June 9th, 2010, 03:12 AM | #1 |
Larger tyres and pressure
Just wondering what tyre pressures people are using with larger than factory tyres. I have the standard front tyre and and gt501 140 rear and have just been running the recommended pressures (29psi front and 31psi rear)
The reason I ask is there are many threads asking about tyre pressures people run, but nothing about the size of the tyre used. Cheers |
June 12th, 2010, 03:16 AM | #2 |
Join Date: Jun 2010 Motorcycle(s): 2008 Kawasaki Ninja 250R-J, 2005 Honda Superhawk VTR1000 Posts: 95
That's a good PSI setting. Different tires benefit from different pressures. I recently purchased BT-003 for my smallest bike in my arsenal the 250-R. Rumor has it, you want to run around 27 PSI for that radial 140/70. I haven't installed them yet. I hear they can get greasy (ie. slip) if not warmed up nicely.
My Honda Superhawk VTR1000 likes about 31 PSI for the Bridgestone C2T tires. |
larger front rotor?? | caltony | 1986 - 2007 Ninja 250R Tech Talk | 18 | March 29th, 2014 08:15 PM |
larger sprocket more links? | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 4 | August 13th, 2013 02:18 PM |
New tire - larger? | shane_colton | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 23rd, 2010 08:15 PM |
Gearing for Larger Tracks | Broom | Ninjettes At Speed | 12 | April 5th, 2009 12:12 AM |
