Old July 8th, 2014, 11:21 PM   #1
Triple R
Motorcycle(s): Suzuki's
R6 Shock?
Has anyone tried or had luck with a 06+ R6 shock on the 08+ 250?
Triple R is offline   Reply With Quote
Old July 9th, 2014, 05:51 AM   #2
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
don't know many details but off the bat I don't think the bikes use the same lower linkage mount. I think the R6 is the type that goes inbetween the linkage and not the "U" shaped type that the 250 and gsxr shocks use. So that being said you would have to do a lot of additional swapping ect... to make it work and why?
GSXR shock for $25 on ebay, it is as easy as buying some bolts and drilling a few holes, don't make it harder than it has to be IMO
Old July 9th, 2014, 09:21 AM   #3
Triple R
I hear what you're saying. I have a R6 shock here and would attempt the swap if anyone had positive results. Looks like I'm going the GSXR route. Curious, does anyone make/sell a "clevis" for the gsxr shock to compensate for the shorter length of the shock? I swear I saw something like that on here not to long ago.
Thanks for the help!
Old July 9th, 2014, 10:06 AM   #4
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
you want shorter dog bones. You can make your own out of steel or T6 or fork out some cash and buy some. Burkhart cycles or something like that sells them specifically for the gsxr shock swap and a reasonable price.
see here (just don't expect any contact from him or to get it on short notice) but you will get them
http://burkhartcycle.com/store/index...dex&cPath=7_34
Old July 9th, 2014, 10:10 AM   #5
Triple R
I would go that route but the class I'm racing in doesn't allow aftermarket dog bones unfortunately.
Old July 9th, 2014, 11:22 AM   #6
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
So you can install a completely different shock that alters everything about the suspension, but you can't install a couple metal spacers to adjust the suspension back closer to stock alignment?
Some racing rules are so stupid...
Originally Posted by InvisiBill View Post
Originally Posted by ForceofWill View Post
So the +1.25 look right at 156mm middle of eye to eye and the +1 look like 158.5mm to me.
FYI, the 39111-1133 dogbones used on the Gen2 EX500 are 157.5mm eye to eye. A lot of EX500 owners buy shorter dogbones from FOG to raise the rear end for quicker steering (similar to the topic of this thread), so you might be able to find some for cheap/free (though $17 still isn't bad). Both the 250 and 500 use the same sleeves through the knuckle and swingarm, but the 500 uses 100mm long bolts (92002-1886) while the 250's are 98mm (92153-1831), so the 500 dogbones might possibly be a bit thicker or something.
Does OEM for a slightly different bike count as aftermarket? Would they even be able to tell (if your own ethics allow you to do this)?
Old July 9th, 2014, 11:24 AM   #7
i use an R1 shock and knuckle with custom bones. the r6 shock is the same but the knuckle is different. i think you gotta use the r1 knuck.
Old July 9th, 2014, 11:25 AM   #8
the idea is that if you have to replace the shock with a "drop-in" then people will likely get an aftermarket kit made for the bike so that a "real engineer" produced the design instead of some knucklehead just trying to slap on whatever fits.
Old July 9th, 2014, 11:26 AM   #9
Triple R
I agree it's stupid but I have to follow them. Granted I probably wont podium or even place top 10 but I just want to be legit. If you guys can recall the guy making the "clevis" type top mount please let me know!
Old July 9th, 2014, 11:54 AM   #10
tuscani451
Motorcycle(s): R6, Kawi 250
I think one of the CVMA guys said a R6+SV dogbones works?
tuscani451 is offline   Reply With Quote
Old July 9th, 2014, 12:10 PM   #11
the yamaha shocks have a bearing at the bottom instead of the way suzuki/kawi do it with the bottom of the shock having a square mount that fits over the shock knuckle which has a bearing in it. so if you want to go to the yamaha shock you have to change the knuckle to the r1-style knuckle
1996 ZX600C shock or 2010 300 shock jgcable 1986 - 2007 Ninja 250R Tech Talk 9 April 30th, 2014 05:35 AM
ZX600 shock davidw38901 1986 - 2007 Ninja 250R Tech Talk 6 October 23rd, 2013 09:50 PM
Replacing my rear shock with a newgen rear shock... ReDnEcK 2008 - 2012 Ninja 250R Tech Talk 4 September 10th, 2010 12:38 PM
looking for a J shock Ninja Nut Items Wanted 1 February 19th, 2010 10:16 PM
WTB: 08-09 Shock mcdanielsamuel Items Wanted 0 June 1st, 2009 09:14 PM
