ones are cheaper, though I see very little reason not to go with cheap generics (nothing else seems prone to rot). You can still see the old diagram with the rotting parts on Cornwall Kawasaki's EX250K diagram (FI-spec 2008-2012). Here is where both parts were discussed in depth on the US EX250J models diagram prior to the change: http://www.ninjette.org/forums/showthread.php?t=30915 |
Source for those wretched rubber well nuts | adouglas | 2008 - 2012 Ninja 250R Tech Talk | 90 | April 6th, 2014 09:57 PM |
WTB: Rubber expansion nuts, pop rivets, body screws (new 250r) | SwagenGTI | Items Wanted | 3 | April 17th, 2013 03:54 PM |
Rubber nuts on Fairings? | setasai | 2008 - 2012 Ninja 250R Tech Talk | 6 | June 21st, 2010 05:52 AM |
which thread had the info about the fairing rubber nuts? | Sound Wave | General Motorcycling Discussion | 1 | April 21st, 2009 01:12 AM |
