Old July 24th, 2017, 01:48 PM   #1
Benshot05
Motorcycle(s): 2012 ninja 250
New to bikes, have a question
OKay so i just bought myself one of the very fast 2012 ninja 250s for my first bike used. Ive been riding it, it rides fine, but it gets to 80mph and is doing 12k rpm. i have a friend who has a 2007 ninja 250 and his gets to a much faster speed and at a lower rpm and he weighs about the same as me.
Ive read of other people doing much faster than just 80mph and im just curious as to whether its just the newer 250s dont go as slow or if something is actually wrong with my bike?
it has 5k miles, i weigh 165, everything else is in good condition other than its needing an oil change soon. I know its just a 250 and shouldnt expect much speed out of it but only 80mph seems like something is wrong to me.
Thank you for reading this and replying! I appreciate it.
Benshot05 is offline   Reply With Quote
Old July 24th, 2017, 02:11 PM   #2
Hi and welcome!
Top-speed is all about aerodynamics and how much wind is blocked by your cross-sectional area. That area then bores a tunnel through the wind. The more air volume you have to displace to create that tunnel, the slower you'll go for any given HP-output.
So... to go faster for same max-HP from engine, fold in your mirrors, tuck down and behind the wind-screen (chin on tank). Pull in your legs, arms, hands, use your little pinkie-finger to keep the throttle pinned. That's good for at least 10-15mph more.
Could also be your bike is out of optimum tune. Or even worn-out and engine needs rebuild.
Old July 24th, 2017, 02:14 PM   #3
Hello Ben, it's good to meet you.
Engine RPM versus road speed in high gear depends only on what particular sprockets the bike has on it. Many guys don't like the high revs at highway speed, and change the sprockets to lower the RPM. Figuring out what sprockets your 250 has might shed some light on the situation. If yours are the stock ones and your friend has different ones, that might explain the difference.
Also, speedometers and tachometers are somewhat notorious for being inaccurate, so that may be entering into the equation. Is the rev limiter limiting your top speed, or are you backing off at 12,000? I thought newgen 250 redlined at 13,000.
Old July 24th, 2017, 03:04 PM   #4
KikRox
KikRox's Avatar
Motorcycle(s): 2011 Ninja 250r se
higher speed + lower rpm = gearing. Stock 250 should top out around 140kph or 90mph with stock 15/45 (3:1 gearing) you can test this without counting. Drive it at 80kph (55mph) in 6th gear. if its doing 7000 rpm its probably stock. At 100 kph its 8000 rpm. 120kph is around 9800-10 000 rpm.
They should give me my own section called kik rox is a silly **** who breaks stuff.
KikRox is offline   Reply With Quote
Old July 24th, 2017, 03:37 PM   #5
Originally Posted by KikRox View Post
..with stock 15/45 (3:1 gearing) .
No, stock gearing in the US was 14/45. Counting teeth is a very simple way to see what the current gearing is, and removes speedometer and tachometer calibration as possible errors.
Old July 24th, 2017, 04:00 PM   #6
KikRox
KikRox's Avatar
oops my bad so the stock ratio is 3.214:1 mind slip. i for some reason thought 15. my bad.
Old July 24th, 2017, 11:21 PM   #7
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome!
Newbe Question - Does the newer Ninjas (or any bikes) have OBDII connectivity? Wanderer General Motorcycling Discussion 11 March 13th, 2017 01:35 AM
Question about throttle on larger bikes Jiggles General Motorcycling Discussion 47 September 27th, 2012 06:43 PM
English 10 Language Question (Very simple question) nickjpass Off-Topic 24 September 16th, 2011 08:28 AM
[superbikeplanet.com] - Battery Bikes, Old Bikes Confirmed For 2011 Infineon West Coa Ninjette Newsbot Motorcycling News 0 September 21st, 2010 04:00 PM
MotoGP question re bikes.... adouglas General Motorcycling Discussion 20 August 11th, 2009 04:46 PM
