June 25th, 2010, 07:11 PM | #1 |
Join Date: Aug 2009 Motorcycle(s): 2014 Ninja 300, 2008 ZX6, 2011 Ninja 1000 Posts: 622
Owning Multiple Motorcycles
After I got the ZX6, I found myself not riding the 250 that much. But lately, I've been trying to ride the 2 an equal amount of time. What I find difficult is getting adjusted to one after riding the other. Sometimes the adjustment period is just a couple of minutes. Other times, it's like half the day or the entire ride. My biggest problems are with throttle control and turning. I can't seem to get used to the throttle on the 250. And turning... It feels like I am just slinging the 250 over when going through the twisties. I don't have any problems go to the ZX. I'm not sure why. There is also the state of mind issue, where the 250 mellows me out and the ZX puts me in an aggressive mode. But, that's a whole other post. How do you cope with switching between bikes? Is there a secret, or is it just a matter of sucking it up?
June 25th, 2010, 08:12 PM | #2 |
Join Date: May 2010 Motorcycle(s): 2010 ninja 250r, 2009 650r Posts: 150
Dang, you can afford insurance for both bikes? I got 3 bikes only one insured the 250r the 05 ZX-6r is just for mods and parking lots plus I got it for $1K form a friend. the 2009 650r was my dads but he doesn't want it so he left it for me =)
The 650r is the same colour as the 250r so I just change plates when I go out. |
June 25th, 2010, 08:47 PM | #3 | |
2010 250 Cup Champion
Join Date: Jan 2010 Motorcycle(s): 2008 Ninja 250R and 2007 Honda CR150F Posts: 168
K. |
June 27th, 2010, 03:46 AM | #4 |
Join Date: May 2010 Motorcycle(s): Current: '11 ZX-6R; Previous: '09 Ninjette; '08 ZX-6R (Ex-Wife '09 TU250X) Posts: 981
Well, I don't have any serious issue jumping on my wife's TU250X, but I do have to remember to slow a bit for corners and brake a bit earlier. I guess it is probably more a mental thing. Take it easy and make the adjustment. If you aren't feeling it that day, then you probably weren't riding in your zone anyways. Be safe out there.
August 4th, 2010, 10:22 PM | #5 |
Join Date: Sep 2009 Motorcycle(s): 08 ninja 250r modded, 73 honda cl200, 74 kawasaki 400 triple Posts: 255
when you mentioned turning, and said that you don't have any problems go to the zx...were you saying that you don't have problems going from the ninja to the zx? i have a 73 honda cl 200....it sat for probably about 20 years, and still has all the original parts, including cables so everything is really stiff...rode that for a week, when i first jumped back on the ninja i was a bit abrupt for a second, as i had gotten used to the clutch being stiffer, the brakes not working as well, and having to give it much more throttle to get it going...i tried out my boyfriend's cbr1000, and i felt way less confident turning, not being used to the handlebar position...and putting my feet up and down felt awkward with the rearsets being higher and further back...you are probably on the right track with alternating back and forth....the more experience you have with bikes that feel different, i'm sure will help you adjust faster
August 4th, 2010, 10:44 PM | #6 |
Join Date: Dec 2009 Motorcycle(s): Plasma Blue 2008 Ninja 250R, 2006 Honda Ruckus 180cc swap, 1967 BMW R60US, 2008 Ninja ZX-14se Posts: 240
Just rode my 250 for the first time in a couple months. Been riding the ZX-14 for 4000 miles. 250 now feels so slow, I first thought something was wrong with it! Took forever to warm up too and had to use a choke!
Guess you never notice these traits of the 250 until you get used to a bigger fuel injected bike! Still fun to just flog the hell out of it like I used to! It's a tough little bike that just keeps on ticking! |
August 5th, 2010, 05:59 AM | #7 |
I guess I'm kinda the opposite. I ride my 250 most of the time commuting to and from work. I jump on the 1000RR when I have the "need for speed" or just want a reminder of what 0-84 mph in first gear feels like.
August 5th, 2010, 07:00 AM | #8 |
Inadequate throttle response has been brought up a number of times on this forum. My read on this issue is that many of our participants are afraid of RPM. There is absolutely no need to be going 45mph in fifth or sixth gear. The Ninjette is all about RPM. I never run my bike under 7500 RPM. In that range, 7500 to 9000 RPM, the bike comes to life. For road riding in groups, the Ninja is fine, and will keep up with the bigger bikes. You just shift a lot more on the Ninja. Going from the ZX6R to the Ninjette would pose less of a problem if the Ninjette was revved higher. I regularly ride with people riding Honda 1000s, a 999 Ducati, 1100 BMW Dual Sport, a couple of Suzuki 650 Dual sports, Suzuki Boulevard 900, etc. I am usually the small bike.
August 19th, 2010, 08:16 AM | #9 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
polygamy has never been easy.
How do you adjust for the various rides? Um, practice practice practice. The more experience you have with each bike, the more solid your frame of reference will be, and the more unique each relationship will be, becoming easier as time goes by and experience increases. You could speed this process up by trying to ride as many bikes as you can. If you have friends who would trust you with their bike, ride their bike, switch half way through a ride... Tis good training to be able to ID a bike's character in the first few turns. A massive factor in all of this is also how hard you'll be riding each bike. If you're just putsing around town, the amount you have to adjust is significantly less than hauling balls on the track with both, for the limits of each bike are very different, and therefor the consequences of not knowing them significantly greater. Best of luck!
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
April 5th, 2011, 12:41 PM | #10 |
Join Date: Jul 2010 Motorcycle(s): 2014 Honda CRF250L, 2010 ninja 250r Posts: 413
This is the same for me. Gonna teach my wife to ride the 250.
April 6th, 2011, 05:32 PM | #11 | |
2 Years Strong
Join Date: Mar 2010 Motorcycle(s): 2011 Ninja 1000, 2008 Ninja 250R, 2007 Honda CRF 150F Posts: 30
April 6th, 2011, 08:51 PM | #12 |
I traded in my Ninja to get my ZX as I was offered a good bit over KBB so it was easier to deal with the dealer than to sell it (I had to to get the new bike). I still ride my wife's TU from time to time and I actually rode it to the store tonight to get a few two liter sodas. I have only had the ZX for a couple of days now, but I find the power to be quite addictive. I ask the bike to move, and it does. That TU is fun and it sounds great, but I can't see myself riding it for any other reason than a quick errand or a test ride after maintenance.
April 7th, 2011, 12:53 PM | #13 |
Join Date: Feb 2011 Motorcycle(s): Green 2013 ZX-6R Posts: 723
I have my ZX-6R for riding on the street and I bought my 250 just to be a dedicated race bike. I have no problem switching. Maybe you should just make your 250 a race bike.
http://www.simplysurrealphotography....es/peanut2.png |
April 7th, 2011, 04:45 PM | #14 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
My 250 is fast. But then again after riding on one of the 1000's the 250 feels nimble and slow.
Sportisimoto USA is born. |
April 29th, 2011, 03:34 PM | #15 |
Join Date: Jun 2010 Motorcycle(s): 2010 Ninja 250r Special Edition (Red/Black) / 2008 Suzuki GSXR 600 (Silver/White) / Ducati Diavel Carbon Red Posts: 76
My Ninja 250 is my daily bike. I ride my GSXR 600 mostly on the weekends. Cant beat the gas milage of the Ninja and I have it geared up to cruise at higher speeds on the freeways. Plus the Ninja 250 is so much easier/quicker to turn.
2010 Ninja 250r Special Edition Blk/Red, Pazzo controls, Lowering kit, Roaring Boyz Toyz risers, Corbin seat, Shogun frame sliders, Yoshimura Full Exhaust 2008 Suzuki GSXR 600 Silver/White |
May 2nd, 2011, 03:52 PM | #16 |
I loved my little Ninja, but my wife's TU kills it in fuel economy. I was averaging about 50 mpg mixed riding on the Ninjette, but I haven't ever seen the TU drop below 65 mpg. As fast as the Ninja 250 it isn't, but the damn thing handles pretty well, and it's a great commuter bike for my whopping nine mile trip.
Apparently it can get as much as seventy-plus miles a gallon. It would probably require me not riding it, and some flat ground somewhere.
R.I.P EthioKnight (Alex) |
May 6th, 2011, 06:52 AM | #17 |
Mid Life Crisis
Join Date: Feb 2011 Motorcycle(s): 2010 Ninja 250r (Passion Red); 1999 BMW K1200RS (Marrakesh Red) Posts: 81
My little Ninja was intended to be my commuter but I went crazy with all the mods like full exhaust,jet kit etc...now it gets about 49mpg . So now I have a fun little light weight bike with 30hp but my 1200 BMW with a hundred more ponies gets around 45mpg so I find myself choosing it more often. It's my fault for modifying the 250 to be something other than what I originally bought it for. Don't get me wrong I still like riding the 250 because it half the weight but I should have kept it stock. As far as getting used to the difference in the two it's only a few minutes and I'm good to go .
Kleen Air removed, Cali emissions removed, drilled slides, 15/43 JT's, 150/60 Rear |
May 6th, 2011, 07:19 AM | #18 |
Join Date: Mar 2011 Motorcycle(s): 899, 748, 250, 250, 70 Posts: 348
At my last trackday, I switched back and forth between the 250 and my S1000RR. At home, I switch up from the BMW to my old 748 to my 70cc Zuma all the time.
Ride whatever you feel like riding. If you don't ride one of them, get rid of it. |
May 6th, 2011, 07:20 AM | #19 |
CVMA #74 WSMC #750
Join Date: Oct 2009 Motorcycle(s): All of them Posts: A lot.
Funny thing, somethings I feel I can corner faster on a 250 than on my 600. What sucks about having multiple bikes is that you tend to ride one more than the other. Well, at least in my case that seems to be true. I've ridden my 600 only once this year whereas my 250 got around 4 or 5. Sad...truly sad.
May 7th, 2011, 08:38 PM | #20 |
Internet Slut
Join Date: Sep 2010 Motorcycle(s): 04 FZ1, 07 FZ6 Posts: A lot.
The issue i have is with turning, i tend to take turns to close on the 250 now that i ride the fazer, i forget how much tighter the turning is on the 250, all most hit my exaust on the curb last weekend, i had to play it off to the guy riding behind me like it was noo big deal as i felt like a dolt lol.
May 7th, 2011, 09:36 PM | #21 | |
2 Years Strong
May 8th, 2011, 02:30 PM | #22 |
Are you guys happy with the zx6r? Iv only been on a cbr600 besides the 250 and dont have much to compare it too. I like the seat height on the honda though.
May 8th, 2011, 02:47 PM | #23 |
vampire
Join Date: Feb 2011 Motorcycle(s): 2 many 2 list Posts: A lot.
I have a great empty office complex just 1/2 mi. from my driveway. Within the office complex there is a 1 3/4 mi. loop that I warm up my tires before every ride, take two laps if I really feel the need.
Two to three times a month I would take all my two-wheel vehicles out and ride a few laps on each of them.. Keeps me sharp on each and every one of my rides. |
Do you feel guilty about owning a bike? | MrAtom | General Motorcycling Discussion | 39 | April 10th, 2015 11:35 PM |
Why owning a gixxer for the street is a bad idea | Sirref | Videos | 15 | December 22nd, 2014 03:30 PM |
6 Things Nobody Tells You About Owning a Motorcycle | JeffM | General Motorcycling Discussion | 23 | October 17th, 2011 10:48 AM |
The psychology of owning a 250R? | ShelbyOne | General Motorcycling Discussion | 28 | April 6th, 2011 03:47 PM |
[topix.net] - Dog-owning drivers a danger to motorcycles | Ninjette Newsbot | Motorcycling News | 0 | August 18th, 2010 12:00 PM |
