July 10th, 2017, 04:39 PM | #1 |
Join Date: Jun 2017 Motorcycle(s): 2011 Ninja 250r se Posts: 100
Weird dead spot.
Cleaned my carbs recently, tuned them, synced them, checked for vac leaks, buckled it all down. She sounds great she rides great. Until today, I hit a dead spot in my throttle more than once. Right at about 9000 rpm as im gonna go into fun time it just sits there. Doesnt bog, doesnt decellerate or chug just no more rpm being made. I've never encountered this issue yet. Any leads as to what would cause an intermittent dead spot? starvation? water? crank bearing? (lol!!)
They should give me my own section called kik rox is a silly **** who breaks stuff. |
July 10th, 2017, 07:26 PM | #2 |
Carb slides not lifting fully would be my guess, meaning something is not assembled correctly or the diaphragms are damaged.
A restricted intake snorkel opening might do that as well. |
July 10th, 2017, 07:37 PM | #3 |
CCS Amateur #501
Join Date: Jun 2015 Motorcycle(s): '09 250 SE 'Booger' Posts: 406
Mine was doing something similar and the tach needle started bouncing around the 9-12k rpm range. Turned out to be a bad ignition box.
July 10th, 2017, 07:59 PM | #4 |
im super careful with the slides but perhaps its possible. I'll take peek tomorrow night, my tach isnt bouncing just no reply to throttle intermittently. sticky slide makes sense.
July 10th, 2017, 11:09 PM | #5 |
I'm thinking it's slides, those Cam be tricky to fit, if not done exactly perfect, you'll have issues and possibly damage them.
July 11th, 2017, 03:36 AM | #6 |
i make sure they are seated before installing the caps but perhaps i got the side of a slide a little dirty. would a vacuum sync issue cause anything like this?
July 11th, 2017, 05:16 AM | #7 |
synch issue is not likely..but a intermittent vac *leak* could very well be.
Check *all* the vac hoses at the decel valve and the 2 points between (inside) the carb bodies.....all should be tight on their mounts. If swollen...could leak under throttle/high vacuum conditions...also make note..when hot, the hoses swell...thus intermittent under varying heat/demand conditions. Within my services...I've seen a lot of these loose, with swollen ends and in need of replacement. If they can be easily removed with light finger pressure...replace. They should be on firmly, and the little spring clamps should be present and *actually clamping*. It may be worth checking.
July 11th, 2017, 11:03 AM | #8 |
Join Date: Dec 2015 Motorcycle(s): 2008 Ninja 250 Posts: 210
You said tuned the carbs. What's the tune look like? (Jet sizes, shimmed the needles?, float height, etc) reason I ask is I had the same problem and removed a washer from each needle so I only had one on each needle. Flat spot disappeared.
But we may have differing mods, just my .02 hope it helps. |
July 11th, 2017, 02:26 PM | #9 |
Tuned to stock spec, 98 mains, 38 pilots, around two turns right idle mixture, left is around 2.75 turns out. floats at 17 mm. just set everything up the way it should be.
I think i found something. my tank isnt venting right... was on my way to work again, hit the highway and boom she's not getting fuel again! i was like ok maybe its vapour lock... went to the gas station fueled up (didnt hear any woosh sound) went back on the highway and she reved up proper. it did it again on the way home again so i rode it home with the lid open just a crack and it was fine. Easy fix atleast i hope it fixes it. That tank and petcock are suspect to begin with. Might be water in my gas making my floats shut the fuel supply off too. two things worth checking before i take the 3 hours to remove, inspect and reinstall the carbs.
July 11th, 2017, 04:42 PM | #10 |
Glad you found the problem. There is a writeup around here somewhere on the tank vents.
July 11th, 2017, 05:23 PM | #11 | |
I have a, write-up on the PreGen has cap vent, I've never even seen the NewGen but I can imagine it's similar
Sounds like it could be a venting issue, no worries it's a free and easy fix, Quote:
July 11th, 2017, 07:10 PM | #12 |
July 11th, 2017, 07:54 PM | #13 |
I would be more interested in the internal parts of the cap, I don't have a NewGen or even access to our.
July 12th, 2017, 02:03 AM | #14 |
I think if i pop that out it will draw air from the overflow. The overflow isnt in the photo but the tube is located under the lid as well. Might try it and see what happens. thanks for the help btw. its nice having a few diff thoughts on the subject. if this doesnt solve it i'll pull the carbs tonight and white lithium grease the slides.
July 12th, 2017, 02:44 AM | #15 | |
Join Date: Mar 2017 Motorcycle(s): 2007 Kawasaki 250 Ninja, 1982 Honda Ascot FT500 Posts: A lot.
Bill |
July 12th, 2017, 04:03 AM | #16 | |
*EDIT* i popped the diaphragm out of my lid. 26 km ride to work, ZERO issues. Sucking back gas like a CHAMP. wicked. +1 for ghostt!! i'll rebuild the cap later.
They should give me my own section called kik rox is a silly **** who breaks stuff. Last futzed with by KikRox; July 12th, 2017 at 05:17 AM. |
July 12th, 2017, 05:30 AM | #17 | |
Just a note on slide lubrication. My thought being, that throttle slide just "floats" in the carb body waiting for a change in air pressure to move it up and gravity to move it back down down - a CV carb. On a non CV carb you have a twist grip to pull it up/open and a spring to close it. In other words you force the throttle slide to do what you want. It just seems to me that sticky lithium grease will hang-up that throttle slide and off come the carburetors again. Bill |
July 12th, 2017, 04:35 PM | #18 | |
Here's a weird one... | misfitsailor | Help | 4 | August 17th, 2014 07:48 PM |
Dead spot around 9k RPM | walk_n_wind | Ninjettes At Speed | 4 | June 5th, 2013 12:47 PM |
Weird :/ | reabo | 2008 - 2012 Ninja 250R Tech Talk | 16 | April 12th, 2013 03:55 AM |
[urgent] my bike is dead. Very dead. Now what? | arnoldc6 | Riding Skills | 15 | September 8th, 2012 08:04 AM |
Dead spot in rpm's | chikenstrips | 2008 - 2012 Ninja 250R Tech Talk | 25 | April 29th, 2012 08:13 PM |
