August 28th, 2013, 09:08 PM | #1 |
troublemaker
Join Date: Feb 2013 Motorcycle(s): 2012 FZR6R Raven Posts: 92
EX250JCF versus EX250JCFA
Can anyone tell me the difference between these models and which one I'm likely to have? I'm looking at part kits and I don't want to select the wrong one. Thanks.
http://www.kawasakipartshouse.com/oe...cle_2012/parts |
August 28th, 2013, 09:49 PM | #2 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
Usually the A denotes one of the SE color schemes.
August 28th, 2013, 10:01 PM | #3 |
Certified looney toon
MOTM Jul '13, Jul '14
For some reason I was under the impression the A was the California edition.
August 28th, 2013, 10:11 PM | #4 |
MOTM - Jan '18, Sep '13
Oh that makes sense. I forget when I check for parts. I just pick one and go with it haha.
August 28th, 2013, 10:46 PM | #5 |
Nope, I'm wrong.
Based on the BikeBandit parts diagram, the Fuel Evaporative System is on both the JCF and JCFA. Looking at their list, the big difference I can see is the color scheme of the cowlings and decals. I put in a 2012 which gives me... JBF/JCF are the standard colors of Ebony, Red, Candy Lime Green, Blue JBFA has either a white lower portion of the lower cowling or Lime green and ebony, JCFA has either a CA, US red and Black or Black lower part. At least that's all that I can see as the difference.
August 28th, 2013, 10:57 PM | #6 | |
troublemaker
August 28th, 2013, 11:01 PM | #7 |
I was actually replying to menikmati but didn't quote things
August 29th, 2013, 10:59 AM | #8 | |
August 29th, 2013, 12:31 PM | #9 |
the difference between jcf, jbf, jcfa, etc are fairly minor. all the bolts are the same. the difference is mostly color and whether or not it has california emission controls. everything else is the same. so if you got the wrong size bolt, its not because you picked a jcf instead of a jbf or whatever.
August 29th, 2013, 01:02 PM | #10 | |
troublemaker
Corbin versus? | wardie | General Motorcycling Discussion | 3 | June 19th, 2014 04:55 AM |
Motorcycle versus Ram | Panda | Videos | 20 | September 12th, 2013 04:27 PM |
new versus thread GO! | EvilPooMonkey | General Motorcycling Discussion | 19 | June 24th, 2012 09:22 PM |
60 km/h versus 68 | Motofool | Videos | 27 | June 10th, 2012 12:54 PM |
Talon versus Bikes | g21-30 | Videos | 9 | April 16th, 2010 07:47 AM |
