January 1st, 2012, 03:38 PM | #1 |
ALRE all day
Join Date: Apr 2011 Motorcycle(s): 2009 Ninja 250R SE Posts: 107
Friction Zone.
Hey all, I took the ninja in for the 600 mile service and they adjusted the clutch for me. Well I had a severely rattling clutch lever. The play was way out of specs. Any way now the play is where it should be, only thing is the friction zone is now furthur away from the bar. I like it closer is there any way that I can make it closer to the bar? Thanks Robert
January 1st, 2012, 03:50 PM | #2 |
January 1st, 2012, 05:20 PM | #3 |
ALRE all day
Is there a way to adjust our stock ones
January 1st, 2012, 05:25 PM | #4 |
nope. they're not adjustable levers. I let mine have some slack so that they're not so far out, but they vibrate and rattle a little whatever. works for me. cheaper than buying adjustable levers.
January 1st, 2012, 06:34 PM | #5 |
ALRE all day
January 1st, 2012, 06:41 PM | #6 |
Check these out http://www.ebay.com/itm/Clutch-Brake...sories&vxp=mtr
and the reviews http://www.ninjette.org/forums/showt...ghlight=levers |
January 1st, 2012, 08:02 PM | #7 |
The OEM brake lever has a slack adjuster with a lock wheel on it. Just give it enough slack that it comes closer to the handle. Keep it far enough away that the clutch is completely disengaged when you bring the lever to the bar, but that will get the friction zone closer to the handle albeit with some buzzing from the vibrations. Works for me. I might put on an adjustable ex500 clutch lever instead though. only $40 and is an OEM part.
Friction Zone in the Cold | Sykes92 | 2008 - 2012 Ninja 250R Tech Talk | 6 | December 16th, 2013 06:09 PM |
Friction Zone | Foom | 1986 - 2007 Ninja 250R Tech Talk | 4 | July 6th, 2011 10:31 AM |
Friction Zone | FF0000 | 1986 - 2007 Ninja 250R Tech Talk | 10 | June 24th, 2011 12:33 PM |
Help with the FRICTION ZONE | tjb0012 | Riding Skills | 11 | April 15th, 2010 05:07 AM |
friction zone and idle | ninjablk08 | 2008 - 2012 Ninja 250R Tech Talk | 28 | March 16th, 2009 08:06 PM |
