June 15th, 2014, 12:55 PM | #1 |
Join Date: Apr 2012 Motorcycle(s): 94 EX250, 81 GS450 Posts: 67
issue adjusting the valves
The wiki is great, my bike has been giving me a hard time during cold starts. Ive already completely rebuilt the carbs. With 18k miles I figured it'll be a good idea to adjust the valves since I have no idea when the previous owner did it last.
So I proceeded to adjust them from the left to right and the last valve intake right cylinder didn't have a nut on the valve adjustment screw. Also with the adjustment screw backed up all the way I still can't get the feeler Guage in under the cam. The rest of the valves are fine. I've put 1000 miles on the bike to date. Do I need to rebuild? Any advise would be appreciated. Thanks |
June 15th, 2014, 02:47 PM | #2 |
Join Date: Sep 2013 Motorcycle(s): 2006 Ninja 250, 2004 Buell XB12s, Honda 110 Elite Posts: 332
The follower has to be on the heel of the cam lobe. If it is, and there is no clearance, you have problems.
"They don't pay me enough to ride this thing!" Kenny Roberts after winning the Indy Mile on the TZ750 powered Grand National bike. |
June 15th, 2014, 03:15 PM | #3 |
Yes its on the heel. I guess I need to yank it and rebuild. Any recommendations on a rebuild kit? Might as well replace the pistons and rings. Anyone make higher compression pistons for these?
June 15th, 2014, 03:38 PM | #4 | |
Join Date: Oct 2013 Motorcycle(s): [2] 2006 Ninja 250s, [3]DRZs, [3]GasGas450s, [1]KDX 225 2 stroke,[1]650HondaCX, [1]Honda CBR1000rr Posts: 40
As an additional comment l would say that as easy as the motor is to pull,I would pull the motor before I pulled the head? Tony |
June 16th, 2014, 09:34 AM | #5 |
Anyone have a PDF copy of the Factory Service Manual?
June 16th, 2014, 10:16 AM | #6 |
Join Date: Sep 2013 Motorcycle(s): Ducati 1198s, Triumph D675, Suzuki SV1000s, `08 Ninja 250, `11 Ninja 250, Suzuki GS750 Posts: 368
Check your PM's.
Oops, wrong section...
MCRA.com Last futzed with by DCMoney; June 16th, 2014 at 11:20 AM. |
DIY - Adjusting Valves on '08+ 250r (WITH Pictures) | VeX | 2008 - 2012 Ninja 250R Tech Talk | 93 | August 21st, 2017 01:34 PM |
Adjusting headlights? | uKER | 2013 - 2017 Ninja 300 Tech Talk | 2 | July 8th, 2013 07:50 PM |
Adjusting Choke | astricklin | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 5th, 2013 06:06 PM |
!HELP! Adjusting Valves issues | 00v_Lucky | 2008 - 2012 Ninja 250R Tech Talk | 9 | June 14th, 2010 04:39 PM |
Adjusting mirrors.. | xTKx | General Motorcycling Discussion | 42 | April 2nd, 2009 02:09 PM |
