Old July 26th, 2017, 04:56 PM   #1
Brad92
Motorcycle(s): Ninja 250r
Tire feathering and peeling bad?
Hey everyone is this tire bad ?
Brad92 is offline   Reply With Quote
Old July 26th, 2017, 05:03 PM   #2
That looks dangerous!
What is the manufacture date? It's 4 numbers in an oval on the sidewall like "2608". The first 2 are the week of the year (26th week) the second are the last digits of the year (2008).
Anything over 5 years and you are on borrowed time.
I just trashed a front tire (BT-016 Pro) that was too old, but not "worn out".
Good tires are a must for survival on the street IMO. I'll take every advantage I can get.
Old July 26th, 2017, 05:24 PM   #3
Assuming it's not overly old, I'd do some hard test stops and observe how it feels in turns and decide that way. I've seen tires do what your photo shows, but still have excellent grip. Really though don't listen to me, it's your safety in question. As I've gotten older, I worry less about tings than I used to.
Old July 26th, 2017, 05:35 PM   #4
Brad92
Made in 2012 so I'm guessing age low usage weathered and hard riding wjen used. Getting a new bike next week but still using this daily, just noticed that today. I'll probably just ride it home and leave it alone till I can geth new tires. Wasn't sure if that was normal peeling wear or worse sounds like it's worse
Old July 26th, 2017, 05:38 PM   #5
A tire shouldn't do that, but the Avon Roadriders on my DT100 have a little of it starting. They still stick like glue though, so I'm not throwing them away.
Old July 26th, 2017, 05:54 PM   #6
jrshooter
Motorcycle(s): ninja 300
that spot in the picture, are they at intervals all the way around the tires ?
possible rebound to fast.
Old July 26th, 2017, 05:56 PM   #7
it aint that deep yet, if the cracks get below the wear bars or shows any signs of less than optimal traction... replace the tire
Old July 26th, 2017, 05:57 PM   #8
Brad92
I'll check, is thathere bad? I don't believe it's ok to ride going further but if others say it's ok I'll let it hang for rest of the season
Old July 26th, 2017, 06:11 PM   #9
I'll check, is thathere bad? I don't believe it's ok to ride going further but if others say it's ok I'll let it hand for rear of season
I have meet and rode with all kinds of riders. If you have no faith in the tire, then it WILL show in other areas of your riding.
Replace it now if that puts your confidence back where it needs to be.
EDIT: Your direct question "is that bad?" Of course that is bad, your tire should NOT wear in that manner. It is showing signs of drying out and age.
Old July 26th, 2017, 06:17 PM   #10
You are not going to get definitive answers - just opinions.
I'm picky about tires, on my cars but especially on my cycles. I've replaced new OEM cycle tires after 500 mi because I didn't like them. Others have ridden on them for 10 years or more. I've replaced car tires after 3 years because traction had degraded past what I thought was acceptable.
As I get older I get less likely to accept anything I see as a potential problem or unacceptable safety risk. There are enough risks out there that I can't control, so I minimize the ones I can. It's kept me alive for over 35 years on 2 wheels, so far...
Old July 26th, 2017, 06:17 PM   #11
Brad92
Ah ok that'she what I was looking for, what it means. So basically all the oils are gone from age. So yea time to dump them. Riding home then new tires next week.
Bad driver & bad rider. Guess who gets hurt... akima Videos 27 July 12th, 2013 12:26 AM
Tire Cupping/Feathering Old Guy on a '08 2008 - 2012 Ninja 250R Tech Talk 3 October 5th, 2012 11:47 PM
Lane splitting.... bad bad bad oblivion007 Videos 29 May 8th, 2012 11:42 AM
No Tire Balance - How Bad? gfloyd2002 2008 - 2012 Ninja 250R Tech Talk 14 October 8th, 2011 11:19 PM
good and bad tire - or good and bad riding? Domagoj Riding Skills 11 September 17th, 2010 07:30 AM
