July 31st, 2014, 11:51 PM | #1 |
Join Date: Jul 2014 Motorcycle(s): 2012 Ninja 250 Posts: 2
Handlebar Mount Bolt Missing??
Hello,
The car is out of commission due to some maintenance that I've messed up :/ so I have been riding the ninja to work. Tonight when I was out oiling the chain I noticed the large handlebar mount bolt is missing?? I heard a clunk noise when I was riding it home today, could that have been it falling out or has someone sabotaged me? Is that what this bolt is called? My main question is is it safe to ride this to work for one day without that bolt? I've attached a picture. Thank you, -Jonathan |
August 1st, 2014, 12:16 AM | #2 |
Private Joker
MOTM - Mar '14
I would be sketched out and therefore wouldn't but I don't actually know for sure if it would cause any severe problems since I've never come across that exact problem.
That particular bolt is what connects the bars/forks/front wheel to the rest of the bike so I can imagine a laundry list of potential problems that could come up, largely with steering, braking, and accelerating...
August 1st, 2014, 05:03 AM | #3 |
Thank you for your words of wisdom lol I feel pretty much the same way. Anybody know what size that bolt is so I can get a temp. replacement until I can get the OEM bolt?
August 1st, 2014, 08:24 AM | #4 |
Join Date: Apr 2014 Motorcycle(s): Ninja 250, Yamaha RS200 (classic) Posts: A lot.
It's the "Stem head bolt"
The problems off the top of my head :- The weight mostly is taken on steel bottom yoke. The steering bearings should have a separate locknut so are of less concern The forks minus that bolt will be a little more inclined to twist and it is that twisting in the yokes which will misshape the holes they pass through or even shear the pinchbolts. (Catastrophic since the front of the bike will colapse as the forks slide right up through the loose lower yoke holes. If you cant get a Ninjette bolt I would imagine other bikes use the same thread to replace it (and the washer) until you get the real thing. and check the pinch bolt torques afterwards. If you ride it at all I would be inclined to make it a gentle run to a dealer for a part and phone in to work. (potholes, drain covers and hard braking are not your friend) Last futzed with by Ninjinsky; August 1st, 2014 at 10:15 AM. |
August 1st, 2014, 08:54 AM | #5 | |
Certified looney toon
MOTM Jul '13, Jul '14
BOLT,FLANGED,16X22,F.S.BLACK 92154-0075-18R
Missing essential bolt! Need help! | Floki | 2008 - 2012 Ninja 250R Tech Talk | 4 | October 6th, 2013 03:08 PM |
Missing bolt / Someone tried to steal my bike? | sunspots | 2008 - 2012 Ninja 250R Tech Talk | 12 | September 19th, 2013 06:24 AM |
fairing bolt missing | kittyslasher | 2008 - 2012 Ninja 250R Tech Talk | 3 | July 30th, 2013 04:44 PM |
Help with missing bolt | dk58 | 2008 - 2012 Ninja 250R Tech Talk | 22 | May 11th, 2011 07:07 PM |
missing fork clamp bolt | boyonfire | 1986 - 2007 Ninja 250R Tech Talk | 11 | June 2nd, 2009 04:24 AM |
