Old June 29th, 2017, 07:25 PM   #1
dorianmayorquin
Help Idle!!
Hello guys, The idle on my ninja 250 is usually good (around 1400 rpm) but sometimes when i come to a stop it goes up to 2500 rpm, however if i engage the clutch a little bit and then release it it immediatly goes back to normal, what do you guys think is the problem?
Thanks!
dorianmayorquin is offline   Reply With Quote
Old June 29th, 2017, 07:58 PM   #2
One possibility is an air leak between the carbs and the cylinder head.
Welcome to the board, Dude!
Old June 30th, 2017, 06:20 AM   #3
taz
taz's Avatar
MOTM - May '17
Might be idle mixture screws need adjusted.? Just one idea. And welcome.
Old June 30th, 2017, 09:08 AM   #4
ducatiman
ducatiman's Avatar
very common scenarios worth checking and eliminating.......swollen hose ends on decel valve? ditto hoses between carbs or tiny one under decel valve? All sources of vac leaks.
Welcome! And where in NY are you? NYC? Upstate?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old July 7th, 2017, 09:28 AM   #5
dorianmayorquin
Hey guys, turns out the problem might be a dirty carburator, I ran some seafoam through it and the problem seems to be fixed (for now). Um, I live close to the GWB, but mostly I stay in NJ! Anybody that lives nearby, I'm looking for a group to ride!
Thanks for the warm welcome!
Old July 7th, 2017, 10:09 AM   #6
I hope you're right, but there's nothing in that product that has much chance of cleaning a dirty carb. You can read the Seafoam MSDS and see what I mean.
Old July 7th, 2017, 10:10 AM   #7
/moved to new-gen tech
Old July 7th, 2017, 10:20 AM   #8
Ghostt
Ghostt's Avatar
Seafoam is good to use to prevent future problems, but it's not a fix all after the fact.
violente et ignorantia
ZX-2R BLOG
Old July 7th, 2017, 11:40 AM   #9
With just oil, Naptha, and isopropyl alcohol, I can't see how it would do much of anything beneficial. We all complain about alcohol in our fuel.
http://www.onboces.org/safety/msds/S...ary%202009.pdf
Old July 7th, 2017, 12:28 PM   #10
I like Techron Concentrate better.
Old July 7th, 2017, 12:29 PM   #11
That stuff does have a chance of preventing and maybe slowly fixing fuel system problems.
Old July 7th, 2017, 01:10 PM   #12
The vital ingredient is PEA. Which is found in Techron Concentrate and Redline SL-1
Old July 7th, 2017, 01:39 PM   #13
I run Techron (1oz per gal) in all my vehicles every spring.
Bike not idling below half choke, idle screw not affecting idle speed Zaraki_Kenpachi 1986 - 2007 Ninja 250R Tech Talk 2 March 6th, 2020 11:13 AM
Question about idle mixture screw and low idle flux daverdfw 2008 - 2012 Ninja 250R Tech Talk 3 June 2nd, 2016 10:36 PM
Idle issues - Idle is different every time I start up. 106 1986 - 2007 Ninja 250R Tech Talk 6 November 13th, 2014 04:57 PM
what should i idle at EvilPooMonkey 2008 - 2012 Ninja 250R Tech Talk 7 July 8th, 2012 03:00 PM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
