September 14th, 2011, 02:03 PM | #1 |
Join Date: Jul 2011 Motorcycle(s): 08 Ninja 250 Posts: 55
Speedo Problem
On my way home from class today I noticed my Speedometer wasn't registering anything, including the mileage. I suspect it is just a loose connection, but the bike got rained on recently so maybe slight corrosion? My question is how/where do I go about cleaning these connections? Will some WD-40 do the trick or is it more involved?
September 14th, 2011, 02:09 PM | #2 | |
September 14th, 2011, 03:42 PM | #3 |
I just replaced the speedo gears at the wheel for a buddies 08. The cable was still good but the gears were broken.
September 14th, 2011, 09:33 PM | #4 |
Very interesting. Any idea what broke the gears/how? Seems like kinda an odd part to fail, as from what I understand of the construction, there's very little room for the wobble that's typically the cause of gear wear/damage.
September 15th, 2011, 09:38 AM | #5 |
The actual broken part was not the gear itself but was located inside the speedometer gear housing. It looks to have been spacer of some sort but I believe it also holds one side of the gear assembly still while the wheel rotation turns the gear/cable.
September 15th, 2011, 01:59 PM | #6 |
The bike has only 2500 miles on it so I would really hope nothing is broken. As far as the connections are concerned I will check them and get back to you guys!
September 15th, 2011, 02:18 PM | #7 |
Okay I finally got the time to get into everything and the cable was loose on the end going into the gauges. What would be the cause of this? How do I go about fixing it?
September 15th, 2011, 06:03 PM | #8 | |
1) previous owner fiddling with it 2) vibrations worked it loose, coming up on 4 years old or not being 100% proper tight from the factory Solution: Can ya just tighten it back up? If not, you may need to align the square pin that's inside with the receiver in the speedometer. Perhaps put a little blue loctite on it to make sure it stays put when you tighten it back down.
October 9th, 2011, 05:16 PM | #9 |
I found it almost impossible to tighten properly with the fairings on. I seemingly got it (everything worked) and found a couple months later that it wasn't even threading straight and wasn't nearly "tight" (still worked; discovered when doing something else with the fairings off).
Speedo Drd, Speedometer and Odometer Accuracy-Speedo Healer/drd | Klondike1020 | General Motorcycling Discussion | 8 | August 17th, 2014 12:23 AM |
My speedo is way out! | Damo990 | 2013 - 2017 Ninja 300 Tech Talk | 14 | March 5th, 2014 06:54 AM |
Speedo Problem | JH PiNoY | 2008 - 2012 Ninja 250R Tech Talk | 3 | July 30th, 2013 06:47 PM |
My speedo is off??? | Kitdog | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 28th, 2010 03:24 PM |
