August 31st, 2017, 09:40 PM | #1 |
[motorcycle.com] - 2018 Harley-Davidson Fat Bob 114 Review – First Ride
2018 Harley-Davidson Fat Bob 114 Editor Score: 84.25%Engine 17.0/20Suspension/Handling 12.75/15 Transmission/Clutch 7.5/10Brakes 8.5/10 Instruments/Controls4.0/5 Ergonomics/Comfort 8.0/10 Appearance/Quality 9.0/10Desirability 9.5/10Value 8.0/10Overall Score84.25/100On August 22, 2017, Harley-Davidson turned the motorcycling world on its ear by announcing that it had scrapped the entire Dyna line of motorcycles and rolled it into a completely revamped Softail line. When the dust settled, eight new Softails – four of them available with the buyer’s choice of a Millwaukee-Eight 107 or optional 114 engine – stood as the heart of a completely new cruiser lineup. The names of the Softails were carryovers from the previous generation, and for the most part, the new models were easily distinguishable as their previous generation’s namesakes. In the case of the 2018 Fat Bob, this wasn’t necessarily a given. Yes, once you knew you were looking at the new Fat Bob, it made sense, but at first glance, the 2018 Fat Bob elicits wows – followed by what the hell is that? Harley-Davidson Introduces All New 2018 Softail Line Harley-Davidson 2018 Softail Pictorial Overview Yes, the 2018 Fat Bob is radically different, but if you look closely, you can see that it is the 2017’s more burly and better looking younger brother. Dialing up the attitude Perhaps only one other 2018 Softail, the Fat Boy, looks as radically different as the Fat Bob does from previous generation. This is because, Harley’s designers felt that, by remaining true to the lines and heritage of the other Softails and former Dynas, they could take some liberties. Brad Richards, Vice President, Styling and Design, noted: “If you do [the] foundational motorcycles correctly, our customers will give us permission to stretch the brand into places they might not have thought it could go.” The Fat Bob is definitely a stretch for Harley. This headlight is quite a departure from the previous Fat Bob, and that’s a good thing. Before we consider the functional changes, which were a different kind of stretch for the Motor Company, let’s look at how different the Fat Bob is stylistically. The 2018 Fat Bob looks like a superhero version of its former self – perhaps bulking up after being bitten by a radioactive spider. The fat 150/80–16 front and 180/70B16 rear tires look menacing mounted on a pair of 16-inch cast rims which are highlighted by a pair of floating brake rotors. The tires’ tread pattern looks capable of handling any form of pavement, almost as if they were ADV-inspired. Mounted above the inverted cartridge fork is an LED headlight that looks like the eye-slit of a 1950’s robot, ready to shoot laser beams. (Think Gort from The Day the Earth Stood Still only boxy.) Beneath the new 3.6 gallon tank that was specifically shaped to show off the top of the engine, the big-twin seems almost outsized for the frame, a powerful appearance that is highlighted by the fat header pipes that arch forward of the crankshaft before swooping back like a mating pair of bronze pythons into the staggered upswept satin-textured dual exhausts. Tasked with the job of carrying all that badassery, a model-specific Softail frame with a 28° rake strives to give the Fat Bob the performance to match its aggressive stance. Dynamic performance is the name of the game when it comes to the changes that Harley made to this new version of the Softail frame, which is claimed to be 35% stiffer from contact-patch-to-contact-patch. Similarly, the SAE lean angle measurement has increased one degree to 31° and 32° right and left, respectively – though in actuality, it feels like much more. The new more conventionally-mounted rear mono-shock gains an external hydraulic adjuster and allows for 4.4 in. of wheel travel in addition boosting cornering clearance. (To learn more about the specifics of the Softail line’s chassis updates, check out our “Harley-Davidson Introduces All New 2018 Softail Line”.) The oil tank under the seat has been exchanged for a hydraulic preload adjuster and the under seat shock. The engine gained a wet sump and space under the transmission for the oil to hang out between cooling trips through the heads. The Milwaukee-Eight 114 engine has been updated for its rigid-mounting in the new frame and is now graced with a second counterbalancer. This doesn’t mean that the engine has lost its V-Twin character. While it remains smooth at low rpm, some vibration does enter the pegs and grips around 3,500 rpm to remind you that you have beefy 102 mm pistons stroking through 114.3 mm to produce a claimed 118 lb-ft of peak torque – also at 3,500 rpm. As with all Milwaukee-Eight engines we’ve tested, the fuel metering is spot on with nary a miss or a shudder unless you’re lugging along just above idle and open the throttle too quickly. One of the benefits of the M-E series being mechanically quieter than the Twin Cam engines is that a more mellifluous exhaust note can exit the 2-into–1-into–2 exhaust without exceeding the EPA’s noise standards. The rider’s feet may be forward, but they’re not stretched out. From the spec chart to the street Perhaps the most divisive feature of the Fat Bob is the feet-forward riding position. Many sportbike riders scoff at a performance-focused motorcycle placing the rider’s feet out front. The Fat Bob is a cruiser first-and-foremost, but a cruiser with, a cruiser with sporting intent. It’s not a standard or a sporty-bike. So, when viewing the tool through the lens of the job it is intended for, I see no issue with the foot position. Yes, the current peg location does limit cornering clearance. However, when the models are ridden back-to-back, the lean angle available compared to the previous generation Fat Bob is more significant than Harley’s single degree claim would lead one to believe. Moving the pegs rearward would require a much higher seat and make the Fat Bob an altogether different motorcycle. What keeps the riding position from falling into the dreaded clamshell category (like that of the dearly departed V-Rod) is the position of the grips relative to the pegs. Take a look at how my 5-foot eleven-inch frame fits the FB’s chassis. The pegs are forward but are not a stretch for my 32-inch inseam. The tapered aluminum bar brings the grips back to where they are a comfortably sporty reach, keeping my back with a slight forward lean to combat the wind. Crank up the intensity, and the rider will naturally lean a bit forward to better manipulate the controls. The Fat Bob’s seat is comfortable and well-shaped. The step at the back is necessary for when you crank on the throttle. Thanks to their wider bars and different wheel/tire sizes, some of the other Softails may steer lighter than the Fat Bob, however, that doesn’t mean that the Bob’s bar isn’t wide enough to offer good leverage. With a firm hand on the tiller, the Fat Bob bends precisely into corners. Once leaned over, stability is the operative word. This shouldn’t come as a surprise with a wheelbase measuring a longish 63.6 inches. Although this is the shortest member of the Softail line, it shouldn’t be considered “short” by any means. Still, the Fat Bob is more than happy to change lines mid-corner or hustle through a series of esses. The Harley-branded Dunlop tires deserve some props for the FB’s friendly handling. The tire shape – despite the adventure-styled tread pattern – contributes to the neutral steering and the confidence-inspiring grip, even when the pegs are skimming the pavement. The suspension is suitably firm for performance riding without being harsh. G-out bumps get absorbed without the boinginess of excessive rebound – even when cranked over in a high-speed sweeper. Other road imperfections rarely affect the chassis until they get to the larger, sharp-edged size, but even then, the additional shock stroke is appreciated. In my stint through the twisties on the Fat Bob, I never bottomed the shock – something I was never able to say about the dual shocks on previous Dynas. Happy at a moderate sporting pace in the canyons and in the stoplight grand prix. The Fat Bob has improved ground clearance, proficient suspension, and an engine that loves full-throttled clutchless upshifts. At some point, you’re gonna have to slow down. The floating dual front discs squeezed by four-piston calipers accomplish the task with a decent amount of feel at the lever. If trail-braking is your thing, you can happily do it all the way to the apex of the corner. ABS is a $795 option that we’d always pop for because we’ve all made mistakes. 2018 Harley-Davidson Fat Bob 114+ Highs</p>
The 2018 Harley-Davidson Fat Bob 114 retails for $18,699 in black ($19,099 for optional colors). 2018 Harley-Davidson Fat Bob 114MSRP$18,699, $19,099 (color option)Engine TypeMilwaukee-Eight® 114 45° V-TwinBore and Stroke102 mm x 114.3 mmFuel SystemElectronic Sequential Port Fuel Injection (ESPFI)Compression Ratio10.5:1Valve Train4 valves per cylinder, pushrodsTransmission6-Speed Cruise DriveFinal DriveBeltFront SuspensionInverted cartridge forkRear SuspensionMono-shock, hydraulic preload adjuster, 4.4 in. travelFront BrakeDual 4-piston calpers, floating discsRear Brake2-piston caliper, floating discFront Tire150/80-16,71H,BWRear Tire180/70B16,77H,BWRake/Trail28° / TK in.Wheelbase63.6 in.Seat Height28 in.Curb Weight676 lb. (claimed)Fuel Capacity3.6 gal.Available ColorsVivid Black, Industrial Gray Denim2018 Harley-Davidson Fat Bob 114 Review – First Ride appeared first on Motorcycle.com. Click here for full story...
[motorcyclistonline] - Scott Riding Boots, Harley-Davidson FXEF Fat Bob 80 and “The S | Ninjette Newsbot | Motorcycling News | 0 | June 9th, 2016 07:10 PM |
[motorcycle.com] - 2014 Harley-Davidson FXDF Fat Bob Review | Ninjette Newsbot | Motorcycling News | 0 | September 19th, 2013 09:30 PM |
[motorcycle.com] - 2014 Harley-Davidson Fat Bob Receives Dark Custom Makeover | Ninjette Newsbot | Motorcycling News | 0 | August 19th, 2013 04:00 PM |
[topix.net] - Harley-Davidson launches Fat Bob | Ninjette Newsbot | Motorcycling News | 0 | November 22nd, 2012 01:10 PM |
[usridernews.com] - New Harley-Davidson® Fat Bob® Keys to Two Lucky Winners | Ninjette Newsbot | Motorcycling News | 0 | June 25th, 2009 09:40 AM |
